[FAQ] LAUNCHXL-F28P65X: How do I fix the EtherCAT issue where the launchpad cannot be scanned in TwinCAT?
Part Number: LAUNCHXL-F28P65X
Other Parts Discussed in Thread: C2000WARE, DP83826E
The first production run of Revision A F28P65X launchpads, which were all shipped in 2023, will not work out of the box when directly following the EtherCAT SubordinateDevice Controller Software User’s Guide that is provided in C2000WARE. This issue affects LAUNCHXL-F28P65X devices with a serial number beginning with CL652307,CL652308,CL652309,CL652310. The serial number is located on the bottom side of the LaunchPad. This is because the boards were designed to use REV1 of the DP83826E PHY, but these early REVA boards were mistakenly manufactured with REV0 of DP83826E. If users find that their board is affected by this issue, and they do not want to use the software workaround provided in this document, they can replace the REV0 PHY with a REV1 PHY to get the expected behavior. All DP83826E PHYs shipped by TI after 2023 should be REV1, and all LAUNCHXL-F28P65X boards shipped by TI after 2023 should have REV1 PHYs.
Please refer to the attached LAUNCHXL-F28P65X_REVA_workaround.pdf for detailed instructions on how to fix this issue. This guide will provide instructions for F28P65x on how to program/read the EEPROM without using TwinCAT, and it will give instructions on how to read/write PHY registers. These instructions could be useful for general debugging, and we may include these projects in a future C2000WARE release.
  • 0284.F28P65X Launchpad REVA Bug.pdf
    // FILE:   ethercat_slave_cpu1_hal.c
    // TITLE:  C28.CPU1 EtherCAT HAL Driver.
    // $TI Release: F28P65x EtherCAT Software v1.00.00.00 $
    // $Release Date: Fri Mar  3 16:18:57 IST 2023 $
    // $Copyright:
    // Copyright (C) 2021 Texas Instruments Incorporated - http://www.ti.com/
    // Redistribution and use in source and binary forms, with or without
    // modification, are permitted provided that the following conditions
    // are met:
    //   Redistributions of source code must retain the above copyright
    //   notice, this list of conditions and the following disclaimer.
    //   Redistributions in binary form must reproduce the above copyright
    //   notice, this list of conditions and the following disclaimer in the
    //   documentation and/or other materials provided with the
    //   distribution.
    //   Neither the name of Texas Instruments Incorporated nor the names of
    //   its contributors may be used to endorse or promote products derived
    //   from this software without specific prior written permission.
    // THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
    // "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
    // LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    // A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
    // OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
    // SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
    // LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    // DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
    // THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    // (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
    // OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    // Included Files
    #include "ethercat_subdevice_cpu1_hal.h"
    #ifdef PDI_HAL_TEST
    // HAL Test Application - Register Debug Structure
    ESC_DebugRegisters ESC_escRegs[ESC_HAL_TEST_DEBUG_REGS_LENGTH];
    // HAL Block Data Arrays
    static uint32_t ESC_writeBlockData[ESC_HAL_TEST_BLOCK_LENGTH / 4U];
    static uint32_t ESC_readBlockData[ESC_HAL_TEST_BLOCK_LENGTH / 4U];
    #endif // PDI_HAL_TEST
    // ESC_getTimer
    uint32_t
    ESC_getTimer(void)
        // Return 1's compliment of the CPU timer
        return(~((uint32_t)CPUTimer_getTimerCount(CPUTIMER0_BASE)));
    // ESC_clearTimer
    void
    ESC_clearTimer(void)
        // Set the timer period count
        CPUTimer_setPeriod(CPUTIMER0_BASE, 0xFFFFFFFFUL);
        // Reload timer with the period count value
        CPUTimer_reloadTimerCounter(CPUTIMER0_BASE);
    // ESC_timerIncPerMilliSec
    uint32_t
    ESC_timerIncPerMilliSec(void)
        // Returns value based on core frequency of 200MHz.
        return((uint32_t)200000UL);
    // ESC_readBlockISR
    void
    ESC_readBlockISR(ESCMEM_ADDR *pData, uint16_t address, uint16_t len)
        // Create pointer to ESC Address
        const void * escSource = (void *)(ESC_BASE + (uint32_t)(address / 2U));
        // Copy ESC data to buffer. Convert lengths to words.
        memcpy(pData, escSource, (size_t)((len + 1U) >> 1U));
        // Determine if length (in bytes) is even or odd
        // (No action on even)
        if((len & 0x1U) == 0x1U)
            // Odd Length
            // Clear extra byte in buffer
            pData[((len - 1U) / 2U)] = (pData[((len - 1U) / 2U)] & ESC_M_LSB);
    // ESC_readBlock
    void
    ESC_readBlock(ESCMEM_ADDR *pData, uint16_t address, uint16_t len)
        // Disables interrupts
        DINT;
        // Perform copy of ESC data to buffer
        ESC_readBlockISR(pData, address, len);
        // Enable interrupts
        EINT;
    // ESC_readDWordISR
    uint32_t
    ESC_readDWordISR(uint16_t address)
        // Read 32-bit address from ESC memory
        return(HWREG(ESC_BASE + (address / 2U)));
    // ESC_readDWord
    uint32_t
    ESC_readDWord(uint16_t address)
        uint32_t dWordValue;
        DINT;
        dWordValue = ESC_readDWordISR(address);
        EINT;
        // Return value
        return(dWordValue);
    // ESC_readWordISR
    uint16_t
    ESC_readWordISR(uint16_t address)
        // Read 16-bit address from ESC memory
        return(HWREGH(ESC_BASE + (address / 2U)));
    // ESC_readWord
    uint16_t
    ESC_readWord(uint16_t address)
        uint16_t wordValue;
        DINT;
        wordValue = ESC_readWordISR(address);
        EINT;
        // Return value
        return(wordValue);
    // ESC_writeBlockISR
    void
    ESC_writeBlockISR(ESCMEM_ADDR *pData, uint16_t address, uint16_t len)
        uint16_t wordValue;
        void * escDest = (void *)(ESC_BASE + (uint32_t)(address / 2U));
            // Odd Length
            // Copy even bytes of buffer data to ESC memory.
