TMS320F28335: TMS320F28335 not booting from Flash
Part Number: TMS320F28335
I am not able to boot from flash TMS320F28335. The GPIO's GPIO84, GPIO85, GPIO86, and GPIO87 have a pull-up to 3.3V which should force the MCu to boot from flash. As far as I understand, the pull-up should be the only thing we need in our system to guarantee that it boots from flash.
Am I missing something else?
I am attaching the .cmd file content.
I'll appreciate your advice.
// TI File $Revision: /main/10 $
// Checkin $Date: July 9, 2008   13:43:56 $
// FILE:	F28335.cmd
// TITLE:	Linker Command File For F28335 Device
// $TI Release:$
// $Release Date:$
// For Code Composer Studio V2.2 and later
// In addition to this memory linker command file,
// add the header linker command file directly to the project.
// The header linker command file is required to link the
// peripheral structures to the proper locations within
// the memory map.
// The header linker files are found in <base>\DSP2833x_Headers\cmd
// For BIOS applications add:      DSP2833x_Headers_BIOS.cmd
// For nonBIOS applications add:   DSP2833x_Headers_nonBIOS.cmd
// For Code Composer Studio prior to V2.2
// 1) Use one of the following -l statements to include the
// header linker command file in the project. The header linker
// file is required to link the peripheral structures to the proper
// locations within the memory map                                    */
/* Uncomment this line to include file only for non-BIOS applications */
/* -l DSP2833x_Headers_nonBIOS.cmd */
/* Uncomment this line to include file only for BIOS applications */
/* -l DSP2833x_Headers_BIOS.cmd */
/* 2) In your project add the path to <base>\DSP2833x_headers\cmd to the
   library search path under project->build options, linker tab,
   library search path (-i).
/* Define the memory block start/length for the F28335
   PAGE 0 will be used to organize program sections
   PAGE 1 will be used to organize data sections
    Notes:
          Memory blocks on F28335 are uniform (ie same
          physical memory) in both PAGE 0 and PAGE 1.
          That is the same memory region should not be
          defined for both PAGE 0 and PAGE 1.
          Doing so will result in corruption of program
          and/or data.
          L0/L1/L2 and L3 memory blocks are mirrored - that is
          they can be accessed in high memory or low memory.
          For simplicity only one instance is used in this
          linker file.
          Contiguous SARAM memory blocks can be combined
          if required to create a larger memory block.
MEMORY
PAGE 0:    /* Program Memory */
           /* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE1 for data allocation */
   ZONE0       : origin = 0x004000, length = 0x001000     /* XINTF zone 0 */
   RAML0       : origin = 0x008000, length = 0x001000     /* on-chip RAM block L0 */
   RAML1       : origin = 0x009000, length = 0x001000     /* on-chip RAM block L1 */
   RAML2       : origin = 0x00A000, length = 0x001000     /* on-chip RAM block L2 */
   RAML3       : origin = 0x00B000, length = 0x001000     /* on-chip RAM block L3 */
   ZONE6       : origin = 0x0100000, length = 0x100000    /* XINTF zone 6 */
   ZONE7A      : origin = 0x0200000, length = 0x00FC00    /* XINTF zone 7 - program space */
   FLASHH      : origin = 0x300000, length = 0x008000     /* on-chip FLASH */
   FLASHG      : origin = 0x308000, length = 0x008000     /* on-chip FLASH */
   FLASHF      : origin = 0x310000, length = 0x008000     /* on-chip FLASH */
   FLASHE      : origin = 0x318000, length = 0x008000     /* on-chip FLASH */
//   FLASHE      : origin = 0x318000, length = 0x007FFE     /* on-chip FLASH - App2*/
   FLASHD      : origin = 0x320000, length = 0x008000     /* on-chip FLASH */
   FLASHC      : origin = 0x328000, length = 0x008000     /* on-chip FLASH */
   FLASHB      : origin = 0x330000, length = 0x008000     /* on-chip FLASH */
//   FLASHB      : origin = 0x330000, length = 0x007FFE     /* on-chip FLASH - App1*/
   FLASHA      : origin = 0x338000, length = 0x007F80     /* on-chip FLASH */
   CSM_RSVD    : origin = 0x33FF80, length = 0x000076     /* Part of FLASHA.  Program with all 0x0000 when CSM is in use. */
   BEGIN       : origin = 0x33FFF6, length = 0x000002     /* Part of FLASHA. Launcher. Used for "boot to Flash" bootloader mode. */
//   BEGIN       : origin = 0x31FFFE, length = 0x000002     /* Part of FLASHE. App2. Used for "boot to Flash" bootloader mode. */
//   BEGIN       : origin = 0x337FFE, length = 0x000002     /* Part of FLASHB. App1. Used for "boot to Flash" bootloader mode. */
   CSM_PWL     : origin = 0x33FFF8, length = 0x000008     /* Part of FLASHA. CSM password locations in FLASHA */
   OTP         : origin = 0x380400, length = 0x000400     /* on-chip OTP */
   ADC_CAL     : origin = 0x380080, length = 0x000009     /* ADC_cal function in Reserved memory */
   IQTABLES    : origin = 0x3FE000, length = 0x000b50     /* IQ Math Tables in Boot ROM */
   IQTABLES2   : origin = 0x3FEB50, length = 0x00008c     /* IQ Math Tables in Boot ROM */
//   FPUTABLES   : origin = 0x3FEBDC, length = 0x0006A0     /* FPU Tables in Boot ROM */
   ROM         : origin = 0x3FF27C, length = 0x000D44     /* Boot ROM */
   RESET       : origin = 0x3FFFC0, length = 0x000002     /* part of boot ROM  */
   VECTORS     : origin = 0x3FFFC2, length = 0x00003E     /* part of boot ROM  */
PAGE 1 :   /* Data Memory */
           /* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE0 for program allocation */
           /* Registers remain on PAGE1                                                  */
   BOOT_RSVD   : origin = 0x000000, length = 0x000050     /* Part of M0, BOOT rom will use this for stack */
   RAMM0       : origin = 0x000050, length = 0x0003B0     /* on-chip RAM block M0 */
   RAMM1       : origin = 0x000400, length = 0x000400     /* on-chip RAM block M1 */
//   RAML4       : origin = 0x00C000, length = 0x001000     /* on-chip RAM block L1 */
//   RAML5       : origin = 0x00D000, length = 0x001000     /* on-chip RAM block L1 */
//   RAML6       : origin = 0x00E000, length = 0x001000     /* on-chip RAM block L1 */
//   RAML7       : origin = 0x00F000, length = 0x001000     /* on-chip RAM block L1 */
   RAML45	   : origin = 0x00C000, length = 0x002000     /* on-chip RAM block L1 */
   RAML67      : origin = 0x00E000, length = 0x002000     /* on-chip RAM block L1 */
   ZONE7B      : origin = 0x20FC00, length = 0x000400     /* XINTF zone 7 - data space */
//   FLASHB      : origin = 0x330000, length = 0x008000     /* on-chip FLASH */
   DEV_EMU     : origin = 0x000880, length = 0x000180     /* device emulation registers */
   FLASH_REGS  : origin = 0x000A80, length = 0x000060     /* FLASH registers */
   CSM         : origin = 0x000AE0, length = 0x000010     /* code security module registers */
   ADC_MIRROR  : origin = 0x000B00, length = 0x000010     /* ADC Results register mirror */
   XINTF       : origin = 0x000B20, length = 0x000020     /* external interface registers */
   CPU_TIMER0  : origin = 0x000C00, length = 0x000008     /* CPU Timer0 registers */
   CPU_TIMER1  : origin = 0x000C08, length = 0x000008     /* CPU Timer0 registers (CPU Timer1 & Timer2 reserved TI use)*/
   CPU_TIMER2  : origin = 0x000C10, length = 0x000008     /* CPU Timer0 registers (CPU Timer1 & Timer2 reserved TI use)*/
   PIE_CTRL    : origin = 0x000CE0, length = 0x000020     /* PIE control registers */
   PIE_VECT    : origin = 0x000D00, length = 0x000100     /* PIE Vector Table */
   DMA         : origin = 0x001000, length = 0x000200     /* DMA registers */
   MCBSPA      : origin = 0x005000, length = 0x000040     /* McBSP-A registers */
   MCBSPB      : origin = 0x005040, length = 0x000040     /* McBSP-B registers */
   ECANA       : origin = 0x006000, length = 0x000040     /* eCAN-A control and status registers */
   ECANA_LAM   : origin = 0x006040, length = 0x000040     /* eCAN-A local acceptance masks */
   ECANA_MOTS  : origin = 0x006080, length = 0x000040     /* eCAN-A message object time stamps */
   ECANA_MOTO  : origin = 0x0060C0, length = 0x000040     /* eCAN-A object time-out registers */
   ECANA_MBOX  : origin = 0x006100, length = 0x000100     /* eCAN-A mailboxes */
   ECANB       : origin = 0x006200, length = 0x000040     /* eCAN-B control and status registers */
   ECANB_LAM   : origin = 0x006240, length = 0x000040     /* eCAN-B local acceptance masks */
   ECANB_MOTS  : origin = 0x006280, length = 0x000040     /* eCAN-B message object time stamps */
   ECANB_MOTO  : origin = 0x0062C0, length = 0x000040     /* eCAN-B object time-out registers */
   ECANB_MBOX  : origin = 0x006300, length = 0x000100     /* eCAN-B mailboxes */
   EPWM1       : origin = 0x006800, length = 0x000022     /* Enhanced PWM 1 registers */
   EPWM2       : origin = 0x006840, length = 0x000022     /* Enhanced PWM 2 registers */
   EPWM3       : origin = 0x006880, length = 0x000022     /* Enhanced PWM 3 registers */
   EPWM4       : origin = 0x0068C0, length = 0x000022     /* Enhanced PWM 4 registers */
   EPWM5       : origin = 0x006900, length = 0x000022     /* Enhanced PWM 5 registers */
   EPWM6       : origin = 0x006940, length = 0x000022     /* Enhanced PWM 6 registers */
   ECAP1       : origin = 0x006A00, length = 0x000020     /* Enhanced Capture 1 registers */
   ECAP2       : origin = 0x006A20, length = 0x000020     /* Enhanced Capture 2 registers */
   ECAP3       : origin = 0x006A40, length = 0x000020     /* Enhanced Capture 3 registers */
   ECAP4       : origin = 0x006A60, length = 0x000020     /* Enhanced Capture 4 registers */
   ECAP5       : origin = 0x006A80, length = 0x000020     /* Enhanced Capture 5 registers */
   ECAP6       : origin = 0x006AA0, length = 0x000020     /* Enhanced Capture 6 registers */
   EQEP1       : origin = 0x006B00, length = 0x000040     /* Enhanced QEP 1 registers */
   EQEP2       : origin = 0x006B40, length = 0x000040     /* Enhanced QEP 2 registers */
   GPIOCTRL    : origin = 0x006F80, length = 0x000040     /* GPIO control registers */
   GPIODAT     : origin = 0x006FC0, length = 0x000020     /* GPIO data registers */
   GPIOINT     : origin = 0x006FE0, length = 0x000020     /* GPIO interrupt/LPM registers */
   SYSTEM      : origin = 0x007010, length = 0x000020     /* System control registers */
   SPIA        : origin = 0x007040, length = 0x000010     /* SPI-A registers */
   SCIA        : origin = 0x007050, length = 0x000010     /* SCI-A registers */
   XINTRUPT    : origin = 0x007070, length = 0x000010     /* external interrupt registers */
   ADC         : origin = 0x007100, length = 0x000020     /* ADC registers */
   SCIB        : origin = 0x007750, length = 0x000010     /* SCI-B registers */
   SCIC        : origin = 0x007770, length = 0x000010     /* SCI-C registers */
   I2CA        : origin = 0x007900, length = 0x000040     /* I2C-A registers */
   CSM_PWL     : origin = 0x33FFF8, length = 0x000008     /* Part of FLASHA.  CSM password locations. */
   PARTID      : origin = 0x380090, length = 0x000001     /* Part ID register location */
/* Allocate sections to memory blocks.
