Part Number: C2000WARE-MOTORCONTROL-SDK
Other Parts Discussed in Thread: CONTROLSUITE
Hi Team,
I would like to check if we have the ref code for sensor trap algorithm for BLDC motor control?
Thanks!
Jenson
Hi Team,
Thanks!
Jenson
There is an example available within controlSUITE (controlSUITE\development_kits\DRV8312-C2-KIT_v128\BLDC_Sensored). Here is the link to the associated documentation: https://www.ti.com/lit/sprabz4
Kind regards,
Skyler
Hi Skyler,
Thanks for your feedback here, I would like to double check if we have some ref code use 3-generation C2000(like 280049/25/13)
Jenson
Hi Jenson,
No, there is no reference code using a Gen 3 C2000 device.
Kind regards,
Skyler
HI Skyler
I would like to double check with you in this folder(controlSUITE\development_kits\DRV8312-C2-KIT_v128\BLDC_Sensored), it also can support F28069 right?I check the guide only show the F28035, but in the folder I can see F28069.c file. So can I use F28069 to run this?
Jenson
Hi Jenson,
Please take a look at this FAQ to find information about porting this to F2806x: https://e2e.ti.com/support/microcontrollers/c2000-microcontrollers-group/c2000/f/c2000-microcontrollers-forum/864875/faq-trapezoidal-control-of-bldc-motors-using-hall-effect-sensors-on-c2000-controller
Kind regards,
Skyler
Hi Skyler,
Thanks for your information, I just want to double check with you for this code.I think we alrady have F2806X version BLDC sensored code..It is right? I try to use F28069 lanchpad to run this code, it can build and debug.
Jenson