            // Convert length to words.
            memcpy(escDest, pData, (size_t)((len - 1U) >> 1U));
            // Read last 16-bit word
            wordValue = ESC_readWordISR(address + (len - 1U));
            // Modify word data and set new data
            wordValue &= ESC_M_MSB;
            wordValue |= (pData[((len - 1U) / 2U)] & ESC_M_LSB);
            // Write modified value to ESC destination
            ESC_writeWordISR(wordValue, (address + (len - 1U)));
        else
            // Even Length
            // Copy buffer data to ESC memory. Convert length to words.
            memcpy(escDest, pData, (size_t)(len >> 1U));
    // ESC_writeBlock
    void
    ESC_writeBlock(ESCMEM_ADDR *pData, uint16_t address, uint16_t len)
        DINT;
        // Write data buffer into ESC memory
        ESC_writeBlockISR(pData, address, len);
        EINT;
    // ESC_writeDWordISR
    void
    ESC_writeDWordISR(uint32_t dWordValue, uint16_t address)
        // Write two 16-bit words to ESC memory
        HWREG(ESC_BASE + (address / 2U)) = dWordValue;
    // ESC_writeDWord
    void
    ESC_writeDWord(uint32_t dWordValue, uint16_t address)
        DINT;
        // Write two 16-words into ESC memory
        ESC_writeDWordISR(dWordValue, address);
        EINT;
    // ESC_writeWordISR
    void
    ESC_writeWordISR(uint16_t wordValue, uint16_t address)
        // Write 16-bit word into ESC memory
        HWREGH(ESC_BASE + (address / 2U)) = wordValue;
    // ESC_writeWord
    void
    ESC_writeWord(uint16_t wordValue, uint16_t address)
        DINT;
        // Write one 16-word into ESC memory
        ESC_writeWordISR(wordValue, address);
        EINT;
    // ESC_setLed
    void
    ESC_setLed(uint16_t runLed, uint16_t errLed)
        // Set/Clear Run LED
        GPIO_writePin(ESC_RUN_LED_GPIO, (uint32_t)(runLed));
        // Set/Clear Error LED
        GPIO_writePin(ESC_ERR_LED_GPIO, (uint32_t)(errLed));
    #ifdef PDI_HAL_TEST
    // HAL_initWriteBlockData
    void HAL_initWriteBlockData(void)
        uint16_t i;
        // Initialize write block data array
        for(i = 0U; i < (ESC_HAL_TEST_BLOCK_LENGTH / 4U); i++)
            ESC_writeBlockData[i] = 0x1234ABCDUL;
    // HAL_clearReadBlockData
    void HAL_clearReadBlockData(void)
        uint16_t i;
        // Clear read block data array
            ESC_readBlockData[i] = 0x0UL;
    // HAL_testBlockData
    uint16_t HAL_testBlockData(uint16_t length)
        uint16_t i;
        uint16_t * writeData = (uint16_t *)(&ESC_writeBlockData[0]);
        uint16_t * readData = (uint16_t *)(&ESC_readBlockData[0]);
        // Check if odd length of bytes
        if((length & 0x1U) == 0x1U)
            // Odd Length of Bytes
            // Check that data written and data read match
            for(i = 0U; i < ((length - 1U) / 2U); i++)
                if(*writeData != *readData)
                    return(ESC_HAL_BLOCK_TEST_FAIL);
                writeData++;
                readData++;
            // Check last byte
            if(((*writeData) & ESC_M_LSB) != ((*readData) & ESC_M_LSB))
        else
            // Even Length of Bytes
            for(i = 0U; i < (length / 2U); i++)
                writeData++;
                readData++;
        return(ESC_HAL_BLOCK_TEST_PASS);
    // ESC_setupPDITestInterface
    void
    ESC_setupPDITestInterface(void)
        uint16_t currentAddress = 0x0U;
        uint32_t doubleWordData = 0x0UL;
        uint16_t wordData = 0x0U;
        // Setup and add various ESC register byte addresses to monitor
        ESC_debugInitESCRegLogs();
        ESC_debugAddESCRegsAddress(0x0U);     // Type, Revision
        ESC_debugAddESCRegsAddress(0x2U);     // Build
        ESC_debugAddESCRegsAddress(0x4U);     // FMMUs, SyncManagers Supported
        ESC_debugAddESCRegsAddress(0x8U);     // ESC Supported Features
        ESC_debugAddESCRegsAddress(0x100U);   // DL Control
        ESC_debugAddESCRegsAddress(0x102U);   // DL Control (Extended)
        ESC_debugAddESCRegsAddress(0x110U);   // DL Status
        ESC_debugAddESCRegsAddress(0x310U);   // Lost Link Counter 1
        ESC_debugAddESCRegsAddress(0x312U);   // Lost Link Counter 2
        ESC_debugAddESCRegsAddress(0x510U);   // MII Control/Status
        ESC_debugAddESCRegsAddress(0x512U);   // PHY Address
        ESC_debugAddESCRegsAddress(0x514U);   // PHY Data
        ESC_debugAddESCRegsAddress(0x516U);   // MII ECAT Access State
        ESC_debugAddESCRegsAddress(0x518U);   // PHY Port Status (1)
        ESC_debugAddESCRegsAddress(0x51AU);   // PHY Port Status (2)
        ESC_debugAddESCRegsAddress(0x1000U);  // First data word of ESC RAM
        // Check that correct PDI type (ASYNC16) is configured
        if((ESC_readWord(ESC_O_PDI_CONTROL) & ESC_PDI_CONTROL_ASYNC16) !=
            // PDI not operational or incorrect
            while(1)
                // Toggle Error
                ESC_signalFail();
        // Perform PDI read and write tests for entire ESC PDI RAM range
        for(currentAddress = ESC_PDI_RAM_START_ADDRESS_OFFSET;
            currentAddress <= ESC_PDI_RAM_END_ADDRESS_OFFSET;
            currentAddress += 4U)
            // Read DWord and Write DWord API Tests
            doubleWordData = ESC_readDWord(currentAddress);
            ESC_writeDWord(0xABCD1234UL, currentAddress);
            if(doubleWordData != 0xABCD1234UL)
                while(1)
                    // Toggle Error
                    ESC_signalFail();
            doubleWordData = ESC_readDWordISR(currentAddress);
            ESC_writeDWordISR(0x1A2B3C4DUL, currentAddress);
            if(doubleWordData != 0x1A2B3C4DUL)
                while(1)
                    // Toggle Error
                    ESC_signalFail();
            // Read Word and Write Word API Tests
            wordData = ESC_readWord(currentAddress);
            ESC_writeWord(0x6789U, currentAddress);
            if(wordData != 0x6789U)
                while(1)
                    // Toggle Error
                    ESC_signalFail();
            wordData = ESC_readWordISR(currentAddress);
            ESC_writeWordISR(0x5A5AU, currentAddress);
            if(wordData != 0x5A5AU)
                while(1)
                    // Toggle Error
                    ESC_signalFail();
        // Setup for read/write block API Tests
        HAL_initWriteBlockData();
        // Perform even length write and read block (non-ISR) API Test
