TMS320F2800137: FLASH_Memory_Erase
Part Number: TMS320F2800137
Dear Sir,
if I erase flash memory then all function work correctly.
after that i have added any function or data or anything then run, unwanted result occurs.
like i have transmit packet after every 10 sec. but in that case it transmits continuously.
  • Babaji,
    I'm not really sure what your question is, I'm not sure what erasing the flash memory would have to do with other functions or where they are located in memory.
    Please give some more detail on this issue.
    Matthew
  • Dear Matthew,
    // $Copyright:
    // Copyright (C) 2017-2023 Texas Instruments Incorporated - http://www.ti.com/
    // Redistribution and use in source and binary forms, with or without
    // modification, are permitted provided that the following conditions
    // are met:
    //   Redistributions of source code must retain the above copyright
    //   notice, this list of conditions and the following disclaimer.
    //   Redistributions in binary form must reproduce the above copyright
    //   notice, this list of conditions and the following disclaimer in the
    //   documentation and/or other materials provided with the
    //   distribution.
    //   Neither the name of Texas Instruments Incorporated nor the names of
    //   its contributors may be used to endorse or promote products derived
    //   from this software without specific prior written permission.
    // THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
    // "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
    // LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    // A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
    // OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
    // SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
    // LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    // DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
    // THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    // (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
    // OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    //! \file   /solutions/tidm_02010_dmpfc/common/source/sys_main.c
    //! \brief  This project is used to control two motor and pfc with one MCU
    //!         Support for dualmtrpfc board with F28002x/F28003x/F280013x
    // include the related header files
    #if defined(SYSCONFIG_EN)
    #include "user.h"
    #include "board.h"
    #endif  // SYSCONFIG_EN
    #include "sys_settings.h"
    #include "sys_main.h"
    #include "systems.h"
    #include "math.h"
    #include "string.h"
    //Global
    unsigned int cpuTimer1IntCount=0;
    unsigned int cpuTimer2IntCount=0;
    unsigned int b=0;
    unsigned char compressor1motorFlag = false;
    static unsigned char ucRxBuff[10]={0};
    // Globals
    volatile bool rx_flag=0;
    volatile bool tx_flag=0;
    //extern volatile bool cx_flag;
    volatile uint8_t CompressorStartFlag=0;
    unsigned int uiRxByteCntr=0;
    char ucRxStatus = 'H';
    char ucRxStatus1;
    //unsigned int uiRxByteLen=4;
    unsigned int uiRxByteLenCntr=0;
    #define ODU_HEADER  '$'
    // Send data for SCI-A
    char sDataA[] = "RR120.50#";
    // Received data for SCI-A
    uint16_t rDataA[1];
    char rxflag=0;
    static unsigned char rx_data;
    static unsigned char rx_data_save;
    unsigned int uiTempValue = 0;
    //unsigned int uiTempValue1 = 0;
    // Used for checking the received data
    uint16_t rDataPointA;
    // Function Prototypes
    __interrupt void INT_SCI_COM_TX_ISR(void);
    __interrupt void INT_SCI_COM_RX_ISR(void);
    void initSCIAFIFO(void);
    void error(void);
    volatile SYSTEM_Vars_t systemVars;
    #pragma DATA_SECTION(systemVars,"user_data");
    #if defined(EPWMDAC_MODE)
    HAL_PWMDACData_t pwmDACData;
    #pragma DATA_SECTION(pwmDACData,"user_data");
    #endif  // EPWMDAC_MODE
    #if defined(DAC128S_ENABLE)
    #if defined(DAC80504_SEL)
    DAC80504_Handle  dac128sHandle;       //!< the DAC80504 interface handle
    DAC80504_Obj     dac128s;             //!< the DAC80504 interface object
    #else   // DAC128S805
    DAC128S_Handle   dac128sHandle;        //!< the DAC128S interface handle
    DAC128S_Obj      dac128s;              //!< the DAC128S interface object
    #endif  // DAC128S805
    #pragma DATA_SECTION(dac128sHandle,"sys_data");
    #pragma DATA_SECTION(dac128s,"sys_data");
    //#define DACTEST_EN
    #if defined(DACTEST_EN)
    float32_t dacTestValue[4];
    #pragma DATA_SECTION(dacTestValue,"sys_data");
    #endif  // DACTEST
    #endif  // DAC128S_ENABLE
    //------------------ADDED-09-02-2024------------------------------
    #define ADC_RESOLUTION_VALUE                (4096.0f) //(4896.0f) //(4096.0f)   //(400.0f)
    #define LOG_10_E                            (0.434294f)
    #define TEMP_T_25_K                         (298.15f)//kevin
    //air temperature
    #define TEMP_AIR_RES_T_25                   (10000.0f)//(10000U)//Ohm
    #define TEMP_AIR_BETA                       (3950.0f)
    #define TEMP_AIR_RES_GND                    (10000.0f)//Ohm
    volatile float fTempValue;
    unsigned int tempnewvalue1,tempnewvalue2,tempnewvalue3;
    //float32_t Temp_Sensor_Ambient,Temp_Sensor1,value,Temp_Sensor_coils,Temp_Sensor_Pipes;
    static float ntc_sensor_get_temp(float res, uint16_t res_25, uint16_t beta);
    __interrupt void INT_CPU_TIMER1_ISR(void);
    void configCPUTimer(uint32_t, float, float);
    // the functions
    //INT_MTR1_EMI_1_ISR
    void main(void)
        unsigned char *msg;
        ucRxStatus ='H';
