Other Parts Discussed in Thread: TMS320F28035, CCSTUDIO, CONTROLSUITE, TMS320F28335
What's the easiest way to implement FAT library out there that will fit in the small 128-KB flash of TMS320F28035? All I need is read and write in FAT16.
Keith,
I'd also be interested to see your map file. It should be in the same directory as the .out file and should have a .map extension.
Also try declaring the file name seperately in a variable like this:
const char fileName[] = {"0:Untitled.bmp"};
then call f_open like this:
fresult = f_open(&g_sFileObject, fileName, FA_READ);
If you do this, the filename will end up being stored in flash and CANNOT be overwritten by anything else. FYI you may have to cast fileName to get this to compile.
Try this and report back.
Trey
map file (converted to .txt):
TMS320C2000 Linker PC v6.1.0
>> Linked Mon Jul 16 11:47:55 2012
OUTPUT FILE NAME: <Screen Test.out>
ENTRY POINT SYMBOL: "_c_int00" address: 00009770
MEMORY CONFIGURATION
name origin length used unused attr fill
PAGE 0:
BEGIN 00000000 00000002 00000002 00000000 RWIX
RAMM0 00000050 000003b0 00000000 000003b0 RWIX
RAML0 00008000 00001000 00000041 00000fbf RWIX
RAML1 00009000 00001000 00000841 000007bf RWIX
RAML2 0000a000 00001000 00000000 00001000 RWIX
RAML3 0000b000 00001000 00000000 00001000 RWIX
ZONE7A 00200000 0000fc00 00000000 0000fc00 RWIX
CSM_RSVD 0033ff80 00000076 00000000 00000076 RWIX
CSM_PWL 0033fff8 00000008 00000000 00000008 RWIX
ADC_CAL 00380080 00000009 00000007 00000002 RWIX
IQTABLES 003fe000 00000b50 00000000 00000b50 RWIX
IQTABLES2 003feb50 0000008c 00000000 0000008c RWIX
FPUTABLES 003febdc 000006a0 00000000 000006a0 RWIX
BOOTROM 003ff27c 00000d44 00000000 00000d44 RWIX
RESET 003fffc0 00000002 00000000 00000002 RWIX
PAGE 1:
BOOT_RSVD 00000002 0000004e 00000000 0000004e RWIX
RAMM1 00000400 00000400 00000300 00000100 RWIX
DEV_EMU 00000880 00000180 000000d0 000000b0 RWIX
FLASH_REGS 00000a80 00000060 00000008 00000058 RWIX
CSM 00000ae0 00000010 00000010 00000000 RWIX
ADC_MIRROR 00000b00 00000010 00000010 00000000 RWIX
XINTF 00000b20 00000020 0000001e 00000002 RWIX
CPU_TIMER0 00000c00 00000008 00000008 00000000 RWIX
CPU_TIMER1 00000c08 00000008 00000008 00000000 RWIX
CPU_TIMER2 00000c10 00000008 00000008 00000000 RWIX
PIE_CTRL 00000ce0 00000020 0000001a 00000006 RWIX
PIE_VECT 00000d00 00000100 00000100 00000000 RWIX
DMA 00001000 00000200 000000e0 00000120 RWIX
MCBSPA 00005000 00000040 00000025 0000001b RWIX
MCBSPB 00005040 00000040 00000025 0000001b RWIX
ECANA 00006000 00000040 00000034 0000000c RWIX
ECANA_LAM 00006040 00000040 00000040 00000000 RWIX
ECANA_MOTS 00006080 00000040 00000040 00000000 RWIX
ECANA_MOTO 000060c0 00000040 00000040 00000000 RWIX
ECANA_MBOX 00006100 00000100 00000100 00000000 RWIX
ECANB 00006200 00000040 00000034 0000000c RWIX
ECANB_LAM 00006240 00000040 00000040 00000000 RWIX
ECANB_MOTS 00006280 00000040 00000040 00000000 RWIX