   Note:
         codestart user defined section in DSP28_CodeStartBranch.asm used to redirect code
                   execution when booting to flash
         ramfuncs  user defined section to store functions that will be copied from Flash into RAM
SECTIONS
    PieVectTableFile : > PIE_VECT,   PAGE = 1
/*** Peripheral Frame 0 Register Structures ***/
   DevEmuRegsFile    : > DEV_EMU,     PAGE = 1
   FlashRegsFile     : > FLASH_REGS,  PAGE = 1
   CsmRegsFile       : > CSM,         PAGE = 1
   AdcMirrorFile     : > ADC_MIRROR,  PAGE = 1
   XintfRegsFile     : > XINTF,       PAGE = 1
   CpuTimer0RegsFile : > CPU_TIMER0,  PAGE = 1
   CpuTimer1RegsFile : > CPU_TIMER1,  PAGE = 1
   CpuTimer2RegsFile : > CPU_TIMER2,  PAGE = 1
   PieCtrlRegsFile   : > PIE_CTRL,    PAGE = 1
   DmaRegsFile       : > DMA,         PAGE = 1
/*** Peripheral Frame 3 Register Structures ***/
   McbspaRegsFile    : > MCBSPA,      PAGE = 1
   McbspbRegsFile    : > MCBSPB,      PAGE = 1
/*** Peripheral Frame 1 Register Structures ***/
   ECanaRegsFile     : > ECANA,       PAGE = 1
   ECanaLAMRegsFile  : > ECANA_LAM    PAGE = 1
   ECanaMboxesFile   : > ECANA_MBOX   PAGE = 1
   ECanaMOTSRegsFile : > ECANA_MOTS   PAGE = 1
   ECanaMOTORegsFile : > ECANA_MOTO   PAGE = 1
   ECanbRegsFile     : > ECANB,       PAGE = 1
   ECanbLAMRegsFile  : > ECANB_LAM    PAGE = 1
   ECanbMboxesFile   : > ECANB_MBOX   PAGE = 1
   ECanbMOTSRegsFile : > ECANB_MOTS   PAGE = 1
   ECanbMOTORegsFile : > ECANB_MOTO   PAGE = 1
   EPwm1RegsFile     : > EPWM1        PAGE = 1
   EPwm2RegsFile     : > EPWM2        PAGE = 1
   EPwm3RegsFile     : > EPWM3        PAGE = 1
   EPwm4RegsFile     : > EPWM4        PAGE = 1
   EPwm5RegsFile     : > EPWM5        PAGE = 1
   EPwm6RegsFile     : > EPWM6        PAGE = 1
   ECap1RegsFile     : > ECAP1        PAGE = 1
   ECap2RegsFile     : > ECAP2        PAGE = 1
   ECap3RegsFile     : > ECAP3        PAGE = 1
   ECap4RegsFile     : > ECAP4        PAGE = 1
   ECap5RegsFile     : > ECAP5        PAGE = 1
   ECap6RegsFile     : > ECAP6        PAGE = 1
   EQep1RegsFile     : > EQEP1        PAGE = 1
   EQep2RegsFile     : > EQEP2        PAGE = 1
   GpioCtrlRegsFile  : > GPIOCTRL     PAGE = 1
   GpioDataRegsFile  : > GPIODAT      PAGE = 1
   GpioIntRegsFile   : > GPIOINT      PAGE = 1
/*** Peripheral Frame 2 Register Structures ***/
   SysCtrlRegsFile   : > SYSTEM,      PAGE = 1
   SpiaRegsFile      : > SPIA,        PAGE = 1
   SciaRegsFile      : > SCIA,        PAGE = 1
   XIntruptRegsFile  : > XINTRUPT,    PAGE = 1
   AdcRegsFile       : > ADC,         PAGE = 1
   ScibRegsFile      : > SCIB,        PAGE = 1
   ScicRegsFile      : > SCIC,        PAGE = 1
   I2caRegsFile      : > I2CA,        PAGE = 1
/*** Code Security Module Register Structures ***/
   CsmPwlFile        : > CSM_PWL,     PAGE = 1
/*** Device Part ID Register Structures ***/
   PartIdRegsFile    : > PARTID,      PAGE = 1
   /* Allocate program areas: */
   .cinit              : > FLASHA      PAGE = 0
   .init_array         : > FLASHA,     PAGE = 0
   .text               : > FLASHA      PAGE = 0
   codestart           : > BEGIN       PAGE = 0
/*** Digital Controller Library functions ***/
	dclfuncs		   : > RAML45,	   PAGE = 1
#ifdef __TI_COMPILER_VERSION__
    #if __TI_COMPILER_VERSION__ >= 15009000
        .TI.ramfunc : {} LOAD = FLASHA,
                         RUN = RAML0,
                         LOAD_START(_RamfuncsLoadStart),
                         LOAD_END(_RamfuncsLoadEnd),
                         RUN_START(_RamfuncsRunStart),
                         LOAD_SIZE(_RamfuncsLoadSize),
                         PAGE = 0
    #else
        ramfuncs       : LOAD = FLASHA,
                         RUN = RAML0,
                         PAGE = 0
							--library=sfra_f32_coff.lib<SFRA_F32_inject.obj>
							--library=sfra_f32_coff.lib<SFRA_F32_collect.obj>
    #endif
#endif
   csmpasswds          : > CSM_PWL     PAGE = 0
   csm_rsvd            : > CSM_RSVD    PAGE = 0
   /* Allocate uninitalized data sections: */
   .stack              : > RAMM1       PAGE = 1
   .bss                : > RAML45      PAGE = 1
   .sysmem             : > RAMM1       PAGE = 1
   .data			   : > RAML45      PAGE = 1
   /* Initalized sections go in Flash */
   /* For SDFlash to program these, they must be allocated to page 0 */
   .const              : > FLASHA      PAGE = 0
   .switch             : > FLASHA      PAGE = 0
   /* Allocate IQ math areas: */
   IQmath              : > FLASHC      PAGE = 0                  /* Math Code */
   IQmathTables     : > IQTABLES,  PAGE = 0, TYPE = NOLOAD
   /* Uncomment the section below if calling the IQNexp() or IQexp()
      functions from the IQMath.lib library in order to utilize the
      relevant IQ Math table in Boot ROM (This saves space and Boot ROM
      is 1 wait-state). If this section is not uncommented, IQmathTables2
      will be loaded into other memory (SARAM, Flash, etc.) and will take
      up space, but 0 wait-state is possible.
   IQmathTables2    : > IQTABLES2, PAGE = 0, TYPE = NOLOAD
              IQmath.lib<IQNexpTable.obj> (IQmathTablesRam)
   SFRA_F32_Data 	: > RAML45, PAGE = 1
//   FPUmathTables    : > FPUTABLES, PAGE = 0, TYPE = NOLOAD
FPUmathTables    : > RAML67, PAGE = 1//, TYPE = NOLOAD
//	FPUmathTables    : LOAD = FLASHB, PAGE = 0,
//                     RUN = RAML67,
//                     RUN_START(FPUmathTablesRunStart),
//                     LOAD_START(FPUmathTablesLoadStart),
//                     LOAD_SIZE(FPUmathTablesLoadSize),
//                     PAGE = 1
   /* Allocate DMA-accessible RAM sections: */
   DMARAML4         : > RAML45     PAGE = 1
   DMARAML5         : > RAML45,    PAGE = 1
   DMARAML6         : > RAML67,    PAGE = 1
   DMARAML7         : > RAML67,    PAGE = 1
   /* Allocate 0x400 of XINTF Zone 7 to storing data */
   ZONE7DATA        : > ZONE7B,    PAGE = 1
   /* .reset is a standard section used by the compiler.  It contains the */
   /* the address of the start of _c_int00 for C Code.   /*
   /* When using the boot ROM this section and the CPU vector */
   /* table is not needed.  Thus the default type is set here to  */
   /* DSECT  */
   .reset              : > RESET,      PAGE = 0, TYPE = DSECT
   vectors             : > VECTORS     PAGE = 0, TYPE = DSECT
   /* Allocate ADC_cal function (pre-programmed by factory into TI reserved memory) */
   .adc_cal     : load = ADC_CAL,   PAGE = 0, TYPE = NOLOAD
// End of file.
  • Hi Wilson,
    Yes that's correct on the boot mode switches, all GPIOs should be in the high (1) position before connecting the device to CCS.
    Have you tried starting with the Timed_LED_Blink example within C2000ware (C:\ti\C2000Ware_5_02_00_00\device_support\f2833x\examples\timed_led_blink) and replacing the 28335_RAM_lnk.cmd file with the F28335.cmd file? By testing this, you can check the flash version of the linker cmd file.
    Another thing to check out is the generated map file (likely placed in the Debug_Experimenter_Kit folder). Is any memory for a Flash section (A-H) being used?
    Thanks and regards,
    Charles
  • Charles,
    Thanks for your response. The code from my initial post is our version of the F28335.cmd file. Our application is meant to reside and run from Flash so, yes at this point Sector A is being used and more sectors will be used in the future. The problem is that the MCU is not booting from Flash and besides the right .cmd file and the boot mode GPIO set to high, I don't know why the MCU doesn't boot once I power-cycle (turning off and turning on) the board.
    I ran the timed_led_blink changing the .cmd file to F28335.cmd file and effectively it works once I power-cycle the system, the LED keeps blinking. I'm comparing both .cmd files but I don't see anything that should prevent the booting from flash from happening.
    The following is the content of our .map file.
                 TMS320C2000 Linker PC v22.6.0
    >> Linked Thu Apr 25 15:40:56 2024
    OUTPUT FILE NAME:   <I_Ctlr.out>
    ENTRY POINT SYMBOL: "_c_int00"  address: 0033af7c
    MEMORY CONFIGURATION
             name            origin    length      used     unused   attr    fill
    PAGE 0:
      ZONE0                 00004000   00001000  00000000  00001000  RWIX
      RAML0                 00008000   00001000  00000021  00000fdf  RWIX
      RAML1                 00009000   00001000  00000000  00001000  RWIX
      RAML2                 0000a000   00001000  00000000  00001000  RWIX
      RAML3                 0000b000   00001000  00000000  00001000  RWIX
      ZONE6                 00100000   00100000  00000000  00100000  RWIX
      ZONE7A                00200000   0000fc00  00000000  0000fc00  RWIX
      FLASHH                00300000   00008000  00000000  00008000  RWIX
      FLASHG                00308000   00008000  00000000  00008000  RWIX
      FLASHF                00310000   00008000  00000000  00008000  RWIX
      FLASHE                00318000   00008000  00000000  00008000  RWIX
      FLASHD                00320000   00008000  00000000  00008000  RWIX
      FLASHC                00328000   00008000  00000000  00008000  RWIX
      FLASHB                00330000   00008000  00000000  00008000  RWIX
      FLASHA                00338000   00007f80  00003214  00004d6c  RWIX
      CSM_RSVD              0033ff80   00000076  00000000  00000076  RWIX
      BEGIN                 0033fff6   00000002  00000002  00000000  RWIX
      CSM_PWL               0033fff8   00000008  00000000  00000008  RWIX
      ADC_CAL               00380080   00000009  00000007  00000002  RWIX
      OTP                   00380400   00000400  00000000  00000400  RWIX
      IQTABLES              003fe000   00000b50  00000000  00000b50  RWIX
      IQTABLES2             003feb50   0000008c  00000000  0000008c  RWIX
      ROM                   003ff27c   00000d44  00000000  00000d44  RWIX
      RESET                 003fffc0   00000002  00000000  00000002  RWIX
      VECTORS               003fffc2   0000003e  00000000  0000003e  RWIX
    PAGE 1:
      BOOT_RSVD             00000000   00000050  00000000  00000050  RWIX
      RAMM0                 00000050   000003b0  00000000  000003b0  RWIX
      RAMM1                 00000400   00000400  00000200  00000200  RWIX
      DEV_EMU               00000880   00000180  00000000  00000180  RWIX
      FLASH_REGS            00000a80   00000060  00000008  00000058  RWIX
      CSM                   00000ae0   00000010  00000010  00000000  RWIX
      ADC_MIRROR            00000b00   00000010  00000000  00000010  RWIX
      XINTF                 00000b20   00000020  0000001e  00000002  RWIX
      CPU_TIMER0            00000c00   00000008  00000008  00000000  RWIX
      CPU_TIMER1            00000c08   00000008  00000008  00000000  RWIX
      CPU_TIMER2            00000c10   00000008  00000008  00000000  RWIX
      PIE_CTRL              00000ce0   00000020  0000001a  00000006  RWIX
      PIE_VECT              00000d00   00000100  00000100  00000000  RWIX
      DMA                   00001000   00000200  00000000  00000200  RWIX
      MCBSPA                00005000   00000040  00000000  00000040  RWIX
      MCBSPB                00005040   00000040  00000000  00000040  RWIX
      ECANA                 00006000   00000040  00000000  00000040  RWIX
      ECANA_LAM             00006040   00000040  00000000  00000040  RWIX
      ECANA_MOTS            00006080   00000040  00000000  00000040  RWIX
      ECANA_MOTO            000060c0   00000040  00000000  00000040  RWIX
      ECANA_MBOX            00006100   00000100  00000000  00000100  RWIX
      ECANB                 00006200   00000040  00000000  00000040  RWIX
      ECANB_LAM             00006240   00000040  00000000  00000040  RWIX
      ECANB_MOTS            00006280   00000040  00000000  00000040  RWIX
      ECANB_MOTO            000062c0   00000040  00000000  00000040  RWIX
      ECANB_MBOX            00006300   00000100  00000000  00000100  RWIX
      EPWM1                 00006800   00000022  00000022  00000000  RWIX
      EPWM2                 00006840   00000022  00000022  00000000  RWIX
      EPWM3                 00006880   00000022  00000022  00000000  RWIX
      EPWM4                 000068c0   00000022  00000000  00000022  RWIX
      EPWM5                 00006900   00000022  00000000  00000022  RWIX
      EPWM6                 00006940   00000022  00000000  00000022  RWIX
      ECAP1                 00006a00   00000020  00000000  00000020  RWIX
      ECAP2                 00006a20   00000020  00000000  00000020  RWIX
      ECAP3                 00006a40   00000020  00000000  00000020  RWIX
      ECAP4                 00006a60   00000020  00000000  00000020  RWIX