        ESC_writeBlock((uint16_t *)(&ESC_writeBlockData[0]),
                       ESC_PDI_RAM_START_ADDRESS_OFFSET,
                       ESC_HAL_TEST_BLOCK_LENGTH);
        ESC_readBlock((uint16_t *)(&ESC_readBlockData[0]),
        if(HAL_testBlockData(ESC_HAL_TEST_BLOCK_LENGTH) != ESC_HAL_BLOCK_TEST_PASS)
            while(1)
                // Toggle Error
                ESC_signalFail();
        HAL_clearReadBlockData();
        // Perform even length write and read block API Test
        ESC_writeBlockISR((uint16_t *)(&ESC_writeBlockData[0]),
                          (ESC_PDI_RAM_START_ADDRESS_OFFSET + 0x1000U),
        ESC_readBlockISR((uint16_t *)(&ESC_readBlockData[0]),
            while(1)
                // Toggle Error
                ESC_signalFail();
        // Perform odd length write and read block (non-ISR) API Test
                       (ESC_PDI_RAM_START_ADDRESS_OFFSET + 0x2000U),
                       (ESC_HAL_TEST_BLOCK_LENGTH - 1U));
        if(HAL_testBlockData((ESC_HAL_TEST_BLOCK_LENGTH - 1U)) !=
            while(1)
                // Toggle Error
                ESC_signalFail();
        // Perform odd length write and read block API Test
                          (ESC_PDI_RAM_START_ADDRESS_OFFSET + 0x3000U),
            while(1)
                // Toggle Error
                ESC_signalFail();
        // Pass
        ESC_signalPass();
    // ESC_debugUpdateESCRegLogs
    void
    ESC_debugUpdateESCRegLogs(void)
        uint16_t i = 0U;
        // Update ESC register data into debug array
        while(ESC_escRegs[i].address != 0xFFFFU)
            ESC_escRegs[i].data = ESC_readWord(ESC_escRegs[i].address);
            i++;
    // ESC_debugAddESCRegsAddress
    void
    ESC_debugAddESCRegsAddress(uint16_t address)
        uint16_t i = 0U;
        // Add ESC Register Address to debug array
        for(i = 0U; i < ESC_HAL_TEST_DEBUG_REGS_LENGTH; i++)
            if(ESC_escRegs[i].address == 0xFFFFU)
                // Assign byte address to struct
                ESC_escRegs[i].address = address;
                return;
    // ESC_debugInitESCRegLogs
    void
    ESC_debugInitESCRegLogs(void)
        uint16_t i = 0U;
        // Initialize ESC register debug array
            ESC_escRegs[i].address = 0xFFFFU;
            ESC_escRegs[i].data = 0xFFFFU;
    // ESC_signalPass
    void
    ESC_signalPass(void)
        // Turn on controlCARD LEDs
        GPIO_writePin(CCARD_LED_1_GPIO, 0UL);
        GPIO_writePin(CCARD_LED_2_GPIO, 0UL);
    // ESC_signalFail
    void
    ESC_signalFail(void)
        // Toggle controlCARD LEDs and delay
        GPIO_togglePin(CCARD_LED_1_GPIO);
        GPIO_togglePin(CCARD_LED_2_GPIO);
        DEVICE_DELAY_US((uint32_t)(500000));
    // ESC_passFailSignalSetup
    void
    ESC_passFailSignalSetup(void)
        // Set LED GPIOs to output mode
        GPIO_setDirectionMode(CCARD_LED_1_GPIO, GPIO_DIR_MODE_OUT);
        GPIO_setDirectionMode(CCARD_LED_2_GPIO, GPIO_DIR_MODE_OUT);
        // Turn off controlCARD LEDs
        GPIO_writePin(CCARD_LED_1_GPIO, 1UL);
        GPIO_writePin(CCARD_LED_2_GPIO, 1UL);
    // ESC_loadedCheckEEPROM
    uint16_t
    ESC_loadedCheckEEPROM(void)
        uint16_t status;
        // Get ESC DL Status register
        status = ESC_readWord(ESC_O_DL_STATUS);
        // Check if EEPROM is loaded
        if((status & ESC_DL_STATUS_EEPROMLOAD_M) == ESC_DL_STATUS_EEPROMLOAD_M)
            // Get ESC EEPROM Status register
            status = ESC_readWord(ESC_O_EEPROM_STATUS);
            // Check if EEPROM is loaded and device information is okay
            if((status & ESC_EEPROM_STATUS_EEPROMLOAD_M) == ESC_EEPROM_SUCCESS)
                return(ESC_EEPROM_SUCCESS);
            else
                return(ESC_EEPROM_LOAD_ERROR);
        else
            // DL Status indicated EEPROM is not loaded
            return(ESC_EEPROM_NOT_LOADED);
    // ESC_resetESC
    void
    ESC_resetESC(void)
        SysCtl_resetPeripheral(SYSCTL_PERIPH_RES_ECAT);
    // ESC_holdESCInReset
    void
    ESC_holdESCInReset(void)
        // Put ESC in reset
        EALLOW;
        HWREGH(DEVCFG_BASE + SYSCTL_O_SOFTPRES23) |= SYSCTL_SOFTPRES23_ETHERCAT;
        EDIS;
    // ESC_releaseESCReset
    void
    ESC_releaseESCReset(void)
        // Release from reset
        EALLOW;
        HWREGH(DEVCFG_BASE + SYSCTL_O_SOFTPRES23) &= (~SYSCTL_SOFTPRES23_ETHERCAT);
        EDIS;
    // Functions for reading / writing to DP838xx PHY devices
    #define ESC_MII_CTRL_STATUS_OFFSET          0x0510 // 0x288 - Low
    #define ESC_PHY_ADDRESS_OFFSET              0x0512 // 0x289 - Low
    #define ESC_PHY_REG_ADDRESS_OFFSET          0x0513 // 0x289 - High
    #define ESC_PHY_DATA_OFFSET                 0x0514 // 0x28A - Low
    #define ESC_MII_ECAT_ACCESS_OFFSET          0x0516 // 0x28B - Low
    #define ESC_MII_PDI_ACCESS_OFFSET           0x0517 // 0x28B - High
    // Function for reading from an ESC PHY register using CPU1 -
    //      Assumes Word and address are 16-bit values
    uint16_t mii_readPhyRegister(uint16_t address, uint16_t target_phy_address)
        // Set PHY address to read/write, (0x0512//0x289 low)
        ESC_writeWordISR((address<<8) | target_phy_address, ESC_PHY_ADDRESS_OFFSET);
        // Write PHY reg, (0x0510//0x288 low)
        ESC_writeWordISR(0x0100,ESC_MII_CTRL_STATUS_OFFSET);
        ESC_writeWordISR(0x0103,ESC_MII_CTRL_STATUS_OFFSET);
        //DEVICE_DELAY_US(100);
        while(ESC_readWordISR(ESC_MII_CTRL_STATUS_OFFSET) != 0x3); // wait till read is completed and successful
        return ESC_readWordISR(ESC_PHY_DATA_OFFSET);
    // Function for writing to an ESC PHY register using CPU1 -
    void mii_writePhyRegister(uint16_t address, uint16_t target_phy_address, uint16_t data)
        ESC_writeWordISR(data, ESC_PHY_DATA_OFFSET);
        ESC_writeWordISR(0x203, ESC_MII_CTRL_STATUS_OFFSET);
        while(ESC_readWordISR(ESC_MII_CTRL_STATUS_OFFSET) != 0x3); // wait till write is completed and successful
    //  Function for reading extended PHY Register, different from reading first 0x1F address
    void mii_writePhyExtendedRegister(uint16_t address, uint16_t target_phy_address, uint16_t data)
        mii_writePhyRegister(0x0D,target_phy_address,0x001F);
        mii_writePhyRegister(0x0E,target_phy_address,address);
        mii_writePhyRegister(0x0D,target_phy_address,0x401F);
