Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
TIDM-02000: PSFB(Phase shift full bridge) leading leg & lagging leg change.
Part Number: TIDM-02000
Other Parts Discussed in Thread: TMS320F280039,
Hello. I am Sam.
I am developing PSFB DCDC convertor using TIDM-02000 and using TMS320F280039.
With Reference to TIDM-02000, ePWM2A/B is leading leg and ePWM1A/B is lagging leg.
I would like to change the leading leg to ePWM1 and the lagging leg to ePWM2.
In the code below, I changed PSFB_FB_PWM1_BASE to EPWM2_BASE and PSFB_FB_PWM2_BASE to EPWM1_BASE to check switching, but it did not work.
The SR switch was turned off and tested.
Is there anything else I need to do to change EPWM1_BASE and EPWM2_BASE?
Thank you.
