TMS320F28379D: Flash API and watchdog
Part Number: TMS320F28379D
I've modified the flash_programming_dcsm_cpu example (see attached) to have an additional Fapi_issueProgrammingCommand() call, then ServiceDog(), then another Fapi_issueProgrammingCommand().
    BufAddr[0] = 0x2;
    BufAddr[1] = 0x2;
    BufAddr[2] = 0x2;
    BufAddr[3] = 0x2;
    BufAddr[4] = 0x2;
    BufAddr[5] = 0x2;
    BufAddr[6] = 0x2;
    BufAddr[7] = 0x2;
    oReturnCheck = Fapi_issueProgrammingCommand((Uint32 *)0x82000,
                                                BufAddr,
                                                8,
                                                0,
                                                0,
                                                Fapi_DataOnly);
    if(oReturnCheck != Fapi_Status_Success)
        Example_Error(oReturnCheck);
    /* pet the watchdog */
    ServiceDog();
    BufAddr[0] = 0x3;
    BufAddr[1] = 0x3;
    BufAddr[2] = 0x3;
    BufAddr[3] = 0x3;
    BufAddr[4] = 0x3;
    BufAddr[5] = 0x3;
    BufAddr[6] = 0x3;
    BufAddr[7] = 0x3;
                                                BufAddr,
                                                8,
                                                0,
                                                0,
                                                Fapi_DataOnly);
By stepping thru the debugger and examining the Memory Browser I can see that the first Fapi_issueProgrammingCommand() (line 457) updates the specified locations in memory.
But the 2nd Fapi_issueProgrammingCommand() (line 482) also returns "Fapi_Status_Success" but the memory locations still contain the values from line 457.
What API call do I need to make after servicing the watchdog?  I tried re-initializing the API with "Fapi_initializeAPI()", but this didn't help.
Thank you
// FILE:   flash_programming_dcsm_cpu01.c
// TITLE:  Flash Programming with DCSM.
//! \addtogroup cpu01_example_list
//! <h1> Flash Programming with DCSM </h1>
//! This example programs secure memory
// $Release Date:  $
// $Copyright:
// Copyright (C) 2013-2023 Texas Instruments Incorporated - http://www.ti.com/
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
//   Redistributions of source code must retain the above copyright
//   notice, this list of conditions and the following disclaimer.
//   Redistributions in binary form must reproduce the above copyright
//   notice, this list of conditions and the following disclaimer in the
//   documentation and/or other materials provided with the
//   distribution.
//   Neither the name of Texas Instruments Incorporated nor the names of
//   its contributors may be used to endorse or promote products derived
//   from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "F28x_Project.h"
#include <string.h>
#include "flash_programming_dcsm_c28.h"
#include "F021_F2837xD_C28x.h"
// Defines
#define  WORDS_IN_FLASH_BUFFER    0xFF
#ifdef __TI_COMPILER_VERSION__
    #if __TI_COMPILER_VERSION__ >= 15009000
        #define ramFuncSection ".TI.ramfunc"
    #else
        #define ramFuncSection "ramfuncs"
    #endif
#endif
// Globals
#pragma DATA_SECTION(Buffer,"BufferDataSection");
uint16   Buffer[WORDS_IN_FLASH_BUFFER + 1];
uint32   *Buffer32 = (uint32 *)Buffer;
// Function Prototypes
void Example_Error(Fapi_StatusType status);
void Example_Done(void);
void Example_CallFlashAPI(void);
// Main
void main(void)
    // Initialize System Control. Enable Peripheral Clocks.
    InitSysCtrl();
    // Disable CPU interrupts.
    DINT;
    // Initialize PIE control registers to default state.
    InitPieCtrl();
    // Disable CPU interrupts and clear all CPU interrupt flags.
    IER = 0x0000;
    IFR = 0x0000;
    // Initialize PIE vector table with pointers to the default
    // Interrupt Service Routines (ISR).
    InitPieVectTable();
    // Call the Flash API functions for this example.
    Example_CallFlashAPI();
// Example_CallFlashAPI - This function will interface to the flash API.
//                        Flash API functions used in this function are
//                        executed from RAM.
#pragma CODE_SECTION(Example_CallFlashAPI, ramFuncSection);
    uint32 u32Index = 0UL;
    uint16 i = 0U;
    Fapi_StatusType oReturnCheck;
    volatile Fapi_FlashStatusType oFlashStatus;
    Fapi_FlashStatusWordType oFlashStatusWord;
    Uint16 BufAddr[8];
    // Grab flash semaphore for Zone1 to enable access to flash registers.
    EALLOW;
    DcsmCommonRegs.FLSEM.all = 0xA501;
    EDIS;
    // Call flash initialization to setup flash waitstates.