          // Clear memory for system and controller
        // The variables must be assigned to these sector if need to be cleared to zero
        HAL_clearDataRAM((void *)loadStart_est_data, (uint16_t)loadSize_est_data);
        HAL_clearDataRAM((void *)loadStart_user_data, (uint16_t)loadSize_user_data);
        HAL_clearDataRAM((void *)loadStart_sys_data, (uint16_t)loadSize_sys_data);
        HAL_clearDataRAM((void *)loadStart_foc_data, (uint16_t)loadSize_foc_data);
        HAL_clearDataRAM((void *)loadStart_pfc_data, (uint16_t)loadSize_pfc_data);
        HAL_clearDataRAM((void *)loadStart_motor_data, (uint16_t)loadSize_motor_data);
        HAL_clearDataRAM((void *)loadStart_dmaBuf_data, (uint16_t)loadSize_dmaBuf_data);
        HAL_clearDataRAM((void *)loadStart_vibc_data, (uint16_t)loadSize_vibc_data);
        HAL_clearDataRAM((void *)loadStart_sfra_data, (uint16_t)loadSize_sfra_data);
        HAL_clearDataRAM((void *)loadStart_datalog_data, (uint16_t)loadSize_datalog_data);
        HAL_clearDataRAM((void *)loadStart_dbgc_data, (uint16_t)loadSize_dbgc_data);
        uint16_t* read_ADC_Value=(uint16_t*) 0x00000B40;
        uint16_t* read_ADC_Value1=(uint16_t*) 0x00000B41;
        uint16_t* read_ADC_Value2=(uint16_t*) 0x00000B42;
    //    AdcData1 = *read_ADC_Value;
    //    AdcData2 = *read_ADC_Value1;
    #if defined(DMCPFC_REV3P2)
        systemVars.boardKit = BOARD_DMCPFC_REV3P2;      // DMCPFC_REV3P1 for F28002x/3x/13x-64pin
    #elif defined(DMCPFC_REV3P1)
        systemVars.boardKit = BOARD_DMCPFC_REV3P1;      // DMCPFC_REV3P1 for F28002x-64pin
    #elif defined(HVMTRPFC_REV1P1)
        systemVars.boardKit = BOARD_HVMTRPFC_REV1P1;    // HVMTRPFC_REV1P1 for F28002x
    #elif defined(BSXL8323RH_REVB)
        systemVars.boardKit = BOARD_BSXL8323RH_REVB;    // BSXL8323RH_REVA for F28002x
    #else
    #error Not select a right board for this project
    #endif
    #if defined(MOTOR1_DISABLE) && defined(MOTOR2_DISABLE) && defined(PFC_DISABLE)
    #error Need to enable at least one function of PFC, MOTOR1, or MOTOR2
    #endif //
        systemVars.estType_M1 = EST_TYPE_NO_OBSERVER;   // this motor is disable
    #elif defined(MOTOR1_FAST) && defined(MOTOR1_ESMO)
        systemVars.estType_M1 = EST_TYPE_FAST_ESMO;    // the estimator is FAST and ESMO
        systemVars.estType_M1 = EST_TYPE_FAST;         // the estimator is only FAST
    #elif defined(MOTOR1_ESMO)
        systemVars.estType_M1 = EST_TYPE_ESMO;         // the estimator is only ESMO
    #else   // !MOTOR1_FAST & !MOTOR1_ESMO
    #error Not select a right estimator for motor 1 in this project
    #endif  // !MOTOR1_FAST & !MOTOR1_ESMO
    #if defined(MOTOR2_DISABLE)
        systemVars.estType_M2 = EST_TYPE_NO_OBSERVER;   // this motor is disable
    #elif defined(MOTOR2_FAST) && defined(MOTOR2_ESMO)
        systemVars.estType_M2 = EST_TYPE_FAST_ESMO;     // the estimator is FAST and ESMO
        systemVars.estType_M2 = EST_TYPE_FAST;          // the estimator is only FAST
    #elif defined(MOTOR2_ESMO)
        systemVars.estType_M2 = EST_TYPE_ESMO;          // the estimator is only ESMO
    #else   //  !MOTOR2_FAST & !MOTOR2_ESMO
    #error Not select a right estimator for motor 2 in this project
    #endif  //  !MOTOR2_FAST & !MOTOR2_ESMO
    #if defined(MOTOR1_FAST) && defined(MOTOR1_ESMO) && \
        defined(MOTOR2_FAST) && defined(MOTOR2_ESMO) && defined(_F28002x)
    #error Limit to the RAM size for copy the program to run in RAM. FAST and ESMO
        can not on dual motor at the same. Only support one motor runs FAST and ESMO
        in parallel, and another motor run FAST or ESMO.
    #endif  //  MOTOR1_FAST & MOTOR1_ESMO & MOTOR2_FAST & MOTOR2_ESMO
    #if defined(MOTOR1_DCLINKSS)
        systemVars.currentSenseType_M1 = CURSEN_TYPE_SINGLE_SHUNT;
    #else
        systemVars.currentSenseType_M1 = CURSEN_TYPE_THREE_SHUNT;
    #endif  // Current Sense Type of Motor 1
    #if defined(MOTOR2_DCLINKSS)
        systemVars.currentSenseType_M2 = CURSEN_TYPE_SINGLE_SHUNT;
    #else
        systemVars.currentSenseType_M2 = CURSEN_TYPE_THREE_SHUNT;
    #endif  // Current Sense Type of Motor 2
    // ** above codes are only for checking the settings, not occupy the memory
        // Initialize device clock and peripherals
        Device_init();                  // call the function in device.c
        // Disable pin locks and enable internal pullups.
        Device_initGPIO();              // call the function in device.c
        // GPIO28 is the SCI Rx pin.
           GPIO_setPinConfig(DEVICE_GPIO_CFG_SCIRXDC);
           GPIO_setDirectionMode(DEVICE_GPIO_PIN_SCIRXDC, GPIO_DIR_MODE_IN);
           GPIO_setPadConfig(DEVICE_GPIO_PIN_SCIRXDC, GPIO_PIN_TYPE_STD);
           GPIO_setQualificationMode(DEVICE_GPIO_PIN_SCIRXDC, GPIO_QUAL_ASYNC);
           // GPIO29 is the SCI Tx pin.
           GPIO_setPinConfig(DEVICE_GPIO_CFG_SCITXDC);
           GPIO_setDirectionMode(DEVICE_GPIO_PIN_SCITXDC, GPIO_DIR_MODE_OUT);
           GPIO_setPadConfig(DEVICE_GPIO_PIN_SCITXDC, GPIO_PIN_TYPE_STD);
           GPIO_setQualificationMode(DEVICE_GPIO_PIN_SCITXDC, GPIO_QUAL_ASYNC);
        // Initializes PIE and clears PIE registers. Disables CPU interrupts.
        Interrupt_initModule();         // call the function in driverlib.lib
        // Initializes the PIE vector table with pointers to the shell Interrupt
        // Service Routines (ISR).
        Interrupt_initVectorTable();    // call the function in driverlib.lib
        // Interrupts that are used in this example are re-mapped to
        // ISR functions found within this file.