      ECAP5                 00006a80   00000020  00000000  00000020  RWIX
      ECAP6                 00006aa0   00000020  00000000  00000020  RWIX
      EQEP1                 00006b00   00000040  00000000  00000040  RWIX
      EQEP2                 00006b40   00000040  00000000  00000040  RWIX
      GPIOCTRL              00006f80   00000040  0000002e  00000012  RWIX
      GPIODAT               00006fc0   00000020  00000020  00000000  RWIX
      GPIOINT               00006fe0   00000020  00000000  00000020  RWIX
      SYSTEM                00007010   00000020  00000020  00000000  RWIX
      SPIA                  00007040   00000010  00000000  00000010  RWIX
      SCIA                  00007050   00000010  00000000  00000010  RWIX
      XINTRUPT              00007070   00000010  00000000  00000010  RWIX
      ADC                   00007100   00000020  0000001e  00000002  RWIX
      SCIB                  00007750   00000010  00000000  00000010  RWIX
      SCIC                  00007770   00000010  00000000  00000010  RWIX
      I2CA                  00007900   00000040  00000000  00000040  RWIX
      RAML45                0000c000   00002000  00000cd8  00001328  RWIX
      RAML67                0000e000   00002000  0000075c  000018a4  RWIX
      ZONE7B                0020fc00   00000400  00000000  00000400  RWIX
      CSM_PWL               0033fff8   00000008  00000008  00000000  RWIX
      PARTID                00380090   00000001  00000000  00000001  RWIX
    SECTION ALLOCATION MAP
     output                                  attributes/
    section   page    origin      length       input sections
    PieVectTableFile
    *          1    00000d00    00000100     UNINITIALIZED
                      00000d00    00000100     DSP2833x_GlobalVariableDefs.obj (PieVectTableFile)
    FlashRegsFile
    *          1    00000a80    00000008     UNINITIALIZED
                      00000a80    00000008     DSP2833x_GlobalVariableDefs.obj (FlashRegsFile)
    CsmRegsFile
    *          1    00000ae0    00000010     UNINITIALIZED
                      00000ae0    00000010     DSP2833x_GlobalVariableDefs.obj (CsmRegsFile)
    XintfRegsFile
    *          1    00000b20    0000001e     UNINITIALIZED
                      00000b20    0000001e     DSP2833x_GlobalVariableDefs.obj (XintfRegsFile)
    CpuTimer0RegsFile
    *          1    00000c00    00000008     UNINITIALIZED
                      00000c00    00000008     DSP2833x_GlobalVariableDefs.obj (CpuTimer0RegsFile)
    CpuTimer1RegsFile
    *          1    00000c08    00000008     UNINITIALIZED
                      00000c08    00000008     DSP2833x_GlobalVariableDefs.obj (CpuTimer1RegsFile)
    CpuTimer2RegsFile
    *          1    00000c10    00000008     UNINITIALIZED
                      00000c10    00000008     DSP2833x_GlobalVariableDefs.obj (CpuTimer2RegsFile)
    PieCtrlRegsFile
    *          1    00000ce0    0000001a     UNINITIALIZED
                      00000ce0    0000001a     DSP2833x_GlobalVariableDefs.obj (PieCtrlRegsFile)
    EPwm1RegsFile
    *          1    00006800    00000022     UNINITIALIZED
                      00006800    00000022     DSP2833x_GlobalVariableDefs.obj (EPwm1RegsFile)
    EPwm2RegsFile
    *          1    00006840    00000022     UNINITIALIZED
                      00006840    00000022     DSP2833x_GlobalVariableDefs.obj (EPwm2RegsFile)
    EPwm3RegsFile
    *          1    00006880    00000022     UNINITIALIZED
                      00006880    00000022     DSP2833x_GlobalVariableDefs.obj (EPwm3RegsFile)
    GpioCtrlRegsFile
    *          1    00006f80    0000002e     UNINITIALIZED
                      00006f80    0000002e     DSP2833x_GlobalVariableDefs.obj (GpioCtrlRegsFile)
    GpioDataRegsFile
    *          1    00006fc0    00000020     UNINITIALIZED
                      00006fc0    00000020     DSP2833x_GlobalVariableDefs.obj (GpioDataRegsFile)
    SysCtrlRegsFile
    *          1    00007010    00000020     UNINITIALIZED
                      00007010    00000020     DSP2833x_GlobalVariableDefs.obj (SysCtrlRegsFile)
    AdcRegsFile
    *          1    00007100    0000001e     UNINITIALIZED
                      00007100    0000001e     DSP2833x_GlobalVariableDefs.obj (AdcRegsFile)
    CsmPwlFile
    *          1    0033fff8    00000008     UNINITIALIZED
                      0033fff8    00000008     DSP2833x_GlobalVariableDefs.obj (CsmPwlFile)
    .cinit     0    0033b144    000000d0
                      0033b144    00000034     (.cinit..data.load) [load image, compression = lzss]
                      0033b178    00000006     (__TI_handler_table)
                      0033b17e    00000004     (.cinit..bss.load) [load image, compression = zero_init]
                      0033b182    00000004     (.cinit.AdcRegsFile.load) [load image, compression = zero_init]
                      0033b186    00000004     (.cinit.CpuTimer0RegsFile.load) [load image, compression = zero_init]
                      0033b18a    00000004     (.cinit.CpuTimer1RegsFile.load) [load image, compression = zero_init]
                      0033b18e    00000004     (.cinit.CpuTimer2RegsFile.load) [load image, compression = zero_init]
                      0033b192    00000004     (.cinit.CsmPwlFile.load) [load image, compression = zero_init]
                      0033b196    00000004     (.cinit.CsmRegsFile.load) [load image, compression = zero_init]
                      0033b19a    00000004     (.cinit.EPwm1RegsFile.load) [load image, compression = zero_init]
                      0033b19e    00000004     (.cinit.EPwm2RegsFile.load) [load image, compression = zero_init]
                      0033b1a2    00000004     (.cinit.EPwm3RegsFile.load) [load image, compression = zero_init]
                      0033b1a6    00000004     (.cinit.FlashRegsFile.load) [load image, compression = zero_init]
                      0033b1aa    00000004     (.cinit.GpioCtrlRegsFile.load) [load image, compression = zero_init]
                      0033b1ae    00000004     (.cinit.GpioDataRegsFile.load) [load image, compression = zero_init]
                      0033b1b2    00000004     (.cinit.PieCtrlRegsFile.load) [load image, compression = zero_init]
                      0033b1b6    00000004     (.cinit.PieVectTableFile.load) [load image, compression = zero_init]
                      0033b1ba    00000004     (.cinit.SFRA_F32_Data.load) [load image, compression = zero_init]
                      0033b1be    00000004     (.cinit.SysCtrlRegsFile.load) [load image, compression = zero_init]
                      0033b1c2    00000004     (.cinit.XintfRegsFile.load) [load image, compression = zero_init]
                      0033b1c6    00000002     --HOLE-- [fill = 0]
                      0033b1c8    0000004c     (__TI_cinit_table)
    .init_array
    *          0    00338000    00000000     UNINITIALIZED
    .TI.ramfunc
    *          0    00338000    00000021     RUN ADDR = 00008000
                      00338000    0000001d     DSP2833x_SysCtrl.obj (.TI.ramfunc)
                      0033801d    00000004     DSP2833x_usDelay.obj (.TI.ramfunc)
    .text      0    00338021    00002fb5
                      00338021    000012fb     PowerMgmt_Svc.obj (.text)
                      0033931c    000005ef     HAL.obj (.text)
                      0033990b    00000585     PowerMgmt_Svc.obj (.text:retain)
                      00339e90    00000316     DSP2833x_DefaultIsr.obj (.text:retain)
                      0033a1a6    000001fa     sfra_f32_tmu_eabi.lib : sfra_f32_tmu_background.obj (.text)
                      0033a3a0    000001c2                           : sfra_f32_tmu_config_reset.obj (.text)
                      0033a562    0000015a     PWM_Driver.obj (.text)
                      0033a6bc    0000013e     HAL.obj (.text:retain)
                      0033a7fa    00000103     NTC_100k.obj (.text)
                      0033a8fd    000000f0     DSP2833x_SysCtrl.obj (.text)
                      0033a9ed    0000009e     ADC_Svc.obj (.text)
                      0033aa8b    0000009c     rts2800_fpu32_eabi.lib : fd_add28.asm.obj (.text)
                      0033ab27    00000083                            : fd_mpy28.asm.obj (.text)
                      0033abaa    00000071     faultHandler_Svc.obj (.text)
                      0033ac1b    00000062     rts2800_fpu32_eabi.lib : s_tanf.c.obj (.text)
                      0033ac7d    0000005e     ADC_Driver.obj (.text)
                      0033acdb    00000056     DSP2833x_CpuTimers.obj (.text)
                      0033ad31    00000053     MainApp.obj (.text)
                      0033ad84    00000038     rts2800_fpu32_fast_supplement_eabi.lib : log_f32.obj (.text)
                      0033adbc    00000034                                            : sin_f32.obj (.text)
                      0033adf0    0000002e     rts2800_fpu32_eabi.lib : copy_decompress_lzss.c.obj (.text:decompress:lzss)
                      0033ae1e    0000002b                            : autoinit.c.obj (.text:__TI_auto_init_nobinit_nopinit)
                      0033ae49    0000002a                            : l_div28.asm.obj (.text)
                      0033ae73    00000029                            : exit.c.obj (.text)
                      0033ae9c    00000028     DSP2833x_PieCtrl.obj (.text)
                      0033aec4    00000023     rts2800_fpu32_eabi.lib : fd_tofsfpu32.asm.obj (.text)
                      0033aee7    00000022     DSP2833x_CodeStartBranch.obj (.text)
                      0033af09    00000021     rts2800_fpu32_fast_supplement_eabi.lib : sqrt_f32.obj (.text)
                      0033af2a    0000001d     rts2800_fpu32_eabi.lib : memcpy.c.obj (.text)
                      0033af47    0000001c                            : fs_tofdfpu32.asm.obj (.text)
                      0033af63    00000019     rts2800_fpu32_fast_supplement_eabi.lib : div_f32.obj (.text)
                      0033af7c    00000017     rts2800_fpu32_eabi.lib : boot28.asm.obj (.text)
                      0033af93    00000011     DSP2833x_PieVect.obj (.text)
                      0033afa4    0000000e     main.obj (.text)
                      0033afb2    0000000c     rts2800_fpu32_eabi.lib : args_main.c.obj (.text)
                      0033afbe    00000008                            : copy_decompress_none.c.obj (.text:decompress:none)
                      0033afc6    00000006                            : copy_zero_init.c.obj (.text:decompress:ZI)
                      0033afcc    00000006                            : memset.c.obj (.text)
                      0033afd2    00000002                            : pre_init.c.obj (.text)
                      0033afd4    00000001                            : _lock.c.obj (.text)
                      0033afd5    00000001                            : startup.c.obj (.text)
    codestart
    *          0    0033fff6    00000002
                      0033fff6    00000002     DSP2833x_CodeStartBranch.obj (codestart)
    dclfuncs   1    0000cc76    00000055
                      0000cc76    0000002f     DCL_DF22_C1.obj (dclfuncs)
                      0000cca5    00000001     --HOLE-- [fill = 0]
                      0000cca6    00000025     DCL_PI_C4.obj (dclfuncs)
    .const     0    0033afd6    0000016e
                      0033afd6    0000000c     ADC_Svc.obj (.const)
                      0033afe2    00000008     HAL.obj (.const)
                      0033afea    00000004     PowerMgmt_Svc.obj (.const)
                      0033afee    00000012     --HOLE-- [fill = 0]
                      0033b000    00000100     DSP2833x_PieVect.obj (.const)
                      0033b100    00000044     NTC_100k.obj (.const:NTC_100k_LUT$1$2)
    .stack     1    00000400    00000200     UNINITIALIZED
                      00000400    00000200     --HOLE--
    .bss       1    0000c000    000008ac     UNINITIALIZED
                      0000c000    0000048a     PowerMgmt_Svc.obj (.bss)
                      0000c48a    000000c8     PowerMgmt_Svc.obj (.bss:freqVect)
                      0000c552    000000c8     PowerMgmt_Svc.obj (.bss:olMagVect)
                      0000c61a    000000c8     PowerMgmt_Svc.obj (.bss:olPhaseVect)
                      0000c6e2    000000c8     PowerMgmt_Svc.obj (.bss:plantMagVect)
                      0000c7aa    000000c8     PowerMgmt_Svc.obj (.bss:plantPhaseVect)
                      0000c872    0000000e     --HOLE--
                      0000c880    00000018     DSP2833x_CpuTimers.obj (.bss)
                      0000c898    00000014     PowerMgmt_Svc.obj (.bss:pfc_vBusMeasBuff_pu)