    // This function must reside in RAM.
    InitFlash();
    // Disable ECC.
    EALLOW;
    Flash0EccRegs.ECC_ENABLE.bit.ENABLE = 0x0;
    // This function is required to initialize the Flash API based on system
    // frequency before any other Flash API operation can be performed.
    oReturnCheck = Fapi_initializeAPI(F021_CPU0_BASE_ADDRESS, 120);
        // Check Flash API documentation for possible errors.
    // Fapi_setActiveFlashBank function sets the flash bank and FMC for further
    // flash operations to be performed on the bank.
    oReturnCheck = Fapi_setActiveFlashBank(Fapi_FlashBank0);
    // Erase Sector C.
    oReturnCheck = Fapi_issueAsyncCommandWithAddress(Fapi_EraseSector,
                   (uint32 *)Bzero_SectorC_start);
    // Wait until FSM is done with erase sector operation.
    while (Fapi_checkFsmForReady() != Fapi_Status_FsmReady)
    // Verify that Sector C is erased. The erase step itself does verification
    // as it goes. This verify is a second verification that can be done.
    oReturnCheck = Fapi_doBlankCheck((uint32 *)Bzero_SectorC_start,
                   Bzero_16KSector_u32length,
                   &oFlashStatusWord);
        // If erase command fails, use Fapi_getFsmStatus() function to get the
        // FMSTAT register contents to see if any of the EV bit, ESUSP bit,
        // CSTAT bit or VOLTSTAT bit is set. Refer to API documentation for
        // more details.
    // Erase Sector B.
                   (uint32 *)Bzero_SectorB_start);
    // Verify that Sector B is erased. The erase step itself does verification
    oReturnCheck = Fapi_doBlankCheck((uint32 *)Bzero_SectorB_start,
                   &oFlashStatusWord);
        // more details.
    // A data buffer of max 8 words can be supplied to the program function.
    // Each word is programmed until the whole buffer is programmed or a
    // problem is found. However, to program a buffer that has more than 8
    // words, program function can be called in a loop to program 8 words for
    // each loop iteration until the whole buffer is programmed.
    // For example, program 0xFF bytes in flash Sector C along with auto-
    // generated ECC.
    // For example fill a buffer with data to program into the flash.
    for(i=0;i<=WORDS_IN_FLASH_BUFFER;i++)
        Buffer[i] = i;
    // Program buffer into Sector C with ECC.
    for(i=0, u32Index = Bzero_SectorC_start;
       (u32Index < (Bzero_SectorC_start + WORDS_IN_FLASH_BUFFER))
       && (oReturnCheck == Fapi_Status_Success); i+= 8, u32Index+= 8)
        oReturnCheck = Fapi_issueProgrammingCommand((uint32 *)u32Index,Buffer+i,
                       8,
                       0,
                       0,
                       Fapi_AutoEccGeneration);
        // Wait until FSM is done with program operation.
        while(Fapi_checkFsmForReady() == Fapi_Status_FsmBusy)
        // Read FMSTAT register contents to know the status of FSM after
        // program command for any debug.
        oFlashStatus = Fapi_getFsmStatus();
        // Verify the values programmed. The program step itself does
        // verification as it goes. This verify is a second verification that
        // can be done.
        oReturnCheck = Fapi_doVerify((uint32 *)u32Index,
                       4,
                       Buffer32+(i/2),
                       &oFlashStatusWord);
    // Program buffer into Sector B with out ECC.
    // Disable ECC so that an error is not generated when reading flash contents
    // without ECC programmed.
    for(i=0, u32Index = Bzero_SectorB_start;
       (u32Index < (Bzero_SectorB_start + WORDS_IN_FLASH_BUFFER))
                       Buffer+i,
                       8,
                       0,
                       0,
                       Fapi_DataOnly);
        // after program command for any debug.
        // can be done.
                       4,
                       Buffer32+(i/2),
                       &oFlashStatusWord);
    // Erase the sectors that we have programmed above.
    // Erase Sector C.
                   &oFlashStatusWord);
        // more details.
    // Erase Sector B.
                   &oFlashStatusWord);
        // more details.
    BufAddr[0] = 0x2;
    BufAddr[1] = 0x2;
    BufAddr[2] = 0x2;
    BufAddr[3] = 0x2;
    BufAddr[4] = 0x2;
    BufAddr[5] = 0x2;
    BufAddr[6] = 0x2;
    BufAddr[7] = 0x2;
                                                BufAddr,
                                                8,
                                                0,
                                                0,
                                                Fapi_DataOnly);
    ServiceDog();
    BufAddr[0] = 0x3;
    BufAddr[1] = 0x3;
    BufAddr[2] = 0x3;
    BufAddr[3] = 0x3;
    BufAddr[4] = 0x3;
    BufAddr[5] = 0x3;
    BufAddr[6] = 0x3;
    BufAddr[7] = 0x3;
                                                BufAddr,
                                                8,
                                                0,
                                                0,
                                                Fapi_DataOnly);
    // Enable ECC.