        //07042024
        Interrupt_register(INT_SCIC_RX, INT_SCI_COM_RX_ISR);
        Interrupt_register(INT_SCIC_TX, INT_SCI_COM_TX_ISR);
        // Initialize the Device Peripherals:
        initSCIAFIFO();
       // SYS_TX_init();
        Interrupt_register(INT_TIMER1, INT_CPU_TIMER1_ISR);  //NEW ADD
    #if !defined(_SIMPLE_FAST_LIB)
        // false->enable motor identification, true->disable motor identification
        userParams[MTR_1].flag_bypassMotorId = true;
        userParams[MTR_2].flag_bypassMotorId = true;
    #endif  // !(_SIMPLE_FAST_LIB)
        // disable the ePWM module time base clock sync signal
        // to synchronize all of the PWMs
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_TBCLKSYNC);
        Board_init();
        //CPUTimer_enableInterrupt(CPU_TIMER1_BASE); //new add
        configCPUTimer(CPUTIMER1_BASE, DEVICE_SYSCLK_FREQ, 119047);// 5000000
        Interrupt_enable(INT_TIMER1);
        CPUTimer_startTimer(CPU_TIMER1_BASE); //new add
        // initialize the driver
        halHandle = HAL_init(&hal, sizeof(hal));
        // set the driver parameters
        HAL_setParams(halHandle);
        // set the control parameters for PFC
        initPFCCtrlParameters();
        // set the control parameters for motor 1
        initMotor1CtrlParameters();
        // set the control parameters for motor 2
        initMotor2CtrlParameters();
        // set the handle in hal for motors and pfc
        HAL_initMtrHandle(halHandle, halMtrHandle[MTR_1], halMtrHandle[MTR_2]);
        HAL_initPFCHandle(halHandle, halPFCHandle);
        // set PWM phase shift between motor and pfc
        HAL_setupPWMsPhaseShift(halHandle);
        // enable the ePWM module time base clock sync signal
        SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_TBCLKSYNC);
    //-----------------------------ADD Communication purpose 12032024-------------------
    //    for(i = 0; i < 2; i++)
    //            sDataA[i] = i;
            rDataPointA = sDataA[0];
    //        Interrupt_enable(INT_SCIA_RX);
    //        Interrupt_enable(INT_SCIA_TX);
    //        Interrupt_clearACKGroup(INTERRUPT_ACK_GROUP9);
    //-----------------------------------------end communication 12032024----------
    #else   // !SYSCONFIG_EN
        // initialize the interrupt vector table
        HAL_initIntVectorTable(halHandle);
        // enable the ADC/PWM interrupts for control
        // enable interrupts to trig DMA
        HAL_enableCtrlInts(halHandle);
    #endif  // !SYSCONFIG_EN
        motorVars[MTR_1].speedRef_Hz = 30.0f;
        motorVars[MTR_2].speedRef_Hz = 30.0f;
        systemVars.speedComp_Hz = 60.0f;
        systemVars.speedFan_Hz = 50.0f;
    #if !defined(HVMTRPFC_REV1P1)
    #error Only HVMTRPFC_REV1P1 supports the EPWMDAC function.
    #else   // HVMTRPFC_REV1P1
        // set DAC parameters
        pwmDACData.periodMax =
                PWMDAC_getPeriod(halHandle->pwmDACHandle[PWMDAC_NUMBER_1]);
    #if defined(PWMDAC_MOTOR) && defined(PWMDAC_PFC)
        pwmDACData.ptrData[0] = &adcDataPFC.IacBus;
        pwmDACData.ptrData[1] = &adcDataPFC.VacBus;
        pwmDACData.ptrData[2] = &angleFOCM1_rad;
        pwmDACData.ptrData[3] = &adcData[MTR_1].I_A.value[0];
        pwmDACData.offset[0] = 0.5f;
        pwmDACData.offset[1] = 0.5f;
        pwmDACData.offset[2] = 0.5f;
        pwmDACData.offset[3] = 0.5f;
        pwmDACData.gain[0] = 1.0f;
        pwmDACData.gain[1] = 1.0f;
        pwmDACData.gain[2] = 1.0f / MATH_TWO_PI;
        pwmDACData.gain[3] = 1.0f / USER_M1_ADC_FULL_SCALE_CURRENT_A;
    #elif defined(PWMDAC_MOTOR) && !defined(PWMDAC_PFC)
        pwmDACData.ptrData[0] = &angleESTM1_rad;
        pwmDACData.ptrData[1] = &adcData[MTR_1].I_A.value[0];
        pwmDACData.ptrData[2] = &adcData[MTR_1].V_V.value[0];
        pwmDACData.ptrData[3] = &angleFOCM1_rad;
        pwmDACData.gain[0] = 1.0f / MATH_TWO_PI;
        pwmDACData.gain[1] = 1.0f / USER_M1_ADC_FULL_SCALE_CURRENT_A;
        pwmDACData.gain[2] = 1.0f / USER_M1_ADC_FULL_SCALE_VOLTAGE_V;
        pwmDACData.gain[3] = 1.0f / MATH_TWO_PI;
    #elif defined(PWMDAC_PFC) && !defined(PWMDAC_MOTOR)
        pwmDACData.ptrData[2] = &pfcVars.IacRef;
        pwmDACData.ptrData[3] = &pfcVars.IacError;
        pwmDACData.offset[0] = 0.0f;
        pwmDACData.offset[1] = 0.0f;
        pwmDACData.offset[2] = 0.0f;
        pwmDACData.offset[3] = 0.0f;
        pwmDACData.gain[2] = 1.0f;
        pwmDACData.gain[3] = 1.0f;
    #elif !defined(PWMDAC_PFC) && !defined(PWMDAC_MOTOR)
        // No EPWMDAC supporting
    #else
    #error Only PWMDAC_PFC or PWMDAC_MOTOR can be supported at the same time
    #endif  // PWMDAC_PFC or PWMDAC_MOTOR
    #endif  // !HVMTRPFC_REV1P1
    #if defined(DATALOGF2_EN)
    //#warning No enough memory if use datalog, so may disable the VIB_COMP
        // Initialize Datalog
        datalogHandle = DATALOGIF_init(&datalog, sizeof(datalog));
        DATALOG_Obj *datalogObj = (DATALOG_Obj *)datalogHandle;
        HAL_setupDMAforDLOG(halHandle, 0, &datalogBuff1[0], &datalogBuff1[1]);
        HAL_setupDMAforDLOG(halHandle, 1, &datalogBuff2[0], &datalogBuff2[1]);
        // set datalog parameters
        datalogObj->iptr[0] = &angleFOCM1_rad;
        datalogObj->iptr[1] = &adcData[MTR_1].I_A.value[0];
    #endif // DATALOGF2_EN
        // initialize the DAC80504
        dac128sHandle = DAC80504_init(&dac128s);
    #if !defined(SYSCONFIG_EN)
        // setup SPI for DAC80504
        DAC80504_setupSPI(dac128sHandle);
    #else  // SYSCONFIG_EN
        SPI_setTxFifoTransmitDelay(DAC_SPI_BASE, 0x04);