    .data      1    0000c8c0    000003b5     UNINITIALIZED
                      0000c8c0    000002be     PowerMgmt_Svc.obj (.data)
                      0000cb7e    00000002     rts2800_fpu32_eabi.lib : _lock.c.obj (.data:_lock)
                      0000cb80    00000050     HAL.obj (.data)
                      0000cbd0    0000003c     faultHandler_Svc.obj (.data:DTC_list)
                      0000cc0c    00000020     ADC_Svc.obj (.data)
                      0000cc2c    00000008     HAL.obj (.data:hsTemp_buffer_s)
                      0000cc34    00000008     HAL.obj (.data:ioutL1_buffer_s)
                      0000cc3c    00000008     HAL.obj (.data:ioutL3_buffer_s)
                      0000cc44    00000008     HAL.obj (.data:ioutl2_buffer_s)
                      0000cc4c    00000008     HAL.obj (.data:ishunt_buffer_s)
                      0000cc54    00000008     HAL.obj (.data:vbus_buffer_s)
                      0000cc5c    00000008     HAL.obj (.data:vgridL2_buffer_s)
                      0000cc64    00000008     HAL.obj (.data:vgridl1_buffer_s)
                      0000cc6c    00000006     rts2800_fpu32_eabi.lib : exit.c.obj (.data)
                      0000cc72    00000002     faultHandler_Svc.obj (.data)
                      0000cc74    00000001     PWM_Driver.obj (.data)
    SFRA_F32_Data
    *          1    0000cccc    00000022     UNINITIALIZED
                      0000cccc    00000022     sfra_f32_tmu_eabi.lib : sfra_f32_tmu_config_reset.obj (SFRA_F32_Data)
    FPUmathTables
    *          1    0000e000    0000075c
                      0000e000    0000068c     rts2800_fpu32_fast_supplement_eabi.lib : FPUmathTables.obj (FPUmathTables)
                      0000e68c    000000d0                                            : logtable_f32.obj (FPUmathTables)
    .reset     0    003fffc0    00000000     DSECT
    vectors    0    003fffc2    00000000     DSECT
    .adc_cal   0    00380080    00000007     NOLOAD SECTION
                      00380080    00000007     DSP2833x_ADC_cal.obj (.adc_cal)
    MODULE SUMMARY
           Module                            code    ro data   rw data
           MainApp.obj                       83      0         0
           main.obj                          14      0         0
           Total:                            97      0         0
        .\Drivers\
           PWM_Driver.obj                    346     0         1
           NTC_100k.obj                      259     68        0
           ADC_Driver.obj                    94      0         0
           Total:                            699     68        1
        .\F28335_Drivers\
           DSP2833x_DefaultIsr.obj           790     0         0
           DSP2833x_GlobalVariableDefs.obj   0       0         610
           DSP2833x_SysCtrl.obj              298     0         0
           DSP2833x_PieVect.obj              17      256       0
           DSP2833x_CpuTimers.obj            86      0         24
           DSP2833x_PieCtrl.obj              40      0         0
           DSP2833x_CodeStartBranch.obj      36      0         0
           DSP2833x_usDelay.obj              8       0         0
           DSP2833x_ADC_cal.obj              7       0         0
           Total:                            1282    256       634
        .\HAL\
           HAL.obj                           1837    8         144
           Total:                            1837    8         144
        .\Libraries\DCL\source\
           DCL_DF22_C1.obj                   47      0         0
           DCL_PI_C4.obj                     37      0         0
           Total:                            84      0         0
        .\Services\
           PowerMgmt_Svc.obj                 6272    4         2884
           ADC_Svc.obj                       158     12        32
           faultHandler_Svc.obj              113     0         62
           Total:                            6543    16        2978
        ../Libraries/sfra/sfra_f32_tmu_eabi.lib
           sfra_f32_tmu_background.obj       506     0         0
           sfra_f32_tmu_config_reset.obj     450     0         34
           Total:                            956     0         34
        C:/TI/ti-cgt-c2000_22.6.0.LTS/lib/rts2800_fpu32_eabi.lib
           fd_add28.asm.obj                  156     0         0
           fd_mpy28.asm.obj                  131     0         0
           s_tanf.c.obj                      98      0         0
           exit.c.obj                        41      0         6
           copy_decompress_lzss.c.obj        46      0         0
           autoinit.c.obj                    43      0         0
           l_div28.asm.obj                   42      0         0
           fd_tofsfpu32.asm.obj              35      0         0
           memcpy.c.obj                      29      0         0
           fs_tofdfpu32.asm.obj              28      0         0
           boot28.asm.obj                    23      0         0
           args_main.c.obj                   12      0         0
           copy_decompress_none.c.obj        8       0         0
           copy_zero_init.c.obj              6       0         0
           memset.c.obj                      6       0         0
           _lock.c.obj                       1       0         2
           pre_init.c.obj                    2       0         0
           startup.c.obj                     1       0         0
           Total:                            708     0         8
        C:/ti/c2000/C2000Ware_4_02_00_00/libraries/math/FPUfastRTS/c28/lib/rts2800_fpu32_fast_supplement_eabi.lib
           FPUmathTables.obj                 0       1676      0
           logtable_f32.obj                  0       208       0
           log_f32.obj                       56      0         0
           sin_f32.obj                       52      0         0
           sqrt_f32.obj                      33      0         0
           div_f32.obj                       25      0         0
           Total:                            166     1884      0
           Stack:                            0       0         512
           Linker Generated:                 0       206       0
           Grand Total:                      12372   2438      4311
    LINKER GENERATED COPY TABLES
    __TI_cinit_table @ 0033b1c8 records: 19, size/record: 4, table size: 76
    	.data: load addr=0033b144, load size=00000034 bytes, run addr=0000c8c0, run size=000003b5 bytes, compression=lzss
    	.bss: load addr=0033b17e, load size=00000004 bytes, run addr=0000c000, run size=000008ac bytes, compression=zero_init
    	AdcRegsFile: load addr=0033b182, load size=00000004 bytes, run addr=00007100, run size=0000001e bytes, compression=zero_init
    	CpuTimer0RegsFile: load addr=0033b186, load size=00000004 bytes, run addr=00000c00, run size=00000008 bytes, compression=zero_init
    	CpuTimer1RegsFile: load addr=0033b18a, load size=00000004 bytes, run addr=00000c08, run size=00000008 bytes, compression=zero_init
    	CpuTimer2RegsFile: load addr=0033b18e, load size=00000004 bytes, run addr=00000c10, run size=00000008 bytes, compression=zero_init
    	CsmPwlFile: load addr=0033b192, load size=00000004 bytes, run addr=0033fff8, run size=00000008 bytes, compression=zero_init
    	CsmRegsFile: load addr=0033b196, load size=00000004 bytes, run addr=00000ae0, run size=00000010 bytes, compression=zero_init
    	EPwm1RegsFile: load addr=0033b19a, load size=00000004 bytes, run addr=00006800, run size=00000022 bytes, compression=zero_init
    	EPwm2RegsFile: load addr=0033b19e, load size=00000004 bytes, run addr=00006840, run size=00000022 bytes, compression=zero_init
    	EPwm3RegsFile: load addr=0033b1a2, load size=00000004 bytes, run addr=00006880, run size=00000022 bytes, compression=zero_init
    	FlashRegsFile: load addr=0033b1a6, load size=00000004 bytes, run addr=00000a80, run size=00000008 bytes, compression=zero_init
    	GpioCtrlRegsFile: load addr=0033b1aa, load size=00000004 bytes, run addr=00006f80, run size=0000002e bytes, compression=zero_init
    	GpioDataRegsFile: load addr=0033b1ae, load size=00000004 bytes, run addr=00006fc0, run size=00000020 bytes, compression=zero_init
    	PieCtrlRegsFile: load addr=0033b1b2, load size=00000004 bytes, run addr=00000ce0, run size=0000001a bytes, compression=zero_init
    	PieVectTableFile: load addr=0033b1b6, load size=00000004 bytes, run addr=00000d00, run size=00000100 bytes, compression=zero_init
    	SFRA_F32_Data: load addr=0033b1ba, load size=00000004 bytes, run addr=0000cccc, run size=00000022 bytes, compression=zero_init
    	SysCtrlRegsFile: load addr=0033b1be, load size=00000004 bytes, run addr=00007010, run size=00000020 bytes, compression=zero_init
    	XintfRegsFile: load addr=0033b1c2, load size=00000004 bytes, run addr=00000b20, run size=0000001e bytes, compression=zero_init
    LINKER GENERATED HANDLER TABLE
    __TI_handler_table @ 0033b178 records: 3, size/record: 2, table size: 6
    	index: 0, handler: __TI_zero_init
    	index: 1, handler: __TI_decompress_lzss
    	index: 2, handler: __TI_decompress_none
    GLOBAL DATA SYMBOLS: SORTED BY DATA PAGE
    address     data page           name
    00000400      10 (00000400)     __stack
    00000a80      2a (00000a80)     FlashRegs
    00000ae0      2b (00000ac0)     CsmRegs
    00000b20      2c (00000b00)     XintfRegs
    00000c00      30 (00000c00)     CpuTimer0Regs
    00000c08      30 (00000c00)     CpuTimer1Regs
    00000c10      30 (00000c00)     CpuTimer2Regs
    00000ce0      33 (00000cc0)     PieCtrlRegs
    00000d00      34 (00000d00)     PieVectTable
    00006800     1a0 (00006800)     EPwm1Regs
    00006840     1a1 (00006840)     EPwm2Regs
    00006880     1a2 (00006880)     EPwm3Regs
    00006f80     1be (00006f80)     GpioCtrlRegs
    00006fc0     1bf (00006fc0)     GpioDataRegs
    00007010     1c0 (00007000)     SysCtrlRegs
    00007100     1c4 (00007100)     AdcRegs
    0000c000     300 (0000c000)     clampactive
    0000c001     300 (0000c000)     EPwm1_DB_Direction
    0000c002     300 (0000c000)     EPwm2_DB_Direction
    0000c003     300 (0000c000)     EPwm3_DB_Direction
    0000c004     300 (0000c000)     acDrop_flag
    0000c005     300 (0000c000)     brownOut_flag
    0000c006     300 (0000c000)     updatecoeff
    0000c007     300 (0000c000)     guiInvRMSStart
    0000c008     300 (0000c000)     guiInvRMSStop
    0000c009     300 (0000c000)     slewState
    0000c00a     300 (0000c000)     i
    0000c00b     300 (0000c000)     offsetCalCounter
    0000c00c     300 (0000c000)     invDutyL1
    0000c00d     300 (0000c000)     invDutyL2
    0000c00e     300 (0000c000)     invDutyCtlr
    0000c00f     300 (0000c000)     invDutyCompl
    0000c010     300 (0000c000)     closeILoopInv
    0000c011     300 (0000c000)     closeVLoopInv
    0000c012     300 (0000c000)     clearInvTrip
    0000c013     300 (0000c000)     rlyConnect
    0000c014     300 (0000c000)     zeroCrossDetectFlag
    0000c015     300 (0000c000)     cyclePolarityFlag
    0000c016     300 (0000c000)     period
    0000c017     300 (0000c000)     pfc_highPowerTrans_flag
    0000c018     300 (0000c000)     pfc_v_adc_counts_min
    0000c019     300 (0000c000)     pfc_v_adc_counts_max
    0000c01a     300 (0000c000)     pfc_vL1_adc_counts_min
    0000c01b     300 (0000c000)     pfc_vL1_adc_counts_max
    0000c01c     300 (0000c000)     pfc_vL2_adc_counts_min
    0000c01d     300 (0000c000)     pfc_vL2_adc_counts_max
    0000c01e     300 (0000c000)     pfc_i_adc_counts_min
    0000c01f     300 (0000c000)     pfc_i_adc_counts_max
    0000c022     300 (0000c000)     gv_out
    0000c024     300 (0000c000)     gv_out_scaled
    0000c026     300 (0000c000)     gv_outL1
    0000c028     300 (0000c000)     gv_out_scaledL1
    0000c02a     300 (0000c000)     gv_outL2
    0000c02c     300 (0000c000)     gv_out_scaledL2
    0000c02e     300 (0000c000)     gv_lead_lag_out
    0000c030     300 (0000c000)     guiVbus
    0000c032     300 (0000c000)     guiVbusMax
    0000c034     300 (0000c000)     guiVbusMin
    0000c036     300 (0000c000)     guiVacMax
    0000c038     300 (0000c000)     guiVacMin
    0000c03a     300 (0000c000)     guiVin
    0000c03c     300 (0000c000)     guiIL
    0000c03e     300 (0000c000)     pfc_ac_volRmsEma_sensed_Volts
    0000c040     301 (0000c040)     guiACFreq
    0000c042     301 (0000c040)     guiPrms
    0000c044     301 (0000c040)     guiIrms
    0000c046     301 (0000c040)     guiVrms
    0000c048     301 (0000c040)     guiVavg
    0000c04a     301 (0000c040)     guiVo
    0000c04c     301 (0000c040)     guiIi