ECANB_MOTO 000062c0 00000040 00000040 00000000 RWIX
ECANB_MBOX 00006300 00000100 00000100 00000000 RWIX
EPWM1 00006800 00000022 00000022 00000000 RWIX
EPWM2 00006840 00000022 00000022 00000000 RWIX
EPWM3 00006880 00000022 00000022 00000000 RWIX
EPWM4 000068c0 00000022 00000022 00000000 RWIX
EPWM5 00006900 00000022 00000022 00000000 RWIX
EPWM6 00006940 00000022 00000022 00000000 RWIX
ECAP1 00006a00 00000020 00000020 00000000 RWIX
ECAP2 00006a20 00000020 00000020 00000000 RWIX
ECAP3 00006a40 00000020 00000020 00000000 RWIX
ECAP4 00006a60 00000020 00000020 00000000 RWIX
ECAP5 00006a80 00000020 00000020 00000000 RWIX
ECAP6 00006aa0 00000020 00000020 00000000 RWIX
EQEP1 00006b00 00000040 00000040 00000000 RWIX
EQEP2 00006b40 00000040 00000040 00000000 RWIX
GPIOCTRL 00006f80 00000040 0000002e 00000012 RWIX
GPIODAT 00006fc0 00000020 00000020 00000000 RWIX
GPIOINT 00006fe0 00000020 0000000a 00000016 RWIX
SYSTEM 00007010 00000020 00000020 00000000 RWIX
SPIA 00007040 00000010 00000010 00000000 RWIX
SCIA 00007050 00000010 00000010 00000000 RWIX
XINTRUPT 00007070 00000010 00000010 00000000 RWIX
ADC 00007100 00000020 0000001e 00000002 RWIX
SCIB 00007750 00000010 00000010 00000000 RWIX
SCIC 00007770 00000010 00000010 00000000 RWIX
I2CA 00007900 00000040 00000022 0000001e RWIX
RAML4 0000c000 00001000 00000023 00000fdd RWIX
RAML5 0000d000 00001000 00000ca6 0000035a RWIX
RAML6 0000e000 00001000 00000000 00001000 RWIX
RAML7 0000f000 00001000 00000000 00001000 RWIX
ZONE7B 0020fc00 00000400 00000000 00000400 RWIX
CSM_PWL 0033fff8 00000008 00000008 00000000 RWIX
PARTID 00380090 00000001 00000001 00000000 RWIX
SECTION ALLOCATION MAP
output attributes/
section page origin length input sections
codestart
* 0 00000000 00000002
00000000 00000002 DSP2833x_CodeStartBranch.obj (codestart)
.pinit 0 00008000 00000000 UNINITIALIZED
.cinit 0 00008000 00000022
00008000 0000000c Screen_Test.obj (.cinit)
0000800c 0000000a rts2800_fpu32.lib : _lock.obj (.cinit)
00008016 0000000a : exit.obj (.cinit)
00008020 00000002 --HOLE-- [fill = 0]
ramfuncs 0 00008022 0000001f
00008022 0000001b DSP2833x_SysCtrl.obj (ramfuncs)
0000803d 00000004 DSP2833x_usDelay.obj (ramfuncs)
.text 0 00009000 00000841
00009000 00000316 DSP2833x_DefaultIsr.obj (.text:retain)
00009316 000002f3 Screen_Test.obj (.text)
00009609 000000f3 DSP2833x_SysCtrl.obj (.text)
000096fc 00000074 DSP2833x_CpuTimers.obj (.text)
00009770 00000046 rts2800_fpu32.lib : boot.obj (.text)
000097b6 00000028 DSP2833x_PieCtrl.obj (.text)
000097de 00000020 DSP2833x_PieVect.obj (.text)
000097fe 00000019 rts2800_fpu32.lib : args_main.obj (.text)
00009817 00000019 : exit.obj (.text)
00009830 00000009 : _lock.obj (.text)
00009839 00000008 DSP2833x_CodeStartBranch.obj (.text)
csm_rsvd 0 0033ff80 00000000 DSECT
csmpasswds
* 0 0033fff8 00000000 DSECT
.adc_cal 0 00380080 00000007 NOLOAD SECTION
00380080 00000007 DSP2833x_ADC_cal.obj (.adc_cal)
.reset 0 003fffc0 00000002 DSECT