        SPI_clearInterruptStatus(DAC_SPI_BASE, SPI_INT_TXFF);
        DAC80504_writeCommand(dac128sHandle);
    #else   // DAC128S805
        // initialize the DAC128S05
        dac128sHandle = DAC128S_init(&dac128s);
        // setup SPI for DAC128S05
        DAC128S_setupSPI(dac128sHandle);
        DAC128S_writeCommand(dac128sHandle);
        // The following settings are for output the values of different variables
        // in each build level for debug. The User can select one of these groups in
        // different build level as commented note
    // DAC_LEVEL1_DACTEST
    // DAC_LEVEL4_DCLINK, DAC_LEVEL4_ALL,  DAC_LEVEL2_MOTOR_IS, DAC_LEVEL4_MOTORS
    // DAC_LEVEL4_VIBCOMP, DAC_LEVEL_TEST, DAC_LEVEL4_PFC
    // DAC_LEVEL2_MOTOR1_IS, DAC_LEVEL2_MOTOR1_VS, DAC_LEVEL3_MOTOR1_EST
    // DAC_LEVEL2_MOTOR2_IS, DAC_LEVEL2_MOTOR2_VS, DAC_LEVEL3_MOTOR2_EST
    // DAC_LEVEL4_MOTOR1_EST, DAC_LEVEL4_SMOM1, DAC_LEVEL4_FASTM1, DAC_LEVEL4_DSMOM1
    // DAC_LEVEL4_MOTOR2_EST, DAC_LEVEL4_SMOM2, DAC_LEVEL4_FASTM2, DAC_LEVEL4_DSMOM2
    #define DAC_LEVEL4_ALL        // define the DAC level
    #if defined(DAC_LEVEL4_DCLINK)
        // Using in build Level_4 to debug single shunt
        dac128s.ptrData[0] = &angleFOCM1_rad;           // CH_A
        dac128s.ptrData[1] = &adcData[0].I_A.value[0];  // CH_B
        dac128s.ptrData[2] = &adcData[0].I_A.value[1];  // CH_C
        dac128s.ptrData[3] = &adcData[0].I_A.value[2];        // CH_D
        dac128s.gain[0] = 4096.0f / MATH_TWO_PI;
        dac128s.gain[1] = 4096.0f * 2.0f / USER_M1_ADC_FULL_SCALE_CURRENT_A;
        dac128s.gain[2] = 4096.0f * 2.0f / USER_M1_ADC_FULL_SCALE_CURRENT_A;
        dac128s.gain[3] = 4096.0f * 2.0f / USER_M1_ADC_FULL_SCALE_CURRENT_A;
        dac128s.offset[0] = (uint16_t)(0.5f * 4096.0f);
        dac128s.offset[1] = (uint16_t)(0.5f * 4096.0f);
        dac128s.offset[2] = (uint16_t)(0.5f * 4096.0f);
        dac128s.offset[3] = (uint16_t)(0.0f * 4096.0f);
    #elif defined(DAC_LEVEL4_PFC)
        // Using in build Level_4 to monitor the rotor angles of motor 1 and 2,
        // and the sensing AC current and voltage for PFC
        dac128s.ptrData[0] = &adcDataPFC.IacBus;    // CH_A
        dac128s.ptrData[1] = &adcDataPFC.VacBus;    // CH_B
        dac128s.ptrData[2] = &adcDataPFC.VdcBus;    // CH_C
        dac128s.ptrData[3] = &adcDataPFC.IacBus;    // CH_D
        dac128s.gain[0] = 4096.0f;
        dac128s.gain[1] = 4096.0f;
        dac128s.gain[2] = 4096.0f;
        dac128s.gain[3] = 4096.0f;
        dac128s.offset[0] = (uint16_t)(0.0f * 4096.0f);
        dac128s.offset[1] = (uint16_t)(0.0f * 4096.0f);
        dac128s.offset[2] = (uint16_t)(0.0f * 4096.0f);
    #elif defined(DAC_LEVEL4_ALL)
        dac128s.ptrData[2] = &angleFOCM1_rad;       // CH_C
        dac128s.ptrData[3] = &angleFOCM2_rad;       // CH_D
        dac128s.gain[2] = 4096.0f / MATH_TWO_PI;
        dac128s.gain[3] = 4096.0f / MATH_TWO_PI;
        dac128s.offset[3] = (uint16_t)(0.5f * 4096.0f);
    #elif defined(DAC_LEVEL2_MOTOR_IS)
        // Using in build level 2: Verify motor_2 current sensing signals
        dac128s.ptrData[0] = &adcData[0].I_A.value[0];        // CH_A
        dac128s.ptrData[1] = &adcData[1].I_A.value[0];        // CH_B
        dac128s.gain[0] = 4096.0f * 1.0f / USER_M1_ADC_FULL_SCALE_CURRENT_A;
        dac128s.gain[1] = 4096.0f * 1.0f / USER_M2_ADC_FULL_SCALE_CURRENT_A;
    #elif defined(DAC_LEVEL2_MOTOR1_IS)
        // Using in build Level 2: Verify motor_1 current sensing signals
        dac128s.ptrData[0] = &angleFOCM1_rad;                 // CH_D
        dac128s.ptrData[1] = &adcData[0].I_A.value[0];        // CH_A
        dac128s.ptrData[2] = &adcData[0].I_A.value[1];        // CH_B
        dac128s.ptrData[3] = &adcData[0].I_A.value[2];        // CH_C
        dac128s.gain[1] = 4096.0f * 1.0f / USER_M1_ADC_FULL_SCALE_CURRENT_A;
        dac128s.gain[2] = 4096.0f * 1.0f / USER_M1_ADC_FULL_SCALE_CURRENT_A;
        dac128s.gain[3] = 4096.0f * 1.0f / USER_M1_ADC_FULL_SCALE_CURRENT_A;
    #elif defined(DAC_LEVEL2_MOTOR1_VS)
        // Using in build level 2: Verify motor_1 voltage sensing signals
        dac128s.ptrData[1] = &adcData[0].V_V.value[0];        // CH_B
        dac128s.ptrData[2] = &adcData[0].V_V.value[1];        // CH_C
        dac128s.ptrData[3] = &adcData[0].V_V.value[2];        // CH_D
        dac128s.gain[1] = 4096.0f * 1.0f / USER_M1_ADC_FULL_SCALE_VOLTAGE_V;
        dac128s.gain[2] = 4096.0f * 1.0f / USER_M1_ADC_FULL_SCALE_VOLTAGE_V;
        dac128s.gain[3] = 4096.0f * 1.0f / USER_M1_ADC_FULL_SCALE_VOLTAGE_V;
    #elif defined(DAC_LEVEL3_MOTOR1_EST)
        // Using in build Level 2 and 3: Verify motor_1 estimation angle
        dac128s.ptrData[0] = &angleGenM1_rad;                 // CH_A
        dac128s.ptrData[1] = &angleESTM1_rad;                 // CH_B
        dac128s.ptrData[2] = &adcData[0].I_A.value[0];        // CH_C
        dac128s.ptrData[3] = &adcData[0].V_V.value[0];        // CH_D
        dac128s.gain[1] = 4096.0f / MATH_TWO_PI;
    #elif defined(DAC_LEVEL2_MOTOR2_IS)
        dac128s.ptrData[0] = &adcData[1].I_A.value[0];        // CH_A
        dac128s.ptrData[1] = &adcData[1].I_A.value[1];        // CH_B
        dac128s.ptrData[2] = &adcData[1].I_A.value[2];        // CH_C
        dac128s.gain[0] = 4096.0f * 1.0f / USER_M2_ADC_FULL_SCALE_CURRENT_A;
        dac128s.gain[2] = 4096.0f * 1.0f / USER_M2_ADC_FULL_SCALE_CURRENT_A;
    #elif defined(DAC_LEVEL2_MOTOR2_VS)
        // Using in build level 2: Verify motor_2 voltage sensing signals
