Part Number: TMS320F28388D
Hello
I plan to run a 16-Point FFT implementation for the CLA on TMS320F28388D. Has anyone implemented a 16-Point FFT for CLA?
-Mohamed
Hello
-Mohamed
Hi Mohamed,
We have lookup tables and examples for 256, 512, and 1024-point FFT's for CLA. These are located in [C2000ware install]\libraries\math\CLAmath\c28\examples. I would suggest using these as a starting point.
Delaney
Hi Delaney,
Thanks for your prompt reply. In my application I can only afford to acquire 16 data points within the time allotted for acquisition and FFT magnitude and phase calculation before updating the control loop. The signals I am acquiring are sinusoidal. I don't think I can use any of the 8, 9 or 10 stage FFT's. Do you have other suggestions for me?
-Mohamed
Hi Mohamed,
I will get back to you with a response to this query tomorrow.
Delaney
Hi Mohamed,
Sorry for the delay. My suggestion would be to take a look at the pictured asm files in the [C2000ware install]\libraries\math\CLAmath\c28\source folder to see how the example FFT's use the ROM lookup table (contained in cla_fft_tables.asm in the same folder) for the different 8, 9 and 10 stage FFT's. These files have detailed comments explaining the algorithm used. You can potentially modify these files to be used for the 4-stage FFT case. You should be able to change the calculated values of the defines in the "FFT Routine defines". I would recommend looking through the whole asm file though to see if any other modifications need to be made.
Delaney
Hi Delaney,
Thanks for your suggestion. I will study the asm files.
-Mohamed
