LAUNCHXL-F280049C: How to generate nanosecond delay using DEVICE_DELAY_US or SysCtl_delay()?
Part Number: LAUNCHXL-F280049C
I'm a beginner of DSP and right now I'm trying to program a double-pulse test waveform. I tried to modify DEVICE_DELAY_US to create an interval of tens of nanoseconds, but it seems the minimum delay is merely 1us? Is there a easy way to generate two pulse with nanoscale interval between?
Thank you,
Tian
  • Hi Tian,
    I havent tried making a define for nano sec delay. But you can try making your own define for nano sec delay by modifying the usec delay define
    Change the 10^6 to 10^9 and see how it works.
    What pulse are you generating with this delay ?
    Have you tried using PWM module to do the same, delay seems like an inefficient way to do this.