        dac128s.ptrData[0] = &angleFOCM2_rad;                 // CH_D
        dac128s.ptrData[1] = &adcData[1].V_V.value[0];        // CH_A
        dac128s.ptrData[2] = &adcData[1].V_V.value[1];        // CH_B
        dac128s.ptrData[3] = &adcData[1].V_V.value[2];        // CH_C
        dac128s.gain[1] = 4096.0f * 1.0f / USER_M2_ADC_FULL_SCALE_VOLTAGE_V;
        dac128s.gain[2] = 4096.0f * 1.0f / USER_M2_ADC_FULL_SCALE_VOLTAGE_V;
        dac128s.gain[3] = 4096.0f * 1.0f / USER_M2_ADC_FULL_SCALE_VOLTAGE_V;
    #elif defined(DAC_LEVEL3_MOTOR2_EST)
        // Using in build level 2 and 3: Verify motor_2 estimation angle
        dac128s.ptrData[0] = &angleGenM2_rad;                 // CH_A
        dac128s.ptrData[1] = &angleESTM2_rad;                 // CH_B
        dac128s.ptrData[2] = &adcData[1].I_A.value[0];        // CH_C
        dac128s.ptrData[3] = &adcData[1].V_V.value[0];        // CH_D
    #elif defined(DAC_LEVEL4_MOTOR2_EST)
        dac128s.ptrData[0] = &angleESTM2_rad;                 // CH_A
        dac128s.ptrData[2] = &adcData[1].V_V.value[0];        // CH_C
        dac128s.ptrData[3] = &adcData[1].I_A.value[1];        // CH_D
        dac128s.gain[3] = 4096.0f * 1.0f / USER_M2_ADC_FULL_SCALE_CURRENT_A;
    #elif defined(DAC_LEVEL4_MOTORS)
        // Using in build level 3 and 4: Verify motor_1 & motor_2 closed-loop
        dac128s.ptrData[1] = &angleFOCM2_rad;                 // CH_B
        dac128s.ptrData[3] = &adcData[1].I_A.value[0];        // CH_D
    #elif defined(DAC_LEVEL4_SMOM1)
        dac128s.ptrData[2] = &anglePLLM1_rad;                 // CH_C
    //    dac128s.ptrData[3] = &angleESTM1_rad;               // CH_D
        dac128s.ptrData[3] = &angleFOCM1_rad;                 // CH_D
    #elif defined(DAC_LEVEL4_FASTM2)
        dac128s.ptrData[0] = &angleFOCM2_rad;                 // CH_A
    #elif defined(DAC_LEVEL4_SMOM2)
        dac128s.ptrData[0] = &angleFOCM2_rad;                 // CH_C
        dac128s.ptrData[1] = &anglePLLM2_rad;                 // CH_A
    #elif defined(DAC_LEVEL4_DSMOM2)
        dac128s.ptrData[2] = &angleESTM2_rad;                 // CH_B
    #elif defined(DAC_LEVEL4_VIBCOMP)
        // Using in build level 4: for vibration compensation debug
        dac128s.ptrData[0] = &vibComp.angleMechPoles_rad;                // CH_A
        dac128s.ptrData[1] = &angleFOCM1_rad;                       // CH_B
        dac128s.ptrData[2] = &vibComp.Iq_comp_A;                    // CH_C
        dac128s.ptrData[3] = &Idq_in_A[0].value[1];                 // CH_D
        dac128s.gain[0] = 4096.0f / MATH_TWO_PI / USER_MOTOR1_NUM_POLE_PAIRS;
        dac128s.gain[2] = 4096.0f * 0.5f / USER_M1_ADC_FULL_SCALE_CURRENT_A;
        dac128s.gain[3] = 4096.0f * 0.5f / USER_M2_ADC_FULL_SCALE_CURRENT_A;
    #elif defined(DAC_LEVEL_TEST) && defined(DACTEST_EN)
        dac128s.ptrData[0] = &dacTestValue[0];         // CH_A
        dac128s.ptrData[1] = &dacTestValue[1];         // CH_B
        dac128s.ptrData[2] = &dacTestValue[2];         // CH_C
        dac128s.ptrData[3] = &dacTestValue[3];         // CH_D
    #else
    #error Not assign the variables to the DAC object
    #endif  //DAC_LEVEL
    #if defined(SFRA_ENABLE) &&  (SFRA_TEST_TYPE == SFRA_TEST_PFC)
        // Plot GH & H plots using SFRA_GUI
        configureSFRA(SFRA_GUI_PLOT_GH_H, PFC_SAMPLING_FREQ_HZ);
        sfraTestLoop = SFRA_TEST_PFC_CURRENT;
        sfraCollectStart = false;       // disable SFRA data collection
    #endif  // SFRA_ENABLE && SFRA_TEST_PFC
    #if defined(SFRA_ENABLE) && (SFRA_TEST_TYPE == SFRA_TEST_MOTOR1)
        // Plot GH & H plots using SFRA_GUI, GH & CL plots using SFRA_GUI_MC
        configureSFRA(SFRA_GUI_PLOT_GH_H, USER_M1_SAMPLING_FREQ_Hz);
        sfraTestLoop = SFRA_TEST_MOTOR1_IQ;
    #endif  // SFRA_ENABLE && SFRA_TEST_MOTOR1
    #if defined(SFRA_ENABLE) && ( SFRA_TEST_TYPE == SFRA_TEST_MOTOR2)
        configureSFRA(SFRA_GUI_PLOT_GH_H, MOTOR2_SAMPLING_FREQ_Hz);
        sfraTestLoop = SFRA_TEST_MOTOR2_IQ;
    #endif  // SFRA_ENABLE && SFRA_TEST_MOTOR2
        systemVars.flagEnableSystem = false;
        compressor1motorFlag = false;    //add 10032024
    #if(PFC_BUILDLEVEL >= PFC_LEVEL_2)
        pfcVars.flagEnableOffsetCalc = false;
        motorVars[MTR_1].flagEnableOffsetCalc = true;
        motorVars[MTR_2].flagEnableOffsetCalc = true;
    #else
        pfcVars.flagEnableOffsetCalc = true;
    #endif  // PFC_BUILDLEVEL == PFC_LEVEL_1
        systemVars.powerRelayWaitTime_ms = POWER_RELAY_WAIT_TIME_ms;    //6s
        systemVars.timerBase_1ms = 0;
        systemVars.flagEnableExtCmd = false;
        // Waiting for enable system flag to be set
        while(systemVars.flagEnableSystem == false)
            if(HAL_getCPUTimerStatus(halHandle, HAL_CPU_TIMER0) == true)
                // read the ADC data with offsets
                HAL_readPFCADCData(&adcDataPFC);
                // convert dc bus voltage from pu to SI unit
                pfcVars.VdcBusLPF = pfcVars.VdcBusLPF +
                        (adcDataPFC.VdcBus - pfcVars.VdcBusLPF) * pfcVars.lpfVdcCoeff;
                pfcVars.VdcBusLPF_V = pfcVars.VdcBusLPF * USER_PFC_ADC_FULL_SCALE_DC_VOLTAGE_V;
            #if(PFC_BUILDLEVEL > PFC_LEVEL_4)
                if(pfcVars.VdcBusLPF_V >= POWER_RELAY_ON_VOLTAGE_V)
                    systemVars.timerBase_1ms++;
            #else
            #endif
                if(systemVars.timerBase_1ms > systemVars.powerRelayWaitTime_ms)
                    systemVars.flagEnableSystem = true;
                    // Turn on the power relay