    0000c04e     301 (0000c040)     guiIo
    0000c050     301 (0000c040)     guiPowerFactor
    0000c052     301 (0000c040)     guiVA
    0000c054     301 (0000c040)     guiFreqAvg
    0000c056     301 (0000c040)     guiVema
    0000c058     301 (0000c040)     EPwm1TimerIntCount
    0000c05a     301 (0000c040)     EPwm2TimerIntCount
    0000c05c     301 (0000c040)     EPwm3TimerIntCount
    0000c05e     301 (0000c040)     acSine_regen
    0000c060     301 (0000c040)     acCosine_regen
    0000c062     301 (0000c040)     regen_theta
    0000c064     301 (0000c040)     acSine_regen_freq
    0000c066     301 (0000c040)     acSine_regen_ISRperiod
    0000c068     301 (0000c040)     ac_vol_regen_Volts
    0000c06a     301 (0000c040)     ac_vol_regen_magnitude
    0000c06c     301 (0000c040)     ac_volRMS_regen_Volts
    0000c06e     301 (0000c040)     ISR2_Loading
    0000c070     301 (0000c040)     ISR2_LoadingAvg
    0000c072     301 (0000c040)     regen_cnt
    0000c074     301 (0000c040)     regen_cnt_Max
    0000c076     301 (0000c040)     spll_regen_syncOn
    0000c078     301 (0000c040)     acDrop_cnt
    0000c07a     301 (0000c040)     gi_out
    0000c07c     301 (0000c040)     gi_outL1
    0000c07e     301 (0000c040)     gi_outL2
    0000c080     302 (0000c080)     gi_lead_lag_out
    0000c082     302 (0000c080)     gi_notch1_out
    0000c084     302 (0000c080)     gi_notch2_out
    0000c086     302 (0000c080)     kpI_1H
    0000c088     302 (0000c080)     kiI_1H
    0000c08a     302 (0000c080)     kiI_3H
    0000c08c     302 (0000c080)     kiI_5H
    0000c08e     302 (0000c080)     kiI_7H
    0000c090     302 (0000c080)     kiI_9H
    0000c092     302 (0000c080)     woI_1H
    0000c094     302 (0000c080)     woI_3H
    0000c096     302 (0000c080)     woI_5H
    0000c098     302 (0000c080)     woI_7H
    0000c09a     302 (0000c080)     woI_9H
    0000c09c     302 (0000c080)     wrcI_1H
    0000c09e     302 (0000c080)     wrcI_3H
    0000c0a0     302 (0000c080)     wrcI_5H
    0000c0a2     302 (0000c080)     wrcI_7H
    0000c0a4     302 (0000c080)     wrcI_9H
    0000c0a6     302 (0000c080)     kpV_1H
    0000c0a8     302 (0000c080)     kiV_1H
    0000c0aa     302 (0000c080)     kiV_3H
    0000c0ac     302 (0000c080)     kiV_5H
    0000c0ae     302 (0000c080)     kiV_7H
    0000c0b0     302 (0000c080)     woV_1H
    0000c0b2     302 (0000c080)     woV_3H
    0000c0b4     302 (0000c080)     woV_5H
    0000c0b6     302 (0000c080)     woV_7H
    0000c0b8     302 (0000c080)     wrcV_1H
    0000c0ba     302 (0000c080)     wrcV_3H
    0000c0bc     302 (0000c080)     wrcV_5H
    0000c0be     302 (0000c080)     wrcV_7H
    0000c0c0     303 (0000c0c0)     c2
    0000c0c2     303 (0000c0c0)     c1
    0000c0c4     303 (0000c0c0)     Phase_Jump
    0000c0c6     303 (0000c0c0)     Phase_Jump_Trig
    0000c0c8     303 (0000c0c0)     acFreq_lpf
    0000c0ca     303 (0000c0c0)     acVoltage_avg
    0000c0cc     303 (0000c0c0)     gridFreqNominal
    0000c0ce     303 (0000c0c0)     gridVrmsNominal
    0000c0d0     303 (0000c0c0)     gridVrmsAvg
    0000c0d2     303 (0000c0c0)     invIiL1Inst
    0000c0d4     303 (0000c0c0)     invIiL2Inst
    0000c0d6     303 (0000c0c0)     invIiL3Inst
    0000c0d8     303 (0000c0c0)     invIiShuntInst
    0000c0da     303 (0000c0c0)     invVoL1Inst
    0000c0dc     303 (0000c0c0)     invVoL2Inst
    0000c0de     303 (0000c0c0)     invVoL1L2Inst
    0000c0e0     303 (0000c0c0)     invVoL3Inst
    0000c0e2     303 (0000c0c0)     invViL1Inst
    0000c0e4     303 (0000c0c0)     invViL2Inst
    0000c0e6     303 (0000c0c0)     invViL1L2Inst
    0000c0e8     303 (0000c0c0)     invViL3Inst
    0000c0ea     303 (0000c0c0)     invIiOffset
    0000c0ec     303 (0000c0c0)     invIfInst
    0000c0ee     303 (0000c0c0)     invIfSDOffset
    0000c0f0     303 (0000c0c0)     invIoInst
    0000c0f2     303 (0000c0c0)     invIoSDOffset
    0000c0f4     303 (0000c0c0)     invVoOffset
    0000c0f6     303 (0000c0c0)     invVoSDOffset
    0000c0f8     303 (0000c0c0)     invVbusInst
    0000c0fa     303 (0000c0c0)     vbus_div
    0000c0fc     303 (0000c0c0)     vbus_fbk_flt
    0000c0fe     303 (0000c0c0)     invVbusOffset
    0000c100     304 (0000c100)     invVbusSDOffset
    0000c102     304 (0000c100)     invVbusAvg
    0000c104     304 (0000c100)     invModIndex
    0000c106     304 (0000c100)     pfcIiRef
    0000c108     304 (0000c100)     invIoRef
    0000c10a     304 (0000c100)     invVoRef
    0000c10c     304 (0000c100)     invVoRefL1
    0000c10e     304 (0000c100)     invVoRefL2
    0000c110     304 (0000c100)     invIiRefInst
    0000c112     304 (0000c100)     invIoRefInst
    0000c114     304 (0000c100)     invVoRefInst
    0000c116     304 (0000c100)     invVoRefLast
    0000c118     304 (0000c100)     invVoRefInstL1
    0000c11a     304 (0000c100)     invVoRefLastL1
    0000c11c     304 (0000c100)     invVoRefInstL2
    0000c11e     304 (0000c100)     invVoRefLastL2
    0000c120     304 (0000c100)     invVbusRef
    0000c122     304 (0000c100)     voltage_error
    0000c124     304 (0000c100)     voltage_errorL1
    0000c126     304 (0000c100)     voltage_errorL2
    0000c128     304 (0000c100)     offset165
    0000c12a     304 (0000c100)     invDutyPU
    0000c12c     304 (0000c100)     invDutyPUPrev
    0000c12e     304 (0000c100)     invDutyPUCtlr
    0000c130     304 (0000c100)     invSine
    0000c132     304 (0000c100)     invSinePrev
    0000c134     304 (0000c100)     invSineFull
    0000c136     304 (0000c100)     IQCMPRA
    0000c138     304 (0000c100)     IQCMPRA_tmp
    0000c13a     304 (0000c100)     IQCMPRAL1
    0000c13c     304 (0000c100)     IQCMPRA_tmpL1
    0000c13e     304 (0000c100)     IQCMPRAL2
    0000c140     305 (0000c140)     IQCMPRA_tmpL2
    0000c142     305 (0000c140)     BiINV_board_Mode
    0000c144     305 (0000c140)     BiINV_pwm_SwState
    0000c146     305 (0000c140)     BiINV_board_State
    0000c148     305 (0000c140)     BiINV_board_Status
    0000c14a     305 (0000c140)     pfc_dutyPU
    0000c14c     305 (0000c140)     pfc_dutyPU_DC
    0000c14e     305 (0000c140)     pfc_thetaOffset_pu
    0000c150     305 (0000c140)     pfc_spll_sine
    0000c152     305 (0000c140)     pfc_spll_cosine
    0000c154     305 (0000c140)     pfc_ac_sign_filtered
    0000c156     305 (0000c140)     pfc_ac_L_sensed_pu
    0000c158     305 (0000c140)     pfc_ac_N_sensed_pu
    0000c15a     305 (0000c140)     pfc_ac_vol_sensed_pu
    0000c15c     305 (0000c140)     pfc_ac_volL1_sensed_pu
    0000c15e     305 (0000c140)     pfc_ac_volL2_sensed_pu
    0000c160     305 (0000c140)     pfc_vACLMeasOffset_pu
    0000c162     305 (0000c140)     pfc_vACNMeasOffset_pu
    0000c164     305 (0000c140)     pfc_vACMeasOffset_pu
    0000c166     305 (0000c140)     pfc_ac_cur_sensed_pu
    0000c168     305 (0000c140)     pfc_iLVrefMeas_pu
    0000c16a     305 (0000c140)     pfc_ac_cur_ref_pu
    0000c16c     305 (0000c140)     pfc_ac_cur_ref_inst_pu
    0000c16e     305 (0000c140)     pfc_ac_cur_ref_inst_prev_pu
    0000c170     305 (0000c140)     pfc_vBusAvg_pu
    0000c172     305 (0000c140)     pfc_vACRmsMeasAvg_pu
    0000c174     305 (0000c140)     pfc_inductor_voltage_drop_feedforward
    0000c176     305 (0000c140)     pfc_vBus_sensed_pu
    0000c178     305 (0000c140)     pfc_vBusMeasOffset_pu
    0000c17a     305 (0000c140)     pfc_vBusRef_pu
    0000c17c     305 (0000c140)     pfc_vBus_sensedFiltered_notch1
    0000c17e     305 (0000c140)     pfc_vBus_sensedFiltered_notch2
    0000c180     306 (0000c180)     pfc_closeGiLoop
    0000c182     306 (0000c180)     pfc_closeGvLoop
    0000c184     306 (0000c180)     pfc_relayConnect
    0000c186     306 (0000c180)     pfc_autoStartSlew
    0000c188     306 (0000c180)     pfc_firstTimeGvLoop
    0000c18a     306 (0000c180)     pfc_vBusError_pu
    0000c18c     306 (0000c180)     pfc_phase2ScaleFactor
    0000c18e     306 (0000c180)     pfc_vBusRefSlewed_pu
    0000c190     306 (0000c180)     gi_controller_out
    0000c192     306 (0000c180)     gv_controller_out
    0000c194     306 (0000c180)     gi_controller_pi_ki
    0000c196     306 (0000c180)     pfc_nonLinearVoltageLoopFlag
    0000c198     306 (0000c180)     pfc_acSine
    0000c19a     306 (0000c180)     pfc_acSine_Prev
    0000c19c     306 (0000c180)     pfc_threshold_PZC1
    0000c19e     306 (0000c180)     pfc_threshold_PZC2
    0000c1a0     306 (0000c180)     pfc_threshold_NZC1
    0000c1a2     306 (0000c180)     pfc_threshold_NZC2
    0000c1a4     306 (0000c180)     pfc_dbRED_SetValue_ticks
    0000c1a6     306 (0000c180)     pfc_dbRED_SetValue_Temp_ticks
    0000c1a8     306 (0000c180)     pfc_dbFED_SetValue_ticks
    0000c1aa     306 (0000c180)     pfc_dbRED_Min_ticks
    0000c1ac     306 (0000c180)     pfc_dbRED_Max_ticks
    0000c1ae     306 (0000c180)     pfc_vBusMeasFiltered_pu
    0000c1b0     306 (0000c180)     PFC_Run_NPhaseState
    0000c1b2     306 (0000c180)     pfc_softStartDuty_ticks
    0000c1b4     306 (0000c180)     pfc_stateSlewMax
    0000c1b6     306 (0000c180)     pfc_softStartDeadBandFED_ticks
    0000c1b8     306 (0000c180)     pfc_v_adc_pu_min
    0000c1ba     306 (0000c180)     pfc_v_adc_pu_max
    0000c1bc     306 (0000c180)     pfc_v_offset_pu
    0000c1be     306 (0000c180)     pfc_vL1_adc_pu_min
    0000c1c0     307 (0000c1c0)     pfc_vL1_adc_pu_max
    0000c1c2     307 (0000c1c0)     pfc_vL1_offset_pu
    0000c1c4     307 (0000c1c0)     pfc_vL2_adc_pu_min
    0000c1c6     307 (0000c1c0)     pfc_vL2_adc_pu_max
    0000c1c8     307 (0000c1c0)     pfc_vL2_offset_pu
    0000c1ca     307 (0000c1c0)     pfc_i_adc_pu_min
    0000c1cc     307 (0000c1c0)     pfc_i_adc_pu_max
    0000c1ce     307 (0000c1c0)     pfc_i_offset_pu
    0000c1d2     307 (0000c1c0)     rgen1
    0000c1d8     307 (0000c1c0)     pfc_notch1
    0000c1ea     307 (0000c1c0)     pfc_notch2
    0000c200     308 (0000c200)     gi_controller
    0000c216     308 (0000c200)     gv_controller
    0000c240     309 (0000c240)     sfra1
    0000c280     30a (0000c280)     spll2
    0000c2c0     30b (0000c2c0)     power_measurement
    0000c300     30c (0000c300)     power_analyzer
    0000c340     30d (0000c340)     spll_signal_generator
    0000c3c0     30f (0000c3c0)     spll1
    0000c440     311 (0000c440)     spll3
    0000c48a     312 (0000c480)     freqVect
    0000c552     315 (0000c540)     olMagVect
    0000c61a     318 (0000c600)     olPhaseVect
    0000c6e2     31b (0000c6c0)     plantMagVect
    0000c7aa     31e (0000c780)     plantPhaseVect
    0000c880     322 (0000c880)     CpuTimer0
    0000c888     322 (0000c880)     CpuTimer1
    0000c890     322 (0000c880)     CpuTimer2
    0000c898     322 (0000c880)     pfc_vBusMeasBuff_pu
    0000c8c0     323 (0000c8c0)     l2_duty_out
    0000c8c1     323 (0000c8c0)     vL2Avg
    0000c8c3     323 (0000c8c0)     Duty_RequestP3n
    0000c8c4     323 (0000c8c0)     pm_heatsinkTemperature
    0000c8c5     323 (0000c8c0)     zero_crossing_reset
    0000c8c6     323 (0000c8c0)     buttonPressed
    0000c8c7     323 (0000c8c0)     tempChange
    0000c8c8     323 (0000c8c0)     vbusAvg
    0000c8c9     323 (0000c8c0)     vp3nAvg
    0000c8ca     323 (0000c8c0)     vac_counts_inst
    0000c8cb     323 (0000c8c0)     ctrl_state
    0000c8cc     323 (0000c8c0)     inv_state_flag
    0000c8d4     323 (0000c8c0)     l2_sp_pi
    0000c8d6     323 (0000c8c0)     l2_fbk_pi
    0000c8d8     323 (0000c8c0)     l2_out_pi
    0000c8da     323 (0000c8c0)     rk_pi
    0000c8dc     323 (0000c8c0)     yk_pi
    0000c8de     323 (0000c8c0)     lk_pi
    0000c8e0     323 (0000c8c0)     uk_pi
    0000c8e2     323 (0000c8c0)     imax_pi
    0000c8e4     323 (0000c8c0)     imin_pi
    0000c8e6     323 (0000c8c0)     Duty_RatioP3n
    0000c8e8     323 (0000c8c0)     upperlim_pi
    0000c8ea     323 (0000c8c0)     lowerlim_pi
    0000c8ec     323 (0000c8c0)     pm_temperatureDerateRatio
    0000c8ee     323 (0000c8c0)     pm_heatsinkDeratedValue
    0000c8f0     323 (0000c8c0)     k1
    0000c8f2     323 (0000c8c0)     k2
    0000c8f4     323 (0000c8c0)     pfc_vBusMeasBuffIndex
    0000c8f6     323 (0000c8c0)     pfc_stateSlew
    0000c900     324 (0000c900)     vL2_data
    0000c90b     324 (0000c900)     vbus_data
    0000c916     324 (0000c900)     vp3n_data
    0000c921     324 (0000c900)     hsink_data
    0000c92c     324 (0000c900)     ishunt_data
    0000c940     325 (0000c940)     gi
    0000c952     325 (0000c940)     gv_pr1
    0000c964     325 (0000c940)     gv_r3
    0000c980     326 (0000c980)     gv_r5
    0000c992     326 (0000c980)     gv_r7
