TMS320F2800157: Application issues
Expert 2330 points
Part Number: TMS320F2800157
Using the TMS320F2800157 new project, please help check if there are any unreasonable schematic diagrams. thanks!
TZ1 and TZ2 are overcurrent and current limiting interrupt signals,
  • Hi Reed,
    Those highlighted GPIOs are AGPIO (can be used either an Analog or digital pin). I assume you are seeing random values.
    Can you confirm if this function is enabled correctly in your code?
    If not, can you ellaborate on what is going wrong?
    Uttam
