how to solve the problem
Other Parts Discussed in Thread: CONTROLSUITE
"..\HVACI_Sensorless.h", line 21: fatal error: could not open source file "aci_fe.h"
1 fatal error detected in the compilation of "../HVACI_Sensorless.c".
Compilation terminated.
>> Compilation failure
gmake: *** [HVACI_Sensorless.obj] Error 1
gmake: Target `all' not remade because of errors.
Build complete for project HVACI_Sensorless
  • Make sure you have the motor control library install
    Check the includes path and see what version of the motor lib is it using and if the same is present at
    controlSUITE\libs\app_libs\motor_control\math_blocks
    if not check controlsuite installer and install DMC Lib components,
    regards
    Manish BHardwaj