    0000c9a4     326 (0000c980)     gv_r9
    0000c9c0     327 (0000c9c0)     gv_r11
    0000c9d2     327 (0000c9c0)     gv_prL1
    0000c9e4     327 (0000c9c0)     gv_r3L1
    0000ca00     328 (0000ca00)     gv_r5L1
    0000ca12     328 (0000ca00)     gv_r7L1
    0000ca24     328 (0000ca00)     gv_prL2
    0000ca40     329 (0000ca40)     gv_r3L2
    0000ca52     329 (0000ca40)     gv_r5L2
    0000ca64     329 (0000ca40)     gv_r7L2
    0000ca80     32a (0000ca80)     gv_lead_lag
    0000ca92     32a (0000ca80)     notch1
    0000caa4     32a (0000ca80)     notch2
    0000cac0     32b (0000cac0)     gi_pr1
    0000cad2     32b (0000cac0)     gi_r3
    0000cae4     32b (0000cac0)     gi_r5
    0000cb00     32c (0000cb00)     gi_r7
    0000cb12     32c (0000cb00)     gi_r9
    0000cb24     32c (0000cb00)     gi_r11
    0000cb40     32d (0000cb40)     gi_lead_lag
    0000cb52     32d (0000cb40)     pi_ph3_settings
    0000cb68     32d (0000cb40)     pi_L2_settings
    0000cb7e     32d (0000cb40)     _lock
    0000cb80     32e (0000cb80)     adc_sample_counter
    0000cb81     32e (0000cb80)     ioutL1_buffer
    0000cb82     32e (0000cb80)     ioutl2_buffer
    0000cb83     32e (0000cb80)     ioutL3_buffer
    0000cb84     32e (0000cb80)     ishunt_buffer
    0000cb85     32e (0000cb80)     vgridl1_buffer
    0000cb86     32e (0000cb80)     vgridL2_buffer
    0000cb87     32e (0000cb80)     vgridL1L2_buffer
    0000cb88     32e (0000cb80)     vgridL3_buffer
    0000cb89     32e (0000cb80)     vbiasgrid_buffer
    0000cb8a     32e (0000cb80)     vbiasinv_buffer
    0000cb8b     32e (0000cb80)     vbus_buffer
    0000cb8c     32e (0000cb80)     hsTemp_buffer
    0000cb8d     32e (0000cb80)     vinvL1_buffer
    0000cb8e     32e (0000cb80)     vinvL2_buffer
    0000cb8f     32e (0000cb80)     vinvL2L3_buffer
    0000cb90     32e (0000cb80)     vinvL3_buffer
    0000cb91     32e (0000cb80)     ioutL1_avg
    0000cb92     32e (0000cb80)     ioutl2_avg
    0000cb93     32e (0000cb80)     ioutL3_avg
    0000cb94     32e (0000cb80)     ishunt_avg
    0000cb95     32e (0000cb80)     vgridl1_avg
    0000cb96     32e (0000cb80)     vgridL2_avg
    0000cb97     32e (0000cb80)     vgridL1L2_avg
    0000cb98     32e (0000cb80)     vgridL3_avg
    0000cb99     32e (0000cb80)     vbiasgrid_avg
    0000cb9a     32e (0000cb80)     vbiasinv_avg
    0000cb9b     32e (0000cb80)     vbus_avg
    0000cb9c     32e (0000cb80)     hsTemp_avg
    0000cb9d     32e (0000cb80)     vinvL1_avg
    0000cb9e     32e (0000cb80)     vinvL2_avg
    0000cb9f     32e (0000cb80)     vinvL2L3_avg
    0000cba0     32e (0000cb80)     vinvL3_avg
    0000cba1     32e (0000cb80)     Inverter_Status
    0000cba2     32e (0000cb80)     t100uSecCtr
    0000cba3     32e (0000cb80)     t1mSecCtr
    0000cba4     32e (0000cb80)     t5mSecCtr
    0000cba5     32e (0000cb80)     t10mSecCtr
    0000cba6     32e (0000cb80)     t100mSecCtr
    0000cba7     32e (0000cb80)     t500mSecCtr
    0000cba8     32e (0000cb80)     t1SecCtr
    0000cba9     32e (0000cb80)     Timer100usOld
    0000cbaa     32e (0000cb80)     Timer1msOld
    0000cbab     32e (0000cb80)     Timer5msOld
    0000cbac     32e (0000cb80)     Timer10msOld
    0000cbad     32e (0000cb80)     Timer100msOld
    0000cbae     32e (0000cb80)     Timer500msOld
    0000cbaf     32e (0000cb80)     Timer1sOld
    0000cbb0     32e (0000cb80)     iShuntOffset_pu
    0000cbb2     32e (0000cb80)     vGridL1Offset_pu
    0000cbb4     32e (0000cb80)     vGridL2Offset_pu
    0000cbb6     32e (0000cb80)     vGirdL3Offset_pu
    0000cbb8     32e (0000cb80)     vGridL1L2Offset_pu
    0000cbba     32e (0000cb80)     vInvL1Offset_pu
    0000cbbc     32e (0000cb80)     vInvL2Offset_pu
    0000cbbe     32e (0000cb80)     vInvL3Offset_pu
    0000cbc0     32f (0000cbc0)     vInvL1L2Offset_pu
    0000cbc2     32f (0000cbc0)     iOutL1Offset_pu
    0000cbc4     32f (0000cbc0)     iOutL2Offset_pu
    0000cbc6     32f (0000cbc0)     iOutL3Offset_pu
    0000cbc8     32f (0000cbc0)     vBustOffset_pu
    0000cbca     32f (0000cbc0)     vBiasInvOffset_pu
    0000cbcc     32f (0000cbc0)     vBiasGridOffset_pu
    0000cbce     32f (0000cbc0)     ntcOffset_pu
    0000cbd0     32f (0000cbc0)     DTC_list
    0000cc0d     330 (0000cc00)     heatSinkTemp
    0000cc0e     330 (0000cc00)     vGridL1
    0000cc10     330 (0000cc00)     vGridL2
    0000cc12     330 (0000cc00)     vGridL1L2
    0000cc14     330 (0000cc00)     vGridL3
    0000cc16     330 (0000cc00)     vBiasGrid
    0000cc18     330 (0000cc00)     vBiasInv
    0000cc1a     330 (0000cc00)     vInvL1
    0000cc1c     330 (0000cc00)     vInvL2
    0000cc1e     330 (0000cc00)     vInvL1L2
    0000cc20     330 (0000cc00)     vInvL3
    0000cc22     330 (0000cc00)     vBus
    0000cc24     330 (0000cc00)     ioutL1
    0000cc26     330 (0000cc00)     ioutL2
    0000cc28     330 (0000cc00)     ioutL3
    0000cc2a     330 (0000cc00)     ishunt
    0000cc2c     330 (0000cc00)     hsTemp_buffer_s
    0000cc34     330 (0000cc00)     ioutL1_buffer_s
    0000cc3c     330 (0000cc00)     ioutL3_buffer_s
    0000cc44     331 (0000cc40)     ioutl2_buffer_s
    0000cc4c     331 (0000cc40)     ishunt_buffer_s
    0000cc54     331 (0000cc40)     vbus_buffer_s
    0000cc5c     331 (0000cc40)     vgridL2_buffer_s
    0000cc64     331 (0000cc40)     vgridl1_buffer_s
    0000cc6c     331 (0000cc40)     __TI_enable_exit_profile_output
    0000cc6e     331 (0000cc40)     __TI_cleanup_ptr
    0000cc70     331 (0000cc40)     __TI_dtors_ptr
    0000cc74     331 (0000cc40)     PWM_isInit
    0000cccc     333 (0000ccc0)     _SFRA_F32_state
    0000cccd     333 (0000ccc0)     _SFRA_F32_stateSlew
    0000ccce     333 (0000ccc0)     _SFRA_F32_rSinSum
    0000ccd0     333 (0000ccc0)     _SFRA_F32_rCosSum
    0000ccd2     333 (0000ccc0)     _SFRA_F32_uSinSum
    0000ccd4     333 (0000ccc0)     _SFRA_F32_uCosSum
    0000ccd6     333 (0000ccc0)     _SFRA_F32_ySinSum
    0000ccd8     333 (0000ccc0)     _SFRA_F32_yCosSum
    0000ccda     333 (0000ccc0)     _SFRA_F32_pointerStart
    0000ccdc     333 (0000ccc0)     _SFRA_F32_reference
    0000ccde     333 (0000ccc0)     _SFRA_F32_amplitude
    0000cce0     333 (0000ccc0)     _SFRA_F32_scalar
    0000cce2     333 (0000ccc0)     _SFRA_F32_step
    0000cce4     333 (0000ccc0)     _SFRA_F32_pointer
    0000cce6     333 (0000ccc0)     _SFRA_F32_preCount
    0000cce8     333 (0000ccc0)     _SFRA_F32_count
    0000ccea     333 (0000ccc0)     _SFRA_F32_windowSamples
    0000ccec     333 (0000ccc0)     _SFRA_F32_angle
    0000e000     380 (0000e000)     FPU32sinTable
    0000e000     380 (0000e000)     FPUsinTable
    0000e100     384 (0000e100)     FPU32cosTable
    0000e100     384 (0000e100)     FPUcosTable
    0000e400     390 (0000e400)     FPU32sinTableEnd
    0000e400     390 (0000e400)     FPUsinTableEnd
    0000e502     394 (0000e500)     FPU32atan2HalfPITable
    0000e502     394 (0000e500)     FPU32cosTableEnd
    0000e502     394 (0000e500)     FPUatan2HalfPITable
    0000e502     394 (0000e500)     FPUcosTableEnd
    0000e506     394 (0000e500)     FPU32atan2Table
    0000e506     394 (0000e500)     FPUatan2Table
    0000e68c     39a (0000e680)     FPU32LOG2
    0000e68c     39a (0000e680)     FPU32atan2TableEnd
    0000e68c     39a (0000e680)     FPUatan2TableEnd
    0000e68e     39a (0000e680)     FPU32INVLOG10
    0000e690     39a (0000e680)     FPU32EXPBIAS
    0000e692     39a (0000e680)     FPU32LOG_TABLE_MASK1
    0000e694     39a (0000e680)     FPU32LOG_TABLE_MASK2
    0000e696     39a (0000e680)     FPU32logTable
    0000e75c     39d (0000e740)     FPU32logTableEnd
    0033b000    cec0 (0033b000)     PieVectTableInit
    0033fff8    cfff (0033ffc0)     CsmPwl
    GLOBAL SYMBOLS: SORTED ALPHABETICALLY BY Name
    page  address   name
    0     0033acd5  ADCA_ForceAllSOCs
    0     0033acd3  ADCA_GetResult
    0     0033ac7d  ADCA_Init
    0     00339909  ADCA_SetChannels_ADC
    0     0033a19c  ADCINT_ISR
    0     0033aa30  ASM_100msTask
    0     0033aa74  ASM_1msTask
    0     00339903  ASM_ADC_CountsTo_mVolts
    0     00339902  ASM_ADC_ISR_Enable
    0     00339901  ASM_ADC_ISR_Register
    0     0033ac7d  ASM_ADC_Init
    0     0033aa01  ASM_GetBusVoltage
    0     003398f8  ASM_GetHSTemp_ADC
    0     0033a9fd  ASM_GetHeatSinkTemperature
    0     003398d8  ASM_GetIGrid_ADC
    0     003398cf  ASM_GetIShunt_ADC
    0     0033a9f8  ASM_GetShuntCurrent
    0     003398c7  ASM_GetVBus_ADC
    0     003398c3  ASM_GetVGridL1_ADC
    0     0033a9ed  ASM_Init
    0     0033aa74  ASM_ScanAllADCs
    1     00007100  AdcRegs
    1     0000c142  BiINV_board_Mode
    1     0000c146  BiINV_board_State
    1     0000c148  BiINV_board_Status
    1     0000c144  BiINV_pwm_SwState
    0     0033ae73  C$$EXIT
    0     0033ad0e  ConfigCpuTimer
    1     0000c880  CpuTimer0
    1     00000c00  CpuTimer0Regs
    1     0000c888  CpuTimer1
    1     00000c08  CpuTimer1Regs
    1     0000c890  CpuTimer2
    1     00000c10  CpuTimer2Regs
    1     0033fff8  CsmPwl
    1     00000ae0  CsmRegs
    0     0033a9bf  CsmUnlock
    0     0033a192  DATALOG_ISR
    1     0000cc76  DCL_runDF22_C1
    1     0000cca6  DCL_runPI_C4
    0     0033a188  DINTCH1_ISR
    0     0033a17e  DINTCH2_ISR
    0     0033a174  DINTCH3_ISR
    0     0033a16a  DINTCH4_ISR
    0     0033a160  DINTCH5_ISR
    0     0033a156  DINTCH6_ISR
    0     0033abdb  DTC_Report
    1     0000cbd0  DTC_list
    0     0033a907  DisableDog
    1     0000c8e6  Duty_RatioP3n
    1     0000c8c3  Duty_RequestP3n
    0     0033a14c  ECAN0INTA_ISR
    0     0033a142  ECAN0INTB_ISR
    0     0033a138  ECAN1INTA_ISR
    0     0033a12e  ECAN1INTB_ISR
    0     0033a124  ECAP1_INT_ISR
    0     0033a11a  ECAP2_INT_ISR
    0     0033a110  ECAP3_INT_ISR
    0     0033a106  ECAP4_INT_ISR
    0     0033a0fc  ECAP5_INT_ISR
    0     0033a0f2  ECAP6_INT_ISR
    0     0033a0e8  EMUINT_ISR
    0     0033a0de  EPWM1_INT_ISR
    0     0033a0d4  EPWM1_TZINT_ISR
    0     0033a0ca  EPWM2_INT_ISR
    0     0033a0c0  EPWM2_TZINT_ISR
    0     0033a0b6  EPWM3_INT_ISR
    0     0033a0ac  EPWM3_TZINT_ISR
    0     0033a0a2  EPWM4_INT_ISR
    0     0033a098  EPWM4_TZINT_ISR
    0     0033a08e  EPWM5_INT_ISR
    0     0033a084  EPWM5_TZINT_ISR
    0     0033a07a  EPWM6_INT_ISR
    0     0033a070  EPWM6_TZINT_ISR
    1     00006800  EPwm1Regs
    1     0000c058  EPwm1TimerIntCount
    1     0000c001  EPwm1_DB_Direction
    1     00006840  EPwm2Regs
    1     0000c05a  EPwm2TimerIntCount
    1     0000c002  EPwm2_DB_Direction
    1     00006880  EPwm3Regs
    1     0000c05c  EPwm3TimerIntCount
    1     0000c003  EPwm3_DB_Direction
    0     0033a066  EQEP1_INT_ISR
    0     0033a05c  EQEP2_INT_ISR
    0     0033aebb  EnableInterrupts
    1     0000e690  FPU32EXPBIAS
    1     0000e68e  FPU32INVLOG10
    1     0000e68c  FPU32LOG2
    1     0000e692  FPU32LOG_TABLE_MASK1
    1     0000e694  FPU32LOG_TABLE_MASK2
    1     0000e502  FPU32atan2HalfPITable
    1     0000e506  FPU32atan2Table
    1     0000e68c  FPU32atan2TableEnd
    1     0000e100  FPU32cosTable
    1     0000e502  FPU32cosTableEnd
    1     0000e696  FPU32logTable
    1     0000e75c  FPU32logTableEnd
    1     0000e000  FPU32sinTable
    1     0000e400  FPU32sinTableEnd
    1     0000e502  FPUatan2HalfPITable
    1     0000e506  FPUatan2Table
    1     0000e68c  FPUatan2TableEnd
    1     0000e100  FPUcosTable
    1     0000e502  FPUcosTableEnd
    1     0000e000  FPUsinTable
    1     0000e400  FPUsinTableEnd
    1     00000a80  FlashRegs
    0     00339743  GPIO_22_Init
    0     003398bd  GPIO_22_Read
    0     003398b8  GPIO_22_Toggle
    0     003398ac  GPIO_22_Write
    0     00339732  GPIO_26_Init
    0     003397d9  GPIO_30_Init
    0     003397ea  GPIO_30_Write
    0     003397ab  GPIO_86_Init
    0     003398a6  GPIO_86_Read
    0     00339754  GPIO_B_LED_Init
    0     003398a0  GPIO_B_LED_Read
    0     0033989b  GPIO_B_LED_Toggle
    0     00339765  GPIO_B_LED_Write
    0     00339771  GPIO_G_LED_Init
    0     00339895  GPIO_G_LED_Read
    0     00339890  GPIO_G_LED_Toggle
    0     00339782  GPIO_G_LED_Write
    0     00339884  GPIO_RLY3_Write
    0     00339702  GPIO_RLY_L1_Init
    0     0033987f  GPIO_RLY_L1_Toggle
    0     00339873  GPIO_RLY_L1_Write
    0     00339712  GPIO_RLY_L2_Init
    0     0033986e  GPIO_RLY_L2_Toggle
    0     00339862  GPIO_RLY_L2_Write
    0     00339722  GPIO_RLY_L3_Init
    0     0033985d  GPIO_RLY_L3_Toggle
    0     0033978e  GPIO_R_LED_Init
    0     00339857  GPIO_R_LED_Read
    0     00339852  GPIO_R_LED_Toggle
    0     0033979f  GPIO_R_LED_Write
