Part Number: TMS320F280025C
Hi, Gurus:
As F280025C TRM p.1474 shows about the analog subsystem block diagram, there is a dot on Gx_ADCA and CPMSSx Input Mux.
Is these two module, ADC and CPMSS can work at same time and same pin?
For example I use A6 to measure voltage and also set CMPSS1 HP for voltage compare application?
Will this setup cause any ADC performance issue?
Thanks!