        mii_writePhyRegister(0x0E,target_phy_address,data);
    // Function for reading from an Extended ESC PHY register using CPU1 -
    uint16_t mii_readPhyExtendedRegister(uint16_t address, uint16_t target_phy_address)
        mii_writePhyRegister(0xD, target_phy_address, 0x1F); //Phy reg 0xD = 0x1F
        mii_writePhyRegister(0xE, target_phy_address, address); //Phy Reg 0xE = *Address of register outside of 0-1F
        mii_writePhyRegister(0xD, target_phy_address, 0x401F); //Phy reg 0xD = 0x401F
        return(mii_readPhyRegister(0xE, target_phy_address)); // Extended read data
    void enable_PDI_access_to_MII(void)
        ESC_writeWordISR(0x0100,ESC_MII_ECAT_ACCESS_OFFSET); // Give PDI access to MII management
        return;
    uint16_t phy_regs_0[32];      // For storing first 32 PHY registers of Port0
    uint16_t ext_phy_regs_0[48];  // For storing Extended PHY registers of Port0
    uint16_t phy_regs_1[32];      // For storing first 32 PHY registers of Port1
    uint16_t ext_phy_regs_1[48];  // For storing Extended PHY registers of Port1
    // ESC_initHW
    uint16_t
    ESC_initHW(void)
        // Set application-specific timeout for waiting for EEPROM to load
        // and one for waiting for memory initialization
        // (End user can adjust as needed)
        uint16_t eepromTimeOut = 0x1000U;
        uint16_t memoryTimeOut = 0x300U;
        // Disable the watchdog
        SysCtl_disableWatchdog();
    #ifdef _FLASH
        // Copy time critical code and flash setup code to RAM. This includes the
        // following functions: Flash_initModule();
        // The RamfuncsLoadStart, RamfuncsLoadSize, and RamfuncsRunStart symbols
        // are created by the linker. Refer to the device .cmd file.
        memcpy(&RamfuncsRunStart, &RamfuncsLoadStart, (size_t)&RamfuncsLoadSize);
        // Call Flash Initialization to setup flash waitstates. This function must
        // reside in RAM.
        Flash_initModule(FLASH0CTRL_BASE, FLASH0ECC_BASE, DEVICE_FLASH_WAITSTATES);
    #endif
        // Verify the XTAL crystal frequency.
    #warn "IMPORTANT: F2838x EtherCAT software is now built for XTAL source of 25MHz. Refer to the EtherCAT Software User Guide for more information"
        if(!Device_verifyXTAL(DEVICE_OSCSRC_FREQ / 1000000))
            // The actual XTAL frequency does not match DEVICE_OSCSRC_FREQ!!
            // Please check the XTAL frequency used.
            // Note that the latest F2838x controlCARDs (Rev.B and later) have been
            // updated to use 25MHz XTAL by default. If you have an older 20MHz XTAL
            // controlCARD (E1, E2, or Rev.A), refer to the controlCARD
            // documentation on steps to reconfigure the controlCARD from 20MHz to
            // 25MHz.
            ESTOP0;
            GPIO_setDirectionMode(DEVICE_GPIO_PIN_LED1, GPIO_DIR_MODE_OUT);
            GPIO_setDirectionMode(DEVICE_GPIO_PIN_LED2, GPIO_DIR_MODE_OUT);
            while(1)
                GPIO_togglePin(DEVICE_GPIO_PIN_LED1);
                GPIO_togglePin(DEVICE_GPIO_PIN_LED2);
                DEVICE_DELAY_US((uint32_t)(50000));
        // Set up device clock
        SysCtl_setClock(DEVICE_SETCLOCK_CFG);
        // Make sure the LSPCLK divider is set to the default (divide by 4)
        SysCtl_setLowSpeedClock(SYSCTL_LSPCLK_PRESCALE_4);
        // Turn on all peripherals and initialize GPIOs
        Device_enableAllPeripherals();
        Device_initGPIO();
        // Configure GPIOs for ECAT
    #ifdef _LAUNCHXL_F28P65X
        // PHY Reset
        GPIO_setPinConfig(GPIO_76_ESC_PHY_RESETN);
        GPIO_setQualificationMode(76,GPIO_QUAL_ASYNC);
        // I2C for EEPROM
        GPIO_setPinConfig(GPIO_40_ESC_I2C_SDA);
        GPIO_setQualificationMode(40,GPIO_QUAL_ASYNC);
        GPIO_setPadConfig(40,GPIO_PIN_TYPE_PULLUP);
        GPIO_setPinConfig(GPIO_30_ESC_I2C_SCL);
        GPIO_setQualificationMode(30,GPIO_QUAL_ASYNC);
        GPIO_setPadConfig(30,GPIO_PIN_TYPE_PULLUP);
        // P0 TX and RX DATA
        GPIO_setPinConfig(GPIO_87_ESC_TX0_DATA0);
        GPIO_setQualificationMode(87,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_88_ESC_TX0_DATA1);
        GPIO_setQualificationMode(88,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_89_ESC_TX0_DATA2);
        GPIO_setQualificationMode(89,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_90_ESC_TX0_DATA3);
        GPIO_setQualificationMode(90,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_80_ESC_RX0_DATA0);
        GPIO_setQualificationMode(80,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_28_ESC_RX0_DATA1);
        GPIO_setQualificationMode(28,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_29_ESC_RX0_DATA2);
        GPIO_setQualificationMode(29,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_83_ESC_RX0_DATA3);
        GPIO_setQualificationMode(83,GPIO_QUAL_ASYNC);
        // P0 TX Enable, RX DV, RX ERR
        GPIO_setPinConfig(GPIO_56_ESC_TX0_ENA);
        GPIO_setQualificationMode(56,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_78_ESC_RX0_DV);
        GPIO_setQualificationMode(78,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_26_ESC_RX0_ERR);
        GPIO_setPadConfig(26,GPIO_PIN_TYPE_STD);
        // P0 TX and RX Clk
        GPIO_setPinConfig(GPIO_85_ESC_TX0_CLK);
        GPIO_setQualificationMode(85,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_77_ESC_RX0_CLK);
        GPIO_setQualificationMode(77,GPIO_QUAL_ASYNC);
        // P0 Linkstatus and Link Active LED
        GPIO_setPinConfig(GPIO_86_ESC_PHY0_LINKSTATUS);
        GPIO_setPadConfig(86,GPIO_PIN_TYPE_INVERT);
        GPIO_setQualificationMode(86,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_58_ESC_LED_LINK0_ACTIVE);
        GPIO_setQualificationMode(58, GPIO_QUAL_ASYNC);
        // P0+P1 MDIO CLK and Data
        GPIO_setPinConfig(GPIO_62_ESC_MDIO_CLK);
        GPIO_setQualificationMode(62,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_27_ESC_MDIO_DATA);
        GPIO_setQualificationMode(27,GPIO_QUAL_ASYNC);
        // P1 TX and RX DATA
        GPIO_setPinConfig(GPIO_22_ESC_TX1_DATA0);
        GPIO_setQualificationMode(22,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_74_ESC_TX1_DATA1);
        GPIO_setQualificationMode(74,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_73_ESC_TX1_DATA2);
        GPIO_setQualificationMode(73,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_19_ESC_TX1_DATA3);