                    HAL_turnOnPowerRelay(ACPOWER_RELAY_GPIO);
                    // Turn on the FWV relay which is used for power relay
                    // on the new board for F280015x
                    HAL_turnOnPowerRelay(FOURWAY_RELAY_GPIO);
                HAL_clearCPUTimerFlag(halHandle, HAL_CPU_TIMER0);
        systemVars.powerRelayWaitTime_ms = OFFSET_CHECK_WAIT_TIME_ms; //4s
    #ifndef PFC_DISABLE
        // run offset calibration for PFC
        runPFCOffsetsCalculation();
    #endif  // PFC_DISABLE
    #ifndef MOTOR1_DISABLE
        // run offset calibration for motor 1
        runMotor1OffsetsCalculation();
    #endif  // !MOTOR1_DISABLE
    #ifndef MOTOR2_DISABLE
        // run offset calibration for motor 2
        runMotor2OffsetsCalculation();
    #endif  // !MOTOR2_DISABLE
        // enable global interrupts
        HAL_enableGlobalInts(halHandle);
        // enable debug interrupts
        HAL_enableDebugInt(halHandle);
        motorVars[0].flagEnableRunAndIdentify = false;
        motorVars[1].flagEnableRunAndIdentify = false;
    //    msg = "@ Welcome VOEPL Team @";
    //    SCI_writeCharArray(SCIC_BASE, (uint16_t*)msg, 22);
        msg = "@ Welcome To Voepl @";
        SCI_writeCharArray(SCIC_BASE, (uint16_t*)msg, 20);
        Interrupt_enable(INT_SCIC_RX);
        Interrupt_enable(INT_SCIC_TX);
        Interrupt_register(INT_SCIC_TX, INT_SCI_COM_TX_ISR);    //ok
        systemVars.powerRelayWaitTime_ms1 = OFFSET_CHECK_WAIT_TIME_ms1; //10s
        while(systemVars.flagEnableSystem == true)
    //        Interrupt_register(INT_SCIA_TX, INT_SCI_COM_TX_ISR);    //ok
                tempnewvalue1 = (*read_ADC_Value);
                fTempValue = (float)(ADC_RESOLUTION_VALUE - tempnewvalue1);//value
                fTempValue *= (TEMP_AIR_RES_GND / tempnewvalue1);
                Temp_Sensor_coils = (float)ntc_sensor_get_temp(fTempValue, TEMP_AIR_RES_T_25, TEMP_AIR_BETA);
            //--------------------------------------Ambient sensor-------------------------------------------------
                tempnewvalue2 = (*read_ADC_Value1);
                fTempValue = (float)(ADC_RESOLUTION_VALUE - tempnewvalue2);//value
                fTempValue *= (TEMP_AIR_RES_GND / tempnewvalue2);
                Temp_Sensor_Ambient = (float)ntc_sensor_get_temp(fTempValue, TEMP_AIR_RES_T_25, TEMP_AIR_BETA);
    //---------------------------------Discharge_Sensor-------------------------------------------------------------
                tempnewvalue3 = (*read_ADC_Value2);
                fTempValue = (float)(ADC_RESOLUTION_VALUE - tempnewvalue3);//value
                fTempValue *= (TEMP_AIR_RES_GND / tempnewvalue3);
                Temp_Sensor_Discharge = (float)ntc_sensor_get_temp(fTempValue, TEMP_AIR_RES_T_25, TEMP_AIR_BETA);
    //-------------------------------------------NEW---ADD---END------------------------------------------------------
    //            systemVars.timerBase_1ms = 0;
    //            systemVars.powerRelayWaitTime_ms1 = OFFSET_CHECK_WAIT_TIME_ms1; //10s
    //          while(tx_flag == false)
    //            if(HAL_getCPUTimerStatus(halHandle, HAL_CPU_TIMER0) == true)
    ////                     systemVars.powerRelayWaitTime_ms1 = OFFSET_CHECK_WAIT_TIME_ms1; //10s
    //                       systemVars.timerBase_1ms++;
    //                       if(systemVars.timerBase_1ms > systemVars.powerRelayWaitTime_ms1)//10000
    //                           //systemVars.flagEnableSystem = true;
    //                           tx_flag = 1;
    //                       HAL_clearCPUTimerFlag(halHandle, HAL_CPU_TIMER0);
                if(tx_flag == true)
                    msg = "$0025,0020#";
                    SCI_writeCharArray(SCIC_BASE, (uint16_t*)msg, 11);
                    tx_flag = false;
                if(rx_flag ==true)
                   // unsigned char ucTempValue = 0;
    //                uiTempValue = (ucRxBuff[0] & 0x0F) << 3;  // Thousands digit (shift left by 3, which is equivalent to multiplying by 8)
    //                uiTempValue += (ucRxBuff[1] & 0x0F) << 2;  // Hundreds digit (shift left by 2, equivalent to multiplying by 4)
    //                uiTempValue += (ucRxBuff[2] & 0x0F) << 1;  // Tens digit (shift left by 1, equivalent to multiplying by 2)
    //                uiTempValue += (ucRxBuff[3] & 0x0F);       // Units digit (no shift, equivalent to multiplying by 1)
    //                rx_flag = 0;
    //                unsigned int uiTempValue=0;
                    uiTempValue = (ucRxBuff[1] & 0x0F);
                    uiTempValue *= 1000;
                    uiTempValue += ((ucRxBuff[2] & 0x0F) * 100);
                    uiTempValue += ((ucRxBuff[3] & 0x0F) * 10);
                    uiTempValue += ((ucRxBuff[4] & 0x0F) * 1);
    //                Temp_Sensor_Ambient=(float)uiTempValue;
    //                IDU_Ambiet_Temp=(float)uiTempValue;
                    IDU_Ambiet_Temp=uiTempValue;
    //                uiTempValue1 = (ucRxBuff[5] & 0x0F);
    //                uiTempValue1 *= 1000;
    //                uiTempValue1 += ((ucRxBuff[6] & 0x0F) * 100);
    //                uiTempValue1 += ((ucRxBuff[7] & 0x0F) * 10);
    //                uiTempValue1 += ((ucRxBuff[8] & 0x0F) * 1);
    //                IDU_set_Temp=uiTempValue1;
                    ucRxStatus1 = '^';
                    //motorVars[MTR_2].CompressorStartFlag = true;
                    CompressorStartFlag=true;
                    rx_flag=false;
    //                cx_flag=true;
