Part Number: LAUNCHXL-F28379D
Other Parts Discussed in Thread: SYSCONFIG, C2000WARE
I want to use SysConfig to configure the I2C pheripheral. Normally, a I2C module has Open Drain Outputs/Floating Inputs.
When using SysConfig, there are pinmux qualification fields for SDA and SDL.
But the Open Drain and inverted pad are not allowed:
Does that mean that I need any transceiver ? Or is an open drain transistor automatically inserted between the digital output and the physical pad ?
Thank you for your help