        GPIO_setQualificationMode(19,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_63_ESC_RX1_DATA0);
        GPIO_setQualificationMode(63,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_64_ESC_RX1_DATA1);
        GPIO_setQualificationMode(64,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_65_ESC_RX1_DATA2);
        GPIO_setQualificationMode(65,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_66_ESC_RX1_DATA3);
        GPIO_setQualificationMode(66,GPIO_QUAL_ASYNC);
        // P1 TX Enable, RX DV, RX ERR
        GPIO_setPinConfig(GPIO_45_ESC_TX1_ENA);
        GPIO_setQualificationMode(45,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_70_ESC_RX1_DV);
        GPIO_setQualificationMode(70,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_71_ESC_RX1_ERR);
        GPIO_setPadConfig(71,GPIO_PIN_TYPE_STD);
        // P1 TX and RX Clk
        GPIO_setPinConfig(GPIO_44_ESC_TX1_CLK);
        GPIO_setQualificationMode(44,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_69_ESC_RX1_CLK);
        GPIO_setQualificationMode(69,GPIO_QUAL_ASYNC);
        // P1 Linkstatus and Link Active LED
        GPIO_setPinConfig(GPIO_68_ESC_PHY1_LINKSTATUS);
        GPIO_setPadConfig(68,GPIO_PIN_TYPE_INVERT);
        GPIO_setQualificationMode(68,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_59_ESC_LED_LINK1_ACTIVE);
        GPIO_setQualificationMode(59, GPIO_QUAL_ASYNC);
        // Sync and Latch
        // Note these GPIOs aren't required for EtherCAT
        // operation and are configured here for demonstration,
        // analysis, and debug purposes
        GPIO_setPinConfig(GPIO_34_ESC_SYNC0);
        GPIO_setQualificationMode(34,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_35_ESC_SYNC1);
        GPIO_setQualificationMode(35,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_60_ESC_LATCH0);
        GPIO_setQualificationMode(60,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_51_ESC_LATCH1);
        GPIO_setQualificationMode(51,GPIO_QUAL_ASYNC);
        // Set GPIO direction for ECAT RUN/ERR LEDs
        GPIO_setPinConfig(GPIO_33_ESC_LED_ERR);
        GPIO_setQualificationMode(33,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_61_ESC_LED_RUN);
        GPIO_setQualificationMode(61,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_0_ESC_GPI0);
        GPIO_setQualificationMode(0,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_8_ESC_GPO0);
        GPIO_setQualificationMode(8,GPIO_QUAL_ASYNC);
        #else
        // PHY Reset
        GPIO_setPinConfig(GPIO_155_ESC_PHY_RESETN);
        GPIO_setQualificationMode(155,GPIO_QUAL_ASYNC);
        // I2C for EEPROM
        GPIO_setPinConfig(GPIO_150_ESC_I2C_SDA);
        GPIO_setQualificationMode(150,GPIO_QUAL_ASYNC);
        GPIO_setPadConfig(150,GPIO_PIN_TYPE_PULLUP);
        GPIO_setPinConfig(GPIO_151_ESC_I2C_SCL);
        GPIO_setQualificationMode(151,GPIO_QUAL_ASYNC);
        GPIO_setPadConfig(151,GPIO_PIN_TYPE_PULLUP);
        GPIO_setPinConfig(GPIO_158_ESC_TX0_DATA0);
        GPIO_setQualificationMode(158,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_159_ESC_TX0_DATA1);
        GPIO_setQualificationMode(159,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_160_ESC_TX0_DATA2);
        GPIO_setQualificationMode(160,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_161_ESC_TX0_DATA3);
        GPIO_setQualificationMode(161,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_165_ESC_RX0_DATA0);
        GPIO_setQualificationMode(165,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_166_ESC_RX0_DATA1);
        GPIO_setQualificationMode(166,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_167_ESC_RX0_DATA2);
        GPIO_setQualificationMode(167,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_168_ESC_RX0_DATA3);
        GPIO_setQualificationMode(168,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_156_ESC_TX0_ENA);
        GPIO_setQualificationMode(156,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_162_ESC_RX0_DV);
        GPIO_setQualificationMode(162,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_164_ESC_RX0_ERR);
        GPIO_setPadConfig(164,GPIO_PIN_TYPE_STD);
        // P0 TX and RX Clk
        GPIO_setPinConfig(GPIO_157_ESC_TX0_CLK);
        GPIO_setQualificationMode(157,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_163_ESC_RX0_CLK);
        GPIO_setQualificationMode(163,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_148_ESC_PHY0_LINKSTATUS);
        GPIO_setPadConfig(148,GPIO_PIN_TYPE_INVERT);
        GPIO_setQualificationMode(148,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_152_ESC_MDIO_CLK);
        GPIO_setQualificationMode(152,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_153_ESC_MDIO_DATA);
        GPIO_setQualificationMode(153,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_131_ESC_TX1_DATA0);
        GPIO_setQualificationMode(131,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_132_ESC_TX1_DATA1);
        GPIO_setQualificationMode(132,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_134_ESC_TX1_DATA2);
        GPIO_setQualificationMode(134,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_141_ESC_RX1_DATA2);
        GPIO_setQualificationMode(141,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_142_ESC_RX1_DATA3);
        GPIO_setQualificationMode(142,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_129_ESC_TX1_ENA);
        GPIO_setQualificationMode(129,GPIO_QUAL_ASYNC);
        // P1 TX and RX Clk
        GPIO_setPinConfig(GPIO_130_ESC_TX1_CLK);
        GPIO_setQualificationMode(130,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_149_ESC_PHY1_LINKSTATUS);
        GPIO_setPadConfig(149,GPIO_PIN_TYPE_INVERT);
        GPIO_setQualificationMode(149,GPIO_QUAL_ASYNC);
        // Sync and Latch
        GPIO_setPinConfig(GPIO_127_ESC_SYNC0);
        GPIO_setQualificationMode(127,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_50_ESC_LATCH0);
        GPIO_setQualificationMode(50,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_30_ESC_LATCH1);
        GPIO_setPinConfig(GPIO_145_ESC_LED_ERR);
        GPIO_setQualificationMode(145,GPIO_QUAL_ASYNC);
        GPIO_setPinConfig(GPIO_146_ESC_LED_RUN);
        GPIO_setQualificationMode(146,GPIO_QUAL_ASYNC);
        #endif
        // Initialize PIE and clear PIE registers. Disables CPU interrupts.