    Flash0EccRegs.ECC_ENABLE.bit.ENABLE = 0xA;
    // Release flash semaphore.
    DcsmCommonRegs.FLSEM.all = 0xA500;
    EDIS;
    // Example is done here.
    Example_Done();
// Example_Error - For this example, if an error is found just stop here
#pragma CODE_SECTION(Example_Error,ramFuncSection);
    // Error code will be in the status parameter.
    // ESTOP0.
    __asm("    ESTOP0");
// Example_Done - For this example, once we are done just stop here
    // ESTOP0.
    __asm("    ESTOP0");
    for(;;)
// End of file
  • Hi Diane,
    You might be missing EALLOW; after the watchdog service.  Please check.
    Thanks and regards,
    Vamsi
  • Vamsi,
    I added EALLOW after ServiceDog(), but I got the same results:
                                                    BufAddr,
                                                    8,
                                                    0,
                                                    0,
                                                    Fapi_DataOnly);
        ServiceDog();
        EALLOW;
        BufAddr[0] = 0x3;
        BufAddr[1] = 0x3;
        BufAddr[2] = 0x3;
        BufAddr[3] = 0x3;
        BufAddr[4] = 0x3;
        BufAddr[5] = 0x3;
        BufAddr[6] = 0x3;
        BufAddr[7] = 0x3;
                                                    BufAddr,
                                                    8,
                                                    0,
                                                    0,
                                                    Fapi_DataOnly);
    Thank you,
    Diane
    // $Release Date:  $
    // $Copyright:
    // are met:
    //   distribution.
    #include <string.h>
    // Defines
        #else
        #endif
    #endif
    // Globals
    // Main
    void main(void)
        InitSysCtrl();
        DINT;
        InitPieCtrl();
        IER = 0x0000;
        IFR = 0x0000;
        InitPieVectTable();
        uint16 i = 0U;
        Uint16 BufAddr[8];
        EALLOW;
        EDIS;
        InitFlash();
        // Disable ECC.
        EALLOW;
        // Erase Sector C.
                       &oFlashStatusWord);
            // more details.
        // Erase Sector B.
                       &oFlashStatusWord);
            // more details.
        // generated ECC.
            Buffer[i] = i;
                           8,
                           0,
                           0,
            // can be done.
                           4,
                           Buffer32+(i/2),
                           &oFlashStatusWord);
                           Buffer+i,
                           8,
                           0,
                           0,
                           Fapi_DataOnly);
            // can be done.
                           4,
                           Buffer32+(i/2),
                           &oFlashStatusWord);
        // Erase Sector C.
                       &oFlashStatusWord);
            // more details.
        // Erase Sector B.
                       &oFlashStatusWord);
            // more details.
        BufAddr[0] = 0x2;
        BufAddr[1] = 0x2;
        BufAddr[2] = 0x2;
        BufAddr[3] = 0x2;
        BufAddr[4] = 0x2;
        BufAddr[5] = 0x2;
        BufAddr[6] = 0x2;
        BufAddr[7] = 0x2;
                                                    BufAddr,
                                                    8,
                                                    0,
                                                    0,
                                                    Fapi_DataOnly);
        ServiceDog();
        EALLOW;
        BufAddr[0] = 0x3;
        BufAddr[1] = 0x3;
        BufAddr[2] = 0x3;
        BufAddr[3] = 0x3;
        BufAddr[4] = 0x3;
        BufAddr[5] = 0x3;
        BufAddr[6] = 0x3;
        BufAddr[7] = 0x3;
                                                    BufAddr,
                                                    8,
                                                    0,
                                                    0,
                                                    Fapi_DataOnly);
        // Enable ECC.
        EDIS;
        Example_Done();
        // ESTOP0.
        __asm("    ESTOP0");
        // ESTOP0.
        __asm("    ESTOP0");
        for(;;)
    // End of file
  • Diane,
    I don't see below wait loop after the program command in your code.  This loop ensures that the given command is complete before proceeding to the next command.
    Thanks and regards,
    Vamsi
  • Vamsi, thank for your help with this.