            // loop while the enable system flag is true
            // 1ms time base
                SYS_processFault();
          if( compressor1motorFlag == true)   //     this is compressor flagRunIdentAndOnLine added by bn
                SYS_updateCtrlState();
                motorVars[MTR_1].flagEnableRunAndIdentify = true;
                switch(systemVars.timerBase_1ms)
                    // 5ms time base
                    case 1:     // motor 1 protection check
                        calculateRMSData(MTR_1);
                        runMotorMonitor(MTR_1);
                        break;
                    case 2:     // motor 2 protection check
                    #if !defined(MOTOR2_DISABLE)    // single motor on high voltage kit
                        calculateRMSData(MTR_2);
                        runMotorMonitor(MTR_2);
                        break;
                    case 3:     // pfc protection check
                    #if !defined(PFC_DISABLE)
                        runPFCMonitor();
                        break;
                    case 4:     // calculate motor and pfc protection value
                    #if !defined(MOTOR1_DCLINKSS)
                        calcMotorOverCurrentThreshold(MTR_1);
                    #elif !defined(MOTOR1_DISABLE)   // MOTOR1_DCLINKSS
                        calcMotorDCLinkOverCurrentThreshold(MTR_1);
                    #endif  // MOTOR1_DCLINKSS
                    #if !defined(MOTOR2_DISABLE) && !defined(MOTOR2_DCLINKSS)
                        calcMotorOverCurrentThreshold(MTR_2);
                    #elif !defined(MOTOR2_DISABLE)   // MOTOR2_DCLINKSS
                        calcMotorDCLinkOverCurrentThreshold(MTR_2);
                    #endif  // !MOTOR2_DISABLE & MOTOR2_DCLINKSS
                        calcPFCOverCurrentThreshold();
                    #if defined(MOTOR1_FWC)
                        updateFWCParams();
                    #endif  // MOTOR1_FWC
                    #if defined(MOTOR1_MTPA)
                        updateMTPAParams();
                    #endif  // MOTOR1_MTPA
                        break;
                    case 5:     // system control
                        systemVars.timerCnt_5ms++;
                        SYS_displayFault();     // 5ms
                    #if defined(MOTOR2_ESMO) && !defined(MOTOR2_DISABLE)
                        if(motorVars[MTR_2].motorState >= MOTOR_CTRL_RUN)
                            ESMO_updateFilterParams(esmoM2Handle);
                            ESMO_updatePLLParams(esmoM2Handle);
                    #endif  // MOTOR2_ESMO
                    #if defined(MOTOR1_ESMO) && !defined(MOTOR1_DISABLE)
                        if(motorVars[MTR_1].motorState >= MOTOR_CTRL_RUN)
                            ESMO_updateFilterParams(esmoM1Handle);
                            ESMO_updatePLLParams(esmoM1Handle);
                        break;
                    default:
                        break;
                // SFRA test
                SFRA_F32_runBackgroundTask(&sfra1);
                SFRA_GUI_runSerialHostComms(&sfra1);
            // run control for motor 1
            runMotor1Control();
            // run control for motor 2
            runMotor2Control();
            // run control for PFC
            runPFCMainControl();
            if(systemVars.flagEnableExtCmd == true)
                if(GPIO_readPin(TEST_SWITCH_GPIO) == 0)
                    motorVars[MTR_2].flagEnableRunAndIdentify = true;
                    motorVars[MTR_2].speedRef_Hz = systemVars.speedFan_Hz;
                else
                    motorVars[MTR_2].flagEnableRunAndIdentify = false;
        } // end of while() loop
        // disable the PWM for stopping the motor 1
        HAL_disableMTRPWM(halMtrHandle[0]);
        HAL_disableMTRPWM(halMtrHandle[1]);
    } // end of main() function
        float temp = 1 / (1 / TEMP_T_25_K + (log10((float)res/res_25) / LOG_10_E / beta));
        temp -= 273.15;
        return temp;
    __interrupt void INT_MTR1_EMI_1_ISR(void)
    //    ADC_clearInterruptStatus(MTR1_EMI_BASE, ADC_INT_NUMBER1);
    //    if(true==ADC_getInterruptOverflowStatus(MTR1_EMI_BASE, ADC_INT_NUMBER1))
     //       ADC_clearInterruptOverflowStatus(MTR1_EMI_BASE, ADC_INT_NUMBER1);
     //   Interrupt_clearACKGroup(INT_MTR1_EMI_1_INTERRUPT_ACK_GROUP);
    //-- end of this file ----------------------------------------------------------
    void
    configCPUTimer(uint32_t cpuTimer, float freq, float period)
            uint32_t temp;
            temp = (uint32_t)((freq / 1000000) * period);
            CPUTimer_setPeriod(CPU_TIMER1_BASE, 119047U);
            CPUTimer_setPreScaler(CPU_TIMER1_BASE, 1000U);
            CPUTimer_reloadTimerCounter(CPU_TIMER1_BASE);
            CPUTimer_setEmulationMode(CPU_TIMER1_BASE, CPUTIMER_EMULATIONMODE_RUNFREE);
            if(cpuTimer == CPUTIMER1_BASE)
            cpuTimer1IntCount = 0;
    __interrupt void INT_CPU_TIMER1_ISR(void) //INT_CPU_TIMER1_ISR
        if(CompressorStartFlag == true)
    //    if( (ucRxStatus1 == '^'))
               b++;
               cpuTimer1IntCount++;
               if(cpuTimer1IntCount >= 181)
                       compressor1motorFlag = true;
    //               cpuTimer1IntCount=0;
    //               cx_flag=false;
                       CompressorStartFlag = false;
        cpuTimer2IntCount++;
        if(cpuTimer2IntCount == 10)
            tx_flag =true;
        Interrupt_clearACKGroup(INTERRUPT_ACK_GROUP1);
    void error(void)
        asm("     ESTOP0"); // Test failed!! Stop!