        Interrupt_initModule();
        // Initialize the PIE vector table with pointers to the shell Interrupt
        // Service Routines (ISR).
        Interrupt_initVectorTable();
        // Register EtherCAT Interrupt Handlers
        Interrupt_register(INT_ECAT, &ESC_applicationLayerHandler);
        Interrupt_register(INT_ECATSYNC0, &ESC_applicationSync0Handler);
        Interrupt_register(INT_ECATSYNC1, &ESC_applicationSync1Handler);
        // Enable ECAT/PDI, Sync0, and Sync1 interrupts in CPU
        Interrupt_enable(INT_ECAT);
        Interrupt_enable(INT_ECATSYNC0);
        Interrupt_enable(INT_ECATSYNC1);
        // Configure and Start timer
        CPUTimer_setPreScaler(CPUTIMER0_BASE, 0U);
        CPUTimer_startTimer(CPUTIMER0_BASE);
    #ifdef PDI_HAL_TEST
        // Enable Pass, fail signals
        ESC_passFailSignalSetup();
        // Sys PLL = 200MHz and use /2 to get 100MHz for ECAT IP
        // (There is a built in /4 to get 25MHz for PHY when using
        //  internal clocking for PHY)
        SysCtl_setECatClk(SYSCTL_ECATCLKOUT_DIV_2, SYSCTL_SOURCE_SYSPLL,
                          ESC_DISABLE_INT_PHY_CLK);
        // Configure EEPROM Size for 16K bits or less
    //    ESCSS_configureEEPROMSize(ESC_SS_CONFIG_BASE, ESCSS_GREATER_THAN_16K);
        ESCSS_configureEEPROMSize(ESC_SS_CONFIG_BASE, ESCSS_LESS_THAN_16K);
        // Reset ESC
        ESC_resetESC();
    #ifdef PDI_HAL_TEST
        // Enable the debug access
        while((HWREGH(ESC_SS_BASE + ESCSS_O_ACCESS_CTRL) &
               ESCSS_ACCESS_CTRL_ENABLE_DEBUG_ACCESS) !=
            ESCSS_enableDebugAccess(ESC_SS_BASE);
        // Wait (with time out) for EEPROM to be loaded
        while(ESC_loadedCheckEEPROM() != ESC_EEPROM_SUCCESS)
            eepromTimeOut--;
            // On time out, return fail
            if(eepromTimeOut == 0U)
                return(ESC_HW_INIT_FAIL);
        // Initialize ESCSS Memory
        ESCSS_initMemory(ESC_SS_BASE);
        // Wait for ESCSS memory initialization to complete
        if(ESCSS_getMemoryInitDoneStatusBlocking(ESC_SS_BASE, memoryTimeOut) !=
           ESCSS_API_SUCCESS)
        ESTOP0;
        // Read PHY registers...
        enable_PDI_access_to_MII();
        ESTOP0;
        mii_writePhyRegister(0x19, 0x00 , 0x8020);
        mii_writePhyRegister(0x18, 0x00 , 0x0080);
        mii_writePhyExtendedRegister(0x460, 0x00, 0x0005);  //CHANGE LED1 LED2 function to LINK
        mii_writePhyExtendedRegister(0x469, 0x00, 0x0004);  // FLIPPED POLARITY OF LEDs
        mii_writePhyExtendedRegister(0x304, 0x00, 0x0008);
        mii_writePhyRegister(0x04, 0x00, 0x01E1);
        mii_writePhyRegister(0x09, 0x00, 0x0020);
        mii_writePhyRegister(0x00, 0x00, 0x3300);
        mii_writePhyRegister(0x0B, 0x00, 0x0008);
        mii_writePhyRegister(0x17, 0x00, 0x49);
        mii_writePhyRegister(0xA, 0x00, 0x102);
        mii_writePhyRegister(0x1F, 0x00, 0x4000);
        uint16_t index;
        // Read first 32 PHY registers (non-extended)
        for (index = 0; index < 32; ++index)
            phy_regs_0[index] = mii_readPhyRegister(index, 0x00);
        // Read extended PHY registers
        ext_phy_regs_0[0] = mii_readPhyExtendedRegister(0x25,0x00);
        ext_phy_regs_0[1] = mii_readPhyExtendedRegister(0x27,0x00);
        ext_phy_regs_0[2] = mii_readPhyExtendedRegister(0x2A,0x00);
        ext_phy_regs_0[3] = mii_readPhyExtendedRegister(0x117,0x00);
        ext_phy_regs_0[4] = mii_readPhyExtendedRegister(0x131,0x00);
        ext_phy_regs_0[5] = mii_readPhyExtendedRegister(0x170,0x00);
        ext_phy_regs_0[6] = mii_readPhyExtendedRegister(0x171,0x00);
        ext_phy_regs_0[7] = mii_readPhyExtendedRegister(0x173,0x00);
        ext_phy_regs_0[8] = mii_readPhyExtendedRegister(0x175,0x00);
        ext_phy_regs_0[9] = mii_readPhyExtendedRegister(0x176,0x00);
        ext_phy_regs_0[10] = mii_readPhyExtendedRegister(0x177,0x00);
        ext_phy_regs_0[11] = mii_readPhyExtendedRegister(0x178,0x00);
        ext_phy_regs_0[12] = mii_readPhyExtendedRegister(0x180,0x00);
        ext_phy_regs_0[13] = mii_readPhyExtendedRegister(0x181,0x00);
        ext_phy_regs_0[14] = mii_readPhyExtendedRegister(0x182,0x00);
        ext_phy_regs_0[15] = mii_readPhyExtendedRegister(0x183,0x00);
        ext_phy_regs_0[16] = mii_readPhyExtendedRegister(0x184,0x00);
        ext_phy_regs_0[17] = mii_readPhyExtendedRegister(0x185,0x00);
        ext_phy_regs_0[18] = mii_readPhyExtendedRegister(0x186,0x00);
        ext_phy_regs_0[19] = mii_readPhyExtendedRegister(0x187,0x00);