    0     003397bc  GPIO_SHDN_DRV_Init
    0     003397cd  GPIO_SHDN_DRV_Write
    0     003397f6  GPIO_SHDN_READ_CTL_Init
    1     00006f80  GpioCtrlRegs
    1     00006fc0  GpioDataRegs
    0     0033a710  HAL_ADC_ISR
    0     00339447  HAL_CalibrateOffsets
    0     0033980b  HAL_DeviceInit
    0     003396d5  HAL_DriversInit
    0     0033942d  HAL_EnableInterrupts
    0     00339446  HAL_GenerateLookUpTable
    0     00339445  HAL_InitFlashMemory
    0     0033942d  HAL_InterruptsInit
    0     00339419  HAL_InterruptsMapping
    0     00339415  HAL_InvSetStatusFlag
    0     00339410  HAL_InverterStatusOFF
    0     003393ea  HAL_MovingAvg
    0     0033a8e1  HAL_NTC_100k_GetResistance
    0     0033a7fa  HAL_NTC_100k_GetTemperature
    0     003393e9  HAL_ServicesPreInit
    0     003393d5  HAL_SetupEPWMtoTriggerADCSOC
    0     003393ba  HAL_StartSchedulerTimer
    0     003393b9  HAL_Watchdog_CounterReset
    0     003393b8  HAL_Watchdog_Init
    0     003393b6  HAL_Watchdog_SetMode
    0     0033a052  I2CINT1A_ISR
    0     0033a048  I2CINT2A_ISR
    0     0033a03e  ILLEGAL_ISR
    0     0033a034  INT13_ISR
    0     0033a02a  INT14_ISR
    0     00338f1a  INV_RUN_HF
    1     0000c136  IQCMPRA
    1     0000c13a  IQCMPRAL1
    1     0000c13e  IQCMPRAL2
    1     0000c138  IQCMPRA_tmp
    1     0000c13c  IQCMPRA_tmpL1
    1     0000c140  IQCMPRA_tmpL2
    1     0000c06e  ISR2_Loading
    1     0000c070  ISR2_LoadingAvg
    0     0033acdb  InitCpuTimers
    0     00008000  InitFlash
    0     0033a955  InitPeripheralClocks
    0     0033ae9c  InitPieCtrl
    0     0033af93  InitPieVectTable
    0     0033a90f  InitPll
    0     0033a9b6  InitSysCtrl
    0     00339375  Inverter_Gpio_Init
    1     0000cba1  Inverter_Status
    0     0033a020  LUF_ISR
    0     0033a016  LVF_ISR
    0     0033a00c  MRINTA_ISR
    0     0033a002  MRINTB_ISR
    0     00339ff8  MXINTA_ISR
    0     00339fee  MXINTB_ISR
    0     0033ad83  MainApp_10msTask
    0     0033ad31  MainApp_Init
    0     0033ad32  MainApp_Run
    0     0033ad31  MainApp_ServicesInit
    0     00339fe4  NMI_ISR
    0     0033a8e1  NTC_100k_GetResistance
    0     0033a7fa  NTC_100k_GetTemperature
    1     0000c1b0  PFC_Run_NPhaseState
    0     00339fda  PIE_RESERVED
    0     0033931b  PM_100msTask
    0     00339313  PM_100usTask
    0     0033930e  PM_1msTask
    0     00339300  PM_1sTask
    0     003392d6  PM_5msTask
    0     00339e5b  PM_CONTROL_HF_ISR
    0     00339984  PM_CONTROL_LF_ISR
    0     00338c36  PM_ControlSateMachine
    0     00338c17  PM_GenericCalculateDerate
    0     003386c0  PM_InitControllerVariables
    0     003385d0  PM_InitGlobalVariables
    0     003393a5  PM_Inverter_Control_Init
    0     0033990b  PM_PH3_CONTROL_ISR
    0     0033a6ba  PWM_EnablePeripheral
    0     0033a576  PWM_Init
    0     0033a574  PWM_ReadPeriod
    0     0033a572  PWM_ResetPeripheral
    0     0033a571  PWM_SetCompareA
    0     0033a570  PWM_SetCompareB
    0     0033a563  PWM_SetDelayChannelA
    0     0033a562  PWM_WritePeriod
    1     0000cc74  PWM_isInit
    1     0000c0c4  Phase_Jump
    1     0000c0c6  Phase_Jump_Trig
    1     00000ce0  PieCtrlRegs
    1     00000d00  PieVectTable
    0     0033b000  PieVectTableInit
    0     00339fd0  RTOSINT_ISR
    0     0033a6bc  SCHED_ISR
    0     00339fc6  SCIRXINTA_ISR
    0     00339fbc  SCIRXINTB_ISR
    0     00339fb2  SCIRXINTC_ISR
    0     00339fa8  SCITXINTA_ISR
    0     00339f9e  SCITXINTB_ISR
    0     00339f94  SCITXINTC_ISR
    0     00339f8a  SEQ1INT_ISR
    0     00339f80  SEQ2INT_ISR
    0     0033a504  SFRA_F32_config
    0     0033a4da  SFRA_F32_initFreqArrayWithLogSteps
    0     0033a4b1  SFRA_F32_reset
    0     0033a3a8  SFRA_F32_resetFreqRespArray
    0     0033a1a6  SFRA_F32_runBackgroundTask
    0     0033a3a0  SFRA_F32_updateInjectionAmplitude
    0     00339f76  SPIRXINTA_ISR
    0     00339f6c  SPITXINTA_ISR
    0     003385b9  SPLL_LPF_Coeff_Update
    0     00339374  SYS_SystemReset
    0     0033a8fd  ServiceDog
    0     0033931c  StartEPwmInverter
    1     00007010  SysCtrlRegs
    0     00339f62  TINT0_ISR
    1     0000cbad  Timer100msOld
    1     0000cba9  Timer100usOld
    1     0000cbac  Timer10msOld
    1     0000cbaa  Timer1msOld
    1     0000cbaf  Timer1sOld
    1     0000cbae  Timer500msOld
    1     0000cbab  Timer5msOld
    0     00339f58  USER10_ISR
    0     00339f4e  USER11_ISR
    0     00339f44  USER12_ISR
    0     00339f3a  USER1_ISR
    0     00339f30  USER2_ISR
    0     00339f26  USER3_ISR
    0     00339f1c  USER4_ISR
    0     00339f12  USER5_ISR
    0     00339f08  USER6_ISR
    0     00339efe  USER7_ISR
    0     00339ef4  USER8_ISR
    0     00339eea  USER9_ISR
    0     00339ee0  WAKEINT_ISR
    0     00339ed6  XINT1_ISR
    0     00339ecc  XINT2_ISR
    0     00339ec2  XINT3_ISR
    0     00339eb8  XINT4_ISR
    0     00339eae  XINT5_ISR
    0     00339ea4  XINT6_ISR
    0     00339e9a  XINT7_ISR
    1     00000b20  XintfRegs
    0     00380080  _ADC_cal
    0     0000801d  _DSP28x_usDelay
    0     0033aef1  _ExitBoot
    0     00338021  _RamfuncsLoadEnd
    abs   00000021  _RamfuncsLoadSize
    0     00338000  _RamfuncsLoadStart
    0     00008000  _RamfuncsRunStart
    1     0000ccde  _SFRA_F32_amplitude
    1     0000ccec  _SFRA_F32_angle
    1     0000cce8  _SFRA_F32_count
    1     0000cce4  _SFRA_F32_pointer
    1     0000ccda  _SFRA_F32_pointerStart
    1     0000cce6  _SFRA_F32_preCount
    1     0000ccd0  _SFRA_F32_rCosSum
    1     0000ccce  _SFRA_F32_rSinSum
    1     0000ccdc  _SFRA_F32_reference
    1     0000cce0  _SFRA_F32_scalar
    1     0000cccc  _SFRA_F32_state
    1     0000cccd  _SFRA_F32_stateSlew
    1     0000cce2  _SFRA_F32_step
    1     0000ccd4  _SFRA_F32_uCosSum
    1     0000ccd2  _SFRA_F32_uSinSum
    1     0000ccea  _SFRA_F32_windowSamples
    1     0000ccd8  _SFRA_F32_yCosSum
    1     0000ccd6  _SFRA_F32_ySinSum
    0     0033b1c8  __TI_CINIT_Base
    0     0033b214  __TI_CINIT_Limit
    0     0033b214  __TI_CINIT_Warm
    0     0033b178  __TI_Handler_Table_Base
    0     0033b17e  __TI_Handler_Table_Limit
    1     00000600  __TI_STACK_END
    abs   00000200  __TI_STACK_SIZE
    0     0033ae1e  __TI_auto_init_nobinit_nopinit
    1     0000cc6e  __TI_cleanup_ptr
    0     0033adf0  __TI_decompress_lzss
    0     0033afbe  __TI_decompress_none
    1     0000cc70  __TI_dtors_ptr
    1     0000cc6c  __TI_enable_exit_profile_output
    abs   ffffffff  __TI_pprof_out_hndl
    abs   ffffffff  __TI_prof_data_size
    abs   ffffffff  __TI_prof_data_start
    0     0033afc6  __TI_zero_init
    0     0033aa8b  __c28xabi_addd
    0     0033af63  __c28xabi_divf
    0     0033ae49  __c28xabi_divl
    0     0033ae66  __c28xabi_divul
    0     0033aec4  __c28xabi_dtof
    0     0033af47  __c28xabi_ftod
    0     0033ae58  __c28xabi_modl
    0     0033ae6d  __c28xabi_modul
    0     0033ab27  __c28xabi_mpyd
    n/a   UNDEFED   __c_args__
    1     00000400  __stack
    0     0033afb2  _args_main
    0     0033af7c  _c_int00
    1     0000cb7e  _lock
    0     0033afd4  _nop
    0     0033afd5  _system_post_cinit
    0     0033afd2  _system_pre_init
    0     0033ae73  abort
    1     0000c060  acCosine_regen
    1     0000c078  acDrop_cnt
    1     0000c004  acDrop_flag
    1     0000c0c8  acFreq_lpf
    1     0000c05e  acSine_regen
    1     0000c066  acSine_regen_ISRperiod
    1     0000c064  acSine_regen_freq
    1     0000c0ca  acVoltage_avg
    1     0000c06c  ac_volRMS_regen_Volts
    1     0000c068  ac_vol_regen_Volts
    1     0000c06a  ac_vol_regen_magnitude
    1     0000cb80  adc_sample_counter
    1     0000c005  brownOut_flag
    1     0000c8c6  buttonPressed
    1     0000c0c2  c1
    1     0000c0c0  c2
    0     003385a8  checkButtonState
    0     003384e9  checkVPh3_Neutral
    1     0000c000  clampactive
    1     0000c012  clearInvTrip
    1     0000c010  closeILoopInv
    1     0000c011  closeVLoopInv
    0     0033fff6  code_start
    0     0033846e  computeDF22_NotchFltrCoeff
    0     0033843b  computeDF22_PIcontrollerCoeff
    0     003383b8  computeDF22_PRcontrollerCoeff
    1     0000c8cb  ctrl_state
    1     0000c015  cyclePolarityFlag
    0     0033ae75  exit
    1     0000c48a  freqVect
    1     0000c940  gi
    1     0000c200  gi_controller
    1     0000c190  gi_controller_out
    1     0000c194  gi_controller_pi_ki
    1     0000cb40  gi_lead_lag
    1     0000c080  gi_lead_lag_out
    1     0000c082  gi_notch1_out
    1     0000c084  gi_notch2_out
    1     0000c07a  gi_out
    1     0000c07c  gi_outL1
    1     0000c07e  gi_outL2
    1     0000cac0  gi_pr1
    1     0000cb24  gi_r11
    1     0000cad2  gi_r3
    1     0000cae4  gi_r5
    1     0000cb00  gi_r7
    1     0000cb12  gi_r9
    1     0000c0cc  gridFreqNominal
    1     0000c0d0  gridVrmsAvg
    1     0000c0ce  gridVrmsNominal
    1     0000c040  guiACFreq
    1     0000c054  guiFreqAvg
    1     0000c03c  guiIL
    1     0000c04c  guiIi
    1     0000c007  guiInvRMSStart
    1     0000c008  guiInvRMSStop
    1     0000c04e  guiIo
    1     0000c044  guiIrms
    1     0000c050  guiPowerFactor
    1     0000c042  guiPrms
    1     0000c052  guiVA
    1     0000c036  guiVacMax
    1     0000c038  guiVacMin
    1     0000c048  guiVavg
    1     0000c030  guiVbus
    1     0000c032  guiVbusMax
    1     0000c034  guiVbusMin
    1     0000c056  guiVema
    1     0000c03a  guiVin
    1     0000c04a  guiVo
    1     0000c046  guiVrms
    1     0000c216  gv_controller
    1     0000c192  gv_controller_out
    1     0000ca80  gv_lead_lag
    1     0000c02e  gv_lead_lag_out
    1     0000c022  gv_out
    1     0000c026  gv_outL1
    1     0000c02a  gv_outL2
    1     0000c024  gv_out_scaled
    1     0000c028  gv_out_scaledL1
    1     0000c02c  gv_out_scaledL2
    1     0000c952  gv_pr1
    1     0000c9d2  gv_prL1
    1     0000ca24  gv_prL2
    1     0000c9c0  gv_r11
    1     0000c964  gv_r3
    1     0000c9e4  gv_r3L1
    1     0000ca40  gv_r3L2
    1     0000c980  gv_r5
    1     0000ca00  gv_r5L1
    1     0000ca52  gv_r5L2
    1     0000c992  gv_r7
    1     0000ca12  gv_r7L1
    1     0000ca64  gv_r7L2
    1     0000c9a4  gv_r9
    1     0000cc0d  heatSinkTemp
    1     0000cb9c  hsTemp_avg
    1     0000cb8c  hsTemp_buffer
    1     0000cc2c  hsTemp_buffer_s
    1     0000c921  hsink_data
    1     0000c00a  i
    1     0000cbc2  iOutL1Offset_pu
    1     0000cbc4  iOutL2Offset_pu
    1     0000cbc6  iOutL3Offset_pu
    1     0000cbb0  iShuntOffset_pu
    1     0000c8e2  imax_pi
    1     0000c8e4  imin_pi
    1     0000c00f  invDutyCompl
    1     0000c00e  invDutyCtlr
    1     0000c00c  invDutyL1
    1     0000c00d  invDutyL2
    1     0000c12a  invDutyPU
    1     0000c12e  invDutyPUCtlr
    1     0000c12c  invDutyPUPrev
    1     0000c0ec  invIfInst
    1     0000c0ee  invIfSDOffset
    1     0000c0d2  invIiL1Inst
    1     0000c0d4  invIiL2Inst
    1     0000c0d6  invIiL3Inst
    1     0000c0ea  invIiOffset
    1     0000c110  invIiRefInst
    1     0000c0d8  invIiShuntInst
    1     0000c0f0  invIoInst
    1     0000c108  invIoRef
    1     0000c112  invIoRefInst
    1     0000c0f2  invIoSDOffset
    1     0000c104  invModIndex
    1     0000c130  invSine
    1     0000c134  invSineFull
    1     0000c132  invSinePrev
    1     0000c102  invVbusAvg
    1     0000c0f8  invVbusInst
    1     0000c0fe  invVbusOffset
    1     0000c120  invVbusRef
    1     0000c100  invVbusSDOffset
    1     0000c0e2  invViL1Inst
    1     0000c0e6  invViL1L2Inst
    1     0000c0e4  invViL2Inst
    1     0000c0e8  invViL3Inst
    1     0000c0da  invVoL1Inst
    1     0000c0de  invVoL1L2Inst
    1     0000c0dc  invVoL2Inst
    1     0000c0e0  invVoL3Inst
    1     0000c0f4  invVoOffset
    1     0000c10a  invVoRef
    1     0000c114  invVoRefInst
    1     0000c118  invVoRefInstL1
    1     0000c11c  invVoRefInstL2
    1     0000c10c  invVoRefL1
    1     0000c10e  invVoRefL2
    1     0000c116  invVoRefLast
    1     0000c11a  invVoRefLastL1
    1     0000c11e  invVoRefLastL2
    1     0000c0f6  invVoSDOffset
    1     0000c8cc  inv_state_flag
    1     0000cc24  ioutL1
    1     0000cb91  ioutL1_avg
    1     0000cb81  ioutL1_buffer
    1     0000cc34  ioutL1_buffer_s
    1     0000cc26  ioutL2
    1     0000cc28  ioutL3
    1     0000cb93  ioutL3_avg
    1     0000cb83  ioutL3_buffer
    1     0000cc3c  ioutL3_buffer_s
    1     0000cb92  ioutl2_avg
    1     0000cb82  ioutl2_buffer
    1     0000cc44  ioutl2_buffer_s
    1     0000cc2a  ishunt
    1     0000cb94  ishunt_avg
    1     0000cb84  ishunt_buffer
    1     0000cc4c  ishunt_buffer_s