    I added the suggested while loops, but I still get the same behavior (I'm manually stepping thru the debugger, so I'm guessing by chance that was slow enough to allow the program steps to complete):
        BufAddr[0] = 0x2;
        BufAddr[1] = 0x2;
        BufAddr[2] = 0x2;
        BufAddr[3] = 0x2;
        BufAddr[4] = 0x2;
        BufAddr[5] = 0x2;
        BufAddr[6] = 0x2;
        BufAddr[7] = 0x2;
                                                    BufAddr,
                                                    8,
                                                    0,
                                                    0,
                                                    Fapi_DataOnly);
        ServiceDog();
        EALLOW;
        BufAddr[0] = 0x3;
        BufAddr[1] = 0x3;
        BufAddr[2] = 0x3;
        BufAddr[3] = 0x3;
        BufAddr[4] = 0x3;
        BufAddr[5] = 0x3;
        BufAddr[6] = 0x3;
        BufAddr[7] = 0x3;
                                                    BufAddr,
                                                    8,
                                                    0,
                                                    0,
                                                    Fapi_DataOnly);
    // $Release Date:  $
    // $Copyright:
    // are met:
    //   distribution.
    #include <string.h>
    // Defines
        #else
        #endif
    #endif
    // Globals
    // Main
    void main(void)
        InitSysCtrl();
        DINT;
        InitPieCtrl();
        IER = 0x0000;
        IFR = 0x0000;
        InitPieVectTable();
        uint16 i = 0U;
        Uint16 BufAddr[8];
        EALLOW;
        EDIS;
        InitFlash();
        // Disable ECC.
        EALLOW;
        // Erase Sector C.
                       &oFlashStatusWord);
            // more details.
        // Erase Sector B.
                       &oFlashStatusWord);
            // more details.
        // generated ECC.
            Buffer[i] = i;
                           8,
                           0,
                           0,
            // can be done.
                           4,
                           Buffer32+(i/2),
                           &oFlashStatusWord);
                           Buffer+i,
                           8,
                           0,
                           0,
                           Fapi_DataOnly);
            // can be done.
                           4,
                           Buffer32+(i/2),
                           &oFlashStatusWord);
        // Erase Sector C.
                       &oFlashStatusWord);
            // more details.
        // Erase Sector B.
                       &oFlashStatusWord);
            // more details.
        BufAddr[0] = 0x2;
        BufAddr[1] = 0x2;
        BufAddr[2] = 0x2;
        BufAddr[3] = 0x2;
        BufAddr[4] = 0x2;
        BufAddr[5] = 0x2;
        BufAddr[6] = 0x2;
        BufAddr[7] = 0x2;
                                                    BufAddr,
                                                    8,
                                                    0,
                                                    0,
                                                    Fapi_DataOnly);
        ServiceDog();
        EALLOW;
        BufAddr[0] = 0x3;
        BufAddr[1] = 0x3;
        BufAddr[2] = 0x3;
        BufAddr[3] = 0x3;
        BufAddr[4] = 0x3;
        BufAddr[5] = 0x3;
        BufAddr[6] = 0x3;
        BufAddr[7] = 0x3;
                                                    BufAddr,
                                                    8,
                                                    0,
                                                    0,
                                                    Fapi_DataOnly);
        // Enable ECC.
        EDIS;
        Example_Done();
        // ESTOP0.
        __asm("    ESTOP0");
        // ESTOP0.
        __asm("    ESTOP0");
        for(;;)
    // End of file
    Thank you,
    Diane
  • I don't think it's the watchdog that's causing the problem.
    If I make 2 sequential program commands to the same address, the 2nd set of values aren't stored:
        BufAddr[0] = 0x2;
        BufAddr[1] = 0x2;
        BufAddr[2] = 0x2;
        BufAddr[3] = 0x2;
        BufAddr[4] = 0x2;
        BufAddr[5] = 0x2;
        BufAddr[6] = 0x2;
        BufAddr[7] = 0x2;
                                                    BufAddr,
                                                    8,
                                                    0,
                                                    0,
                                                    Fapi_DataOnly);
    //    /* pet the watchdog */
    //    ServiceDog();
    //    EALLOW;
        BufAddr[0] = 0x3;
        BufAddr[1] = 0x3;
        BufAddr[2] = 0x3;
        BufAddr[3] = 0x3;
        BufAddr[4] = 0x3;
        BufAddr[5] = 0x3;
        BufAddr[6] = 0x3;
        BufAddr[7] = 0x3;
                                                    BufAddr,
                                                    8,
                                                    0,
                                                    0,
                                                    Fapi_DataOnly);
  • Hi Diane,
    0x2 --> 0x3 involves a bit change from 0 to 1.
    Using a program command, you can not change a 0 to 1.
    You need to issue erase command to change a bit from 0 to 1.
    Thanks and regards,
    Vamsi
  • Vamsi,
    I was trying to provide a simplified example of what I was doing, my writes are changing address and values every time.
    You were right, the problem was the missing EALLOW after the watchdog call.
    Thank you for your help.
    Diane