        ext_phy_regs_0[20] = mii_readPhyExtendedRegister(0x188,0x00);
        ext_phy_regs_0[21] = mii_readPhyExtendedRegister(0x189,0x00);
        ext_phy_regs_0[22] = mii_readPhyExtendedRegister(0x18A,0x00);
        ext_phy_regs_0[23] = mii_readPhyExtendedRegister(0x302,0x00);
        ext_phy_regs_0[24] = mii_readPhyExtendedRegister(0x303,0x00);
        ext_phy_regs_0[25] = mii_readPhyExtendedRegister(0x304,0x00);
        ext_phy_regs_0[26] = mii_readPhyExtendedRegister(0x305,0x00);
        ext_phy_regs_0[27] = mii_readPhyExtendedRegister(0x306,0x00);
        ext_phy_regs_0[28] = mii_readPhyExtendedRegister(0x308,0x00);
        ext_phy_regs_0[29] = mii_readPhyExtendedRegister(0x30B,0x00);
        ext_phy_regs_0[30] = mii_readPhyExtendedRegister(0x30C,0x00);
        ext_phy_regs_0[31] = mii_readPhyExtendedRegister(0x30E,0x00);
        ext_phy_regs_0[32] = mii_readPhyExtendedRegister(0x404,0x00);
        ext_phy_regs_0[33] = mii_readPhyExtendedRegister(0x40D,0x00);
        ext_phy_regs_0[34] = mii_readPhyExtendedRegister(0x456,0x00);
        ext_phy_regs_0[35] = mii_readPhyExtendedRegister(0x460,0x00);
        ext_phy_regs_0[36] = mii_readPhyExtendedRegister(0x461,0x00);
        ext_phy_regs_0[37] = mii_readPhyExtendedRegister(0x467,0x00);
        ext_phy_regs_0[38] = mii_readPhyExtendedRegister(0x468,0x00);
        ext_phy_regs_0[39] = mii_readPhyExtendedRegister(0x469,0x00);
        ext_phy_regs_0[40] = mii_readPhyExtendedRegister(0x4A0,0x00);
        ext_phy_regs_0[41] = mii_readPhyExtendedRegister(0x4A1,0x00);
        ext_phy_regs_0[42] = mii_readPhyExtendedRegister(0x4A2,0x00);
        ext_phy_regs_0[43] = mii_readPhyExtendedRegister(0x4A3,0x00);
        ext_phy_regs_0[44] = mii_readPhyExtendedRegister(0x4A4,0x00);
        ext_phy_regs_0[45] = mii_readPhyExtendedRegister(0x4A5,0x00);
        ext_phy_regs_0[46] = mii_readPhyExtendedRegister(0x4A6,0x00);
        ext_phy_regs_0[47] = mii_readPhyExtendedRegister(0x4A7,0x00);
        //ESTOP0;
        // Set PHY Address to Port1
        uint16_t ESC_PHY_addr_reg_value;
        ESC_PHY_addr_reg_value =  ESC_readWordISR(ESC_PHY_ADDRESS_OFFSET);
    //    ESTOP0;
        ESC_writeWordISR(0x01, ESC_PHY_ADDRESS_OFFSET);
    //    ESTOP0;
    //    ESTOP0;
        mii_writePhyRegister(0x19, 0x01 , 0x8020);
        mii_writePhyRegister(0x18, 0x01 , 0x0080);
        mii_writePhyExtendedRegister(0x460, 0x01, 0x0005);  //CHANGE LED1 LED2 function to LINK
        mii_writePhyExtendedRegister(0x469, 0x01, 0x0004);  // FLIPPED POLARITY OF LEDs
        mii_writePhyExtendedRegister(0x304, 0x01, 0x0008);
        mii_writePhyRegister(0x04, 0x01, 0x01E1);
        mii_writePhyRegister(0x09, 0x01, 0x0020);
        mii_writePhyRegister(0x00, 0x01, 0x3300);
        mii_writePhyRegister(0x0B, 0x01, 0x0008);
        mii_writePhyRegister(0x17, 0x01, 0x49);
        mii_writePhyRegister(0xA, 0x01, 0x102);
        mii_writePhyRegister(0x1F, 0x01, 0x4000);
        //ESTOP0;
            phy_regs_1[index] = mii_readPhyRegister(index, 0x01);
        //ESTOP0;
        ext_phy_regs_1[0] = mii_readPhyExtendedRegister(0x25, 0x01);
        ext_phy_regs_1[1] = mii_readPhyExtendedRegister(0x27, 0x01);
        ext_phy_regs_1[2] = mii_readPhyExtendedRegister(0x2A, 0x01);
        ext_phy_regs_1[3] = mii_readPhyExtendedRegister(0x117, 0x01);
        ext_phy_regs_1[4] = mii_readPhyExtendedRegister(0x131, 0x01);
        ext_phy_regs_1[5] = mii_readPhyExtendedRegister(0x170, 0x01);
        ext_phy_regs_1[6] = mii_readPhyExtendedRegister(0x171, 0x01);
        ext_phy_regs_1[7] = mii_readPhyExtendedRegister(0x173, 0x01);
        ext_phy_regs_1[8] = mii_readPhyExtendedRegister(0x175, 0x01);
        ext_phy_regs_1[9] = mii_readPhyExtendedRegister(0x176, 0x01);
        ext_phy_regs_1[10] = mii_readPhyExtendedRegister(0x177, 0x01);
        ext_phy_regs_1[11] = mii_readPhyExtendedRegister(0x178, 0x01);
        ext_phy_regs_1[12] = mii_readPhyExtendedRegister(0x180, 0x01);
        ext_phy_regs_1[13] = mii_readPhyExtendedRegister(0x181, 0x01);
        ext_phy_regs_1[14] = mii_readPhyExtendedRegister(0x182, 0x01);
        ext_phy_regs_1[15] = mii_readPhyExtendedRegister(0x183, 0x01);
        ext_phy_regs_1[16] = mii_readPhyExtendedRegister(0x184, 0x01);
        ext_phy_regs_1[17] = mii_readPhyExtendedRegister(0x185, 0x01);
        ext_phy_regs_1[18] = mii_readPhyExtendedRegister(0x186, 0x01);
        ext_phy_regs_1[19] = mii_readPhyExtendedRegister(0x187, 0x01);
        ext_phy_regs_1[20] = mii_readPhyExtendedRegister(0x188, 0x01);