        for (;;);
    //    uint16_t i;
    //     SCI_writeCharArray(SCIA_BASE, sDataA, 9);
    //        SCI_clearInterruptStatus(SCIA_BASE, SCI_INT_TXFF);
    //        // Issue PIE ACK
    //        // SCI_enableInterrupt(uint32_t base, uint32_t intFlags);
        ASSERT(SCI_isBaseValid(SCIC_BASE));
        if(SCI_isFIFOEnabled(SCIC_BASE))
            while(SCI_getRxFIFOStatus(SCIC_BASE) == SCI_FIFO_RX15)
            //rx_data =(HWREGH(SCIC_BASE + SCI_O_RXBUF) & SCI_RXBUF_SAR_M);
            rx_data = (HWREGH(SCIC_BASE + SCI_O_RXBUF) & SCI_RXBUF_SAR_M);
            rx_data_save = rx_data;
            if(ucRxStatus == 'H')
                if(rx_data == '$')
                    uiRxByteCntr = 0;
                    ucRxBuff[uiRxByteCntr++] = rx_data_save;
                    ucRxStatus = 'A';
                else
                    uiRxByteCntr = 0;
                    ucRxStatus = 'H';
            else if(ucRxStatus == 'A')
                if(rx_data == '*')  //
                    rx_flag = 1;
    //                cx_flag = 1;
                    ucRxStatus = 'H';
                else
            else
                ucRxStatus = 'H';
                uiRxByteCntr = 0;
    //-------------------------New added end------------------
        SCI_clearOverflowStatus(SCIC_BASE);
        SCI_clearInterruptStatus(SCIC_BASE, SCI_INT_RXFF);
            // Issue PIE ack
    void initSCIAFIFO()
        // 8 char bits, 1 stop bit, no parity. Baud rate is 9600.
        SCI_setConfig(SCIC_BASE, DEVICE_LSPCLK_FREQ, 9600, (SCI_CONFIG_WLEN_8 |
                                                         SCI_CONFIG_STOP_ONE |
                                                            SCI_CONFIG_PAR_NONE));
        SCI_enableModule(SCIC_BASE);
       SCI_enableLoopback(SCIC_BASE);
        SCI_resetChannels(SCIC_BASE);
        SCI_disableFIFO(SCIC_BASE);
        // RX and TX FIFO Interrupts Enabled
        SCI_enableInterrupt(SCIC_BASE, (SCI_INT_RXFF | SCI_INT_TXFF));
        SCI_disableInterrupt(SCIC_BASE, SCI_INT_RXERR);
        // The transmit FIFO generates an interrupt when FIFO status
        // bits are less than or equal to 2 out of 16 words
        // The receive FIFO generates an interrupt when FIFO status
        // bits are greater than equal to 2 out of 16 words
        SCI_setFIFOInterruptLevel(SCIC_BASE, SCI_FIFO_TX2, SCI_FIFO_RX2);
        SCI_performSoftwareReset(SCIC_BASE);
        SCI_resetTxFIFO(SCIC_BASE);//
        SCI_resetRxFIFO(SCIC_BASE);//
    this code work ok.
    // $Copyright:
    // are met:
    //   distribution.
    #include "user.h"
    #include "board.h"
    #include "math.h"
    #include "string.h"
    //Global
    unsigned int b=0;
    // Globals
    char ucRxStatus1;
    uint16_t rDataA[1];
    char rxflag=0;
    void error(void);
    #else   // DAC128S805
    #endif  // DACTEST
    //air temperature
    // the functions
    void main(void)
        unsigned char *msg;
        ucRxStatus ='H';
    #else
    #endif
    #endif //
    #else
    #else
        //07042024
        initSCIAFIFO();
       // SYS_TX_init();
        Board_init();
    //            sDataA[i] = i;
    #else
    #else   // DAC128S805
    #else
    #endif  //DAC_LEVEL
    #else
            #else
            #endif
    #ifndef PFC_DISABLE
    //                           tx_flag = 1;
                if(tx_flag == true)
                    tx_flag = false;
                if(rx_flag ==true)
    //                rx_flag = 0;
                    ucRxStatus1 = '^';
                    rx_flag=false;
    //                cx_flag=true;
            // 1ms time base
                SYS_processFault();
                    // 5ms time base
                        break;
                        break;
                        runPFCMonitor();
                        break;
                        updateFWCParams();
                        updateMTPAParams();
                        break;
                        break;
                    default:
                        break;
                // SFRA test
            runMotor1Control();
            runMotor2Control();
                else
        temp -= 273.15;
        return temp;
    void
            uint32_t temp;
               b++;
    //               cx_flag=false;
            tx_flag =true;
    void error(void)
        for (;;);
    //    uint16_t i;
    //        // Issue PIE ACK
                if(rx_data == '$')
                    uiRxByteCntr = 0;
                    ucRxStatus = 'A';
                else
                    uiRxByteCntr = 0;
                    ucRxStatus = 'H';
                    rx_flag = 1;
    //                cx_flag = 1;
                    ucRxStatus = 'H';
                else
            else
                ucRxStatus = 'H';
                uiRxByteCntr = 0;
            // Issue PIE ack
    void initSCIAFIFO()
    this above code not work properly.
    we added line no.1009-1014 then code not work properly.
  • If you put a breakpoint at line 1000, does ucRxBuff[5] - [8] have the values you expect from the SCI/UART transfer?  Maybe the issue is back at the SCI data receive, and if that data is bad its going to impact the code you have mentioned.
    Matthew
  • Dear Mathew,
    Please find Detail video.
    It very urgent issue because please resolved as early as possible...our project is delay due this issue only otherwise our project is complete almost 80%.
    Please clarify exactly what the intended behavior is, then clarify what the code is doing incorrectly in your second file and the video. Given that we do not have the context of the intended behavior, It is not clear so far from your replies, unfortunately. With that information, we'll be able to more easily help you.
    Jason Osborn