    1     0000c92c  ishunt_data
    1     0000c8f0  k1
    1     0000c8f2  k2
    1     0000c088  kiI_1H
    1     0000c08a  kiI_3H
    1     0000c08c  kiI_5H
    1     0000c08e  kiI_7H
    1     0000c090  kiI_9H
    1     0000c0a8  kiV_1H
    1     0000c0aa  kiV_3H
    1     0000c0ac  kiV_5H
    1     0000c0ae  kiV_7H
    1     0000c086  kpI_1H
    1     0000c0a6  kpV_1H
    1     0000c8c0  l2_duty_out
    1     0000c8d6  l2_fbk_pi
    1     0000c8d8  l2_out_pi
    1     0000c8d4  l2_sp_pi
    1     0000c8de  lk_pi
    0     0033ad84  logf
    1     0000c8ea  lowerlim_pi
    0     0033afa4  main
    0     0033af2a  memcpy
    0     0033afcc  memset
    1     0000ca92  notch1
    1     0000caa4  notch2
    1     0000cbce  ntcOffset_pu
    1     0000c128  offset165
    1     0000c00b  offsetCalCounter
    1     0000c552  olMagVect
    1     0000c61a  olPhaseVect
    1     0000c016  period
    1     0000c106  pfcIiRef
    1     0000c198  pfc_acSine
    1     0000c19a  pfc_acSine_Prev
    1     0000c156  pfc_ac_L_sensed_pu
    1     0000c158  pfc_ac_N_sensed_pu
    1     0000c16e  pfc_ac_cur_ref_inst_prev_pu
    1     0000c16c  pfc_ac_cur_ref_inst_pu
    1     0000c16a  pfc_ac_cur_ref_pu
    1     0000c166  pfc_ac_cur_sensed_pu
    1     0000c154  pfc_ac_sign_filtered
    1     0000c15c  pfc_ac_volL1_sensed_pu
    1     0000c15e  pfc_ac_volL2_sensed_pu
    1     0000c03e  pfc_ac_volRmsEma_sensed_Volts
    1     0000c15a  pfc_ac_vol_sensed_pu
    1     0000c186  pfc_autoStartSlew
    1     0000c180  pfc_closeGiLoop
    1     0000c182  pfc_closeGvLoop
    1     0000c1a8  pfc_dbFED_SetValue_ticks
    1     0000c1ac  pfc_dbRED_Max_ticks
    1     0000c1aa  pfc_dbRED_Min_ticks
    1     0000c1a6  pfc_dbRED_SetValue_Temp_ticks
    1     0000c1a4  pfc_dbRED_SetValue_ticks
    1     0000c14a  pfc_dutyPU
    1     0000c14c  pfc_dutyPU_DC
    1     0000c188  pfc_firstTimeGvLoop
    1     0000c017  pfc_highPowerTrans_flag
    1     0000c168  pfc_iLVrefMeas_pu
    1     0000c01f  pfc_i_adc_counts_max
    1     0000c01e  pfc_i_adc_counts_min
    1     0000c1cc  pfc_i_adc_pu_max
    1     0000c1ca  pfc_i_adc_pu_min
    1     0000c1ce  pfc_i_offset_pu
    1     0000c174  pfc_inductor_voltage_drop_feedforward
    1     0000c196  pfc_nonLinearVoltageLoopFlag
    1     0000c1d8  pfc_notch1
    1     0000c1ea  pfc_notch2
    1     0000c18c  pfc_phase2ScaleFactor
    1     0000c184  pfc_relayConnect
    1     0000c1b6  pfc_softStartDeadBandFED_ticks
    1     0000c1b2  pfc_softStartDuty_ticks
    1     0000c152  pfc_spll_cosine
    1     0000c150  pfc_spll_sine
    1     0000c8f6  pfc_stateSlew
    1     0000c1b4  pfc_stateSlewMax
    1     0000c14e  pfc_thetaOffset_pu
    1     0000c1a0  pfc_threshold_NZC1
    1     0000c1a2  pfc_threshold_NZC2
    1     0000c19c  pfc_threshold_PZC1
    1     0000c19e  pfc_threshold_PZC2
    1     0000c160  pfc_vACLMeasOffset_pu
    1     0000c164  pfc_vACMeasOffset_pu
    1     0000c162  pfc_vACNMeasOffset_pu
    1     0000c172  pfc_vACRmsMeasAvg_pu
    1     0000c170  pfc_vBusAvg_pu
    1     0000c18a  pfc_vBusError_pu
    1     0000c8f4  pfc_vBusMeasBuffIndex
    1     0000c898  pfc_vBusMeasBuff_pu
    1     0000c1ae  pfc_vBusMeasFiltered_pu
    1     0000c178  pfc_vBusMeasOffset_pu
    1     0000c18e  pfc_vBusRefSlewed_pu
    1     0000c17a  pfc_vBusRef_pu
    1     0000c17c  pfc_vBus_sensedFiltered_notch1
    1     0000c17e  pfc_vBus_sensedFiltered_notch2
    1     0000c176  pfc_vBus_sensed_pu
    1     0000c01b  pfc_vL1_adc_counts_max
    1     0000c01a  pfc_vL1_adc_counts_min
    1     0000c1c0  pfc_vL1_adc_pu_max
    1     0000c1be  pfc_vL1_adc_pu_min
    1     0000c1c2  pfc_vL1_offset_pu
    1     0000c01d  pfc_vL2_adc_counts_max
    1     0000c01c  pfc_vL2_adc_counts_min
    1     0000c1c6  pfc_vL2_adc_pu_max
    1     0000c1c4  pfc_vL2_adc_pu_min
    1     0000c1c8  pfc_vL2_offset_pu
    1     0000c019  pfc_v_adc_counts_max
    1     0000c018  pfc_v_adc_counts_min
    1     0000c1ba  pfc_v_adc_pu_max
    1     0000c1b8  pfc_v_adc_pu_min
    1     0000c1bc  pfc_v_offset_pu
    1     0000cb68  pi_L2_settings
    1     0000cb52  pi_ph3_settings
    1     0000c6e2  plantMagVect
    1     0000c7aa  plantPhaseVect
    1     0000c8ee  pm_heatsinkDeratedValue
    1     0000c8c4  pm_heatsinkTemperature
    1     0000c8ec  pm_temperatureDerateRatio
    1     0000c300  power_analyzer
    1     0000c2c0  power_measurement
    1     0000c072  regen_cnt
    1     0000c074  regen_cnt_Max
    1     0000c062  regen_theta
    0     00338365  reset_PRcontrollers
    1     0000c1d2  rgen1
    1     0000c8da  rk_pi
    1     0000c013  rlyConnect
    0     00339e90  rsvd_ISR
    0     00338362  scaleTempTo100ths
    0     00338021  setupSFRA
    1     0000c240  sfra1
    0     0033adbc  sinf
    1     0000c009  slewState
    1     0000c3c0  spll1
    1     0000c280  spll2
    1     0000c440  spll3
    1     0000c076  spll_regen_syncOn
    1     0000c340  spll_signal_generator
    0     0033af09  sqrtf
    1     0000cba6  t100mSecCtr
    1     0000cba2  t100uSecCtr
    1     0000cba5  t10mSecCtr
    1     0000cba8  t1SecCtr
    1     0000cba3  t1mSecCtr
    1     0000cba7  t500mSecCtr
    1     0000cba4  t5mSecCtr
    0     0033ac1b  tanf
    1     0000c8c7  tempChange
    1     0000c8e0  uk_pi
    1     0000c006  updatecoeff
    1     0000c8e8  upperlim_pi
    1     0000cc16  vBiasGrid
    1     0000cbcc  vBiasGridOffset_pu
    1     0000cc18  vBiasInv
    1     0000cbca  vBiasInvOffset_pu
    1     0000cc22  vBus
    1     0000cbc8  vBustOffset_pu
    1     0000cbb6  vGirdL3Offset_pu
    1     0000cc0e  vGridL1
    1     0000cc12  vGridL1L2
    1     0000cbb8  vGridL1L2Offset_pu
    1     0000cbb2  vGridL1Offset_pu
    1     0000cc10  vGridL2
    1     0000cbb4  vGridL2Offset_pu
    1     0000cc14  vGridL3
    1     0000cc1a  vInvL1
    1     0000cc1e  vInvL1L2
    1     0000cbc0  vInvL1L2Offset_pu
    1     0000cbba  vInvL1Offset_pu
    1     0000cc1c  vInvL2
    1     0000cbbc  vInvL2Offset_pu
    1     0000cc20  vInvL3
    1     0000cbbe  vInvL3Offset_pu
    1     0000c8c1  vL2Avg
    1     0000c900  vL2_data
    1     0000c8ca  vac_counts_inst
    1     0000cb99  vbiasgrid_avg
    1     0000cb89  vbiasgrid_buffer
    1     0000cb9a  vbiasinv_avg
    1     0000cb8a  vbiasinv_buffer
    1     0000c8c8  vbusAvg
    1     0000cb9b  vbus_avg
    1     0000cb8b  vbus_buffer
    1     0000cc54  vbus_buffer_s
    1     0000c90b  vbus_data
    1     0000c0fa  vbus_div
    1     0000c0fc  vbus_fbk_flt
    1     0000cb97  vgridL1L2_avg
    1     0000cb87  vgridL1L2_buffer
    1     0000cb96  vgridL2_avg
    1     0000cb86  vgridL2_buffer
    1     0000cc5c  vgridL2_buffer_s
    1     0000cb98  vgridL3_avg
    1     0000cb88  vgridL3_buffer
    1     0000cb95  vgridl1_avg
    1     0000cb85  vgridl1_buffer
    1     0000cc64  vgridl1_buffer_s
    1     0000cb9d  vinvL1_avg
    1     0000cb8d  vinvL1_buffer
    1     0000cb9f  vinvL2L3_avg
    1     0000cb8f  vinvL2L3_buffer
    1     0000cb9e  vinvL2_avg
    1     0000cb8e  vinvL2_buffer
    1     0000cba0  vinvL3_avg
    1     0000cb90  vinvL3_buffer
    1     0000c122  voltage_error
    1     0000c124  voltage_errorL1
    1     0000c126  voltage_errorL2
    1     0000c8c9  vp3nAvg
    1     0000c916  vp3n_data
    1     0000c092  woI_1H
    1     0000c094  woI_3H
    1     0000c096  woI_5H
    1     0000c098  woI_7H
    1     0000c09a  woI_9H
    1     0000c0b0  woV_1H
    1     0000c0b2  woV_3H
    1     0000c0b4  woV_5H
    1     0000c0b6  woV_7H
    1     0000c09c  wrcI_1H
    1     0000c09e  wrcI_3H
    1     0000c0a0  wrcI_5H
    1     0000c0a2  wrcI_7H
    1     0000c0a4  wrcI_9H
    1     0000c0b8  wrcV_1H
    1     0000c0ba  wrcV_3H
    1     0000c0bc  wrcV_5H
    1     0000c0be  wrcV_7H
    1     0000c8dc  yk_pi
    1     0000c014  zeroCrossDetectFlag
    1     0000c8c5  zero_crossing_reset
    GLOBAL SYMBOLS: SORTED BY Symbol Address
    page  address   name
    0     00339e90  rsvd_ISR
    0     00339fe4  NMI_ISR
    0     0033a016  LVF_ISR
    0     0033a020  LUF_ISR
    0     0033a576  PWM_Init
    0     0033a90f  InitPll
    0     0033a9ed  ASM_Init
    0     0033ac1b  tanf
    0     0033ad84  logf
    0     0033adbc  sinf
    0     0033ae73  C$$EXIT
    0     0033ae73  abort
    0     0033ae75  exit
    0     0033af09  sqrtf
    0     0033af2a  memcpy
    0     0033af7c  _c_int00
    0     0033afa4  main
    0     0033afcc  memset
    0     0033afd4  _nop
    0     00380080  _ADC_cal
    1     00000400  __stack
    1     00000ae0  CsmRegs
    1     00007100  AdcRegs
    1     0000c00a  i
    1     0000c016  period
    1     0000c022  gv_out
    1     0000c026  gv_outL1
    1     0000c02a  gv_outL2
    1     0000c030  guiVbus
    1     0000c03a  guiVin
    1     0000c03c  guiIL
    1     0000c042  guiPrms
    1     0000c044  guiIrms
    1     0000c046  guiVrms
    1     0000c048  guiVavg
    1     0000c04a  guiVo
    1     0000c04c  guiIi
    1     0000c04e  guiIo
    1     0000c052  guiVA
    1     0000c056  guiVema
    1     0000c07a  gi_out
    1     0000c07c  gi_outL1
    1     0000c07e  gi_outL2
    1     0000c086  kpI_1H
    1     0000c088  kiI_1H
    1     0000c08a  kiI_3H
    1     0000c08c  kiI_5H
    1     0000c08e  kiI_7H
    1     0000c090  kiI_9H
    1     0000c092  woI_1H
    1     0000c094  woI_3H
    1     0000c096  woI_5H
    1     0000c098  woI_7H
    1     0000c09a  woI_9H
    1     0000c09c  wrcI_1H
    1     0000c09e  wrcI_3H
    1     0000c0a0  wrcI_5H
    1     0000c0a2  wrcI_7H
    1     0000c0a4  wrcI_9H
    1     0000c0a6  kpV_1H
    1     0000c0a8  kiV_1H
    1     0000c0aa  kiV_3H
    1     0000c0ac  kiV_5H
    1     0000c0ae  kiV_7H
    1     0000c0b0  woV_1H
    1     0000c0b2  woV_3H
    1     0000c0b4  woV_5H
    1     0000c0b6  woV_7H
    1     0000c0b8  wrcV_1H
    1     0000c0ba  wrcV_3H
    1     0000c0bc  wrcV_5H
    1     0000c0be  wrcV_7H
    1     0000c0c0  c2
    1     0000c0c2  c1
    1     0000c0fa  vbus_div
    1     0000c106  pfcIiRef
    1     0000c108  invIoRef
    1     0000c10a  invVoRef
    1     0000c130  invSine
    1     0000c136  IQCMPRA
    1     0000c1d2  rgen1
    1     0000c240  sfra1
    1     0000c280  spll2
    1     0000c3c0  spll1
    1     0000c440  spll3
    1     0000c48a  freqVect
    1     0000c8c1  vL2Avg
    1     0000c8c8  vbusAvg
    1     0000c8c9  vp3nAvg
    1     0000c8d4  l2_sp_pi
    1     0000c8da  rk_pi
    1     0000c8dc  yk_pi
    1     0000c8de  lk_pi
    1     0000c8e0  uk_pi
    1     0000c8e2  imax_pi
    1     0000c8e4  imin_pi
    1     0000c8f0  k1
    1     0000c8f2  k2
    1     0000c900  vL2_data
    1     0000c940  gi
    1     0000c952  gv_pr1
    1     0000c964  gv_r3
    1     0000c980  gv_r5
    1     0000c992  gv_r7
    1     0000c9a4  gv_r9
    1     0000c9c0  gv_r11
    1     0000c9d2  gv_prL1
    1     0000c9e4  gv_r3L1
    1     0000ca00  gv_r5L1
    1     0000ca12  gv_r7L1
    1     0000ca24  gv_prL2
    1     0000ca40  gv_r3L2
    1     0000ca52  gv_r5L2
    1     0000ca64  gv_r7L2
    1     0000ca92  notch1
    1     0000caa4  notch2
    1     0000cac0  gi_pr1
    1     0000cad2  gi_r3
    1     0000cae4  gi_r5
    1     0000cb00  gi_r7
    1     0000cb12  gi_r9
    1     0000cb24  gi_r11
    1     0000cb7e  _lock
    1     0000cb9b  vbus_avg
    1     0000cba8  t1SecCtr
    1     0000cbd0  DTC_list
    1     0000cc0e  vGridL1
    1     0000cc10  vGridL2
    1     0000cc14  vGridL3
    1     0000cc18  vBiasInv
    1     0000cc1a  vInvL1
    1     0000cc1c  vInvL2
    1     0000cc1e  vInvL1L2
    1     0000cc20  vInvL3
    1     0000cc22  vBus
    1     0000cc24  ioutL1
    1     0000cc26  ioutL2
    1     0000cc28  ioutL3
    1     0000cc2a  ishunt
    1     0033fff8  CsmPwl
    [742 symbols]
  • Hi Wilson,
    Does it change if using a different Flash Sector for loading .TI.ramfuncs? The original F28335.cmd file loads from Sector D.
    What happens if you load the program in CCS and step through the device initialization within main? Does it ever reach main after loading the code?
    Thanks and regards,
    Charles
  • Charles,
    I don't have any problem if I'm debugging the run as it should be. If I program the MCU and power cycle, the code never runs, making me think that the MCU is not booting from Flash.
  • Hi Wilson,
    After loading code and power cycling the MCU, can you connect to CCS again and perform a memory dump for the affected Flash areas?
    Looking to rule out the program not being loaded to Flash.
    If you are able to load the code through the bootloader, can you perform a memory dump and compare the two?
    Charles