        ext_phy_regs_1[21] = mii_readPhyExtendedRegister(0x189, 0x01);
        ext_phy_regs_1[22] = mii_readPhyExtendedRegister(0x18A, 0x01);
        ext_phy_regs_1[23] = mii_readPhyExtendedRegister(0x302, 0x01);
        ext_phy_regs_1[24] = mii_readPhyExtendedRegister(0x303, 0x01);
        ext_phy_regs_1[25] = mii_readPhyExtendedRegister(0x304, 0x01);
        ext_phy_regs_1[26] = mii_readPhyExtendedRegister(0x305, 0x01);
        ext_phy_regs_1[27] = mii_readPhyExtendedRegister(0x306, 0x01);
        ext_phy_regs_1[28] = mii_readPhyExtendedRegister(0x308, 0x01);
        ext_phy_regs_1[29] = mii_readPhyExtendedRegister(0x30B, 0x01);
        ext_phy_regs_1[30] = mii_readPhyExtendedRegister(0x30C, 0x01);
        ext_phy_regs_1[31] = mii_readPhyExtendedRegister(0x30E, 0x01);
        ext_phy_regs_1[32] = mii_readPhyExtendedRegister(0x404, 0x01);
        ext_phy_regs_1[33] = mii_readPhyExtendedRegister(0x40D, 0x01);
        ext_phy_regs_1[34] = mii_readPhyExtendedRegister(0x456, 0x01);
        ext_phy_regs_1[35] = mii_readPhyExtendedRegister(0x460, 0x01);
        ext_phy_regs_1[36] = mii_readPhyExtendedRegister(0x461, 0x01);
        ext_phy_regs_1[37] = mii_readPhyExtendedRegister(0x467, 0x01);
        ext_phy_regs_1[38] = mii_readPhyExtendedRegister(0x468, 0x01);
        ext_phy_regs_1[39] = mii_readPhyExtendedRegister(0x469, 0x01);
        ext_phy_regs_1[40] = mii_readPhyExtendedRegister(0x4A0, 0x01);
        ext_phy_regs_1[41] = mii_readPhyExtendedRegister(0x4A1, 0x01);
        ext_phy_regs_1[42] = mii_readPhyExtendedRegister(0x4A2, 0x01);
        ext_phy_regs_1[43] = mii_readPhyExtendedRegister(0x4A3, 0x01);
        ext_phy_regs_1[44] = mii_readPhyExtendedRegister(0x4A4, 0x01);
        ext_phy_regs_1[45] = mii_readPhyExtendedRegister(0x4A5, 0x01);
        ext_phy_regs_1[46] = mii_readPhyExtendedRegister(0x4A6, 0x01);
        ext_phy_regs_1[47] = mii_readPhyExtendedRegister(0x4A7, 0x01);
        //ESTOP0;
        //ESTOP0;
        ESTOP0;
        // Initialize AL Event Mask to zero to prevent ESC interrupts until
        // set during stack state transition to SAFEOP
        ESC_writeDWord(0UL, ESC_O_AL_EVENTMASK);
        // Enable ECAT/PDI, Sync0, and Sync1 interrupts in ESCSS
        ESCSS_setMaskedInterruptStatus(ESC_SS_BASE,
                                       (ESCSS_INTR_MASK_IRQ_MASK |
                                        ESCSS_INTR_MASK_SYNC0_MASK |
                                        ESCSS_INTR_MASK_SYNC1_MASK));
        // Connect ESCSS Sync0/1 signals to respective interrupts in PIE
        ESCSS_configureSync0Connections(ESC_SS_BASE, ESCSS_SYNC0_CONFIG_C28X_PIE_EN,
                                        ESCSS_VALID_KEY_VALUE);
        ESCSS_configureSync1Connections(ESC_SS_BASE, ESCSS_SYNC1_CONFIG_C28X_PIE_EN,
        // Enable interrupts to CPU
        EINT;
        return(ESC_HW_INIT_SUCCESS);
    // ESC_releaseHW
    void
    ESC_releaseHW(void)
        // Intentionally empty - Implementation is left to the end user
    // ESC_applicationLayerHandler
    __interrupt void
    ESC_applicationLayerHandler(void)
    #ifdef ETHERCAT_STACK
    #if AL_EVENT_ENABLED
        // When stack is included and application event enabled, call stack PDI ISR
        PDI_Isr();
    #endif  // AL_EVENT_ENABLED
    #endif  // ETHERCAT_STACK
        // Acknowledge and clear interrupt in ESCSS
        ESCSS_clearRawInterruptStatus(ESC_SS_BASE, ESCSS_INTR_CLR_IRQ_CLR);
        // Acknowledge this interrupt located in PIE group 1
        Interrupt_clearACKGroup(INTERRUPT_ACK_GROUP1);
    // ESC_applicationSync0Handler
    __interrupt void
    ESC_applicationSync0Handler(void)
    #if DC_SUPPORTED
        // When stack is included and DC is enabled, call stack Sync0 ISR
        Sync0_Isr();
    #endif  // DC_SUPPORTED
        ESCSS_clearRawInterruptStatus(ESC_SS_BASE, ESCSS_INTR_CLR_SYNC0_CLR);
    // ESC_applicationSync1Handler
    __interrupt void
    ESC_applicationSync1Handler(void)
    #if DC_SUPPORTED
        // When stack is included and DC is enabled, call stack Sync1 ISR
        Sync1_Isr();
        ESCSS_clearRawInterruptStatus(ESC_SS_BASE, ESCSS_INTR_CLR_SYNC1_CLR);
        // Acknowledge this interrupt located in PIE group 5
        Interrupt_clearACKGroup(INTERRUPT_ACK_GROUP5);
    // End of File
    program_i2c_ESC_eeprom_F28P65x.zip
    The instructions for the fix are in the LAUNCHXL-F28P65X_REVA_workaround.pdf document that is attached to this response. The referenced files are also attached to this response.