003fffc0 00000002 rts2800_fpu32.lib : boot.obj (.reset)
.stack 1 00000400 00000300 UNINITIALIZED
00000400 00000300 --HOLE--
DevEmuRegsFile
* 1 00000880 000000d0 UNINITIALIZED
00000880 000000d0 DSP2833x_GlobalVariableDefs.obj (DevEmuRegsFile)
FlashRegsFile
* 1 00000a80 00000008 UNINITIALIZED
00000a80 00000008 DSP2833x_GlobalVariableDefs.obj (FlashRegsFile)
CsmRegsFile
* 1 00000ae0 00000010 UNINITIALIZED
00000ae0 00000010 DSP2833x_GlobalVariableDefs.obj (CsmRegsFile)
AdcMirrorFile
* 1 00000b00 00000010 UNINITIALIZED
00000b00 00000010 DSP2833x_GlobalVariableDefs.obj (AdcMirrorFile)
XintfRegsFile
* 1 00000b20 0000001e UNINITIALIZED
00000b20 0000001e DSP2833x_GlobalVariableDefs.obj (XintfRegsFile)
CpuTimer0RegsFile
* 1 00000c00 00000008 UNINITIALIZED
00000c00 00000008 DSP2833x_GlobalVariableDefs.obj (CpuTimer0RegsFile)
CpuTimer1RegsFile
* 1 00000c08 00000008 UNINITIALIZED
00000c08 00000008 DSP2833x_GlobalVariableDefs.obj (CpuTimer1RegsFile)
CpuTimer2RegsFile
* 1 00000c10 00000008 UNINITIALIZED
00000c10 00000008 DSP2833x_GlobalVariableDefs.obj (CpuTimer2RegsFile)
PieCtrlRegsFile
* 1 00000ce0 0000001a UNINITIALIZED
00000ce0 0000001a DSP2833x_GlobalVariableDefs.obj (PieCtrlRegsFile)
PieVectTableFile
* 1 00000d00 00000100 UNINITIALIZED
00000d00 00000100 DSP2833x_GlobalVariableDefs.obj (PieVectTableFile)
DmaRegsFile
* 1 00001000 000000e0 UNINITIALIZED
00001000 000000e0 DSP2833x_GlobalVariableDefs.obj (DmaRegsFile)
McbspaRegsFile
* 1 00005000 00000025 UNINITIALIZED
00005000 00000025 DSP2833x_GlobalVariableDefs.obj (McbspaRegsFile)
McbspbRegsFile
* 1 00005040 00000025 UNINITIALIZED
00005040 00000025 DSP2833x_GlobalVariableDefs.obj (McbspbRegsFile)
ECanaRegsFile
* 1 00006000 00000034 UNINITIALIZED
00006000 00000034 DSP2833x_GlobalVariableDefs.obj (ECanaRegsFile)
ECanaLAMRegsFile
* 1 00006040 00000040 UNINITIALIZED
00006040 00000040 DSP2833x_GlobalVariableDefs.obj (ECanaLAMRegsFile)
ECanaMOTSRegsFile
* 1 00006080 00000040 UNINITIALIZED
00006080 00000040 DSP2833x_GlobalVariableDefs.obj (ECanaMOTSRegsFile)
ECanaMOTORegsFile
* 1 000060c0 00000040 UNINITIALIZED
000060c0 00000040 DSP2833x_GlobalVariableDefs.obj (ECanaMOTORegsFile)
ECanaMboxesFile
* 1 00006100 00000100 UNINITIALIZED
00006100 00000100 DSP2833x_GlobalVariableDefs.obj (ECanaMboxesFile)
ECanbRegsFile
* 1 00006200 00000034 UNINITIALIZED
00006200 00000034 DSP2833x_GlobalVariableDefs.obj (ECanbRegsFile)
ECanbLAMRegsFile
* 1 00006240 00000040 UNINITIALIZED
00006240 00000040 DSP2833x_GlobalVariableDefs.obj (ECanbLAMRegsFile)
ECanbMOTSRegsFile
* 1 00006280 00000040 UNINITIALIZED
00006280 00000040 DSP2833x_GlobalVariableDefs.obj (ECanbMOTSRegsFile)
ECanbMOTORegsFile
* 1 000062c0 00000040 UNINITIALIZED
000062c0 00000040 DSP2833x_GlobalVariableDefs.obj (ECanbMOTORegsFile)
ECanbMboxesFile
* 1 00006300 00000100 UNINITIALIZED
00006300 00000100 DSP2833x_GlobalVariableDefs.obj (ECanbMboxesFile)
EPwm1RegsFile
* 1 00006800 00000022 UNINITIALIZED
00006800 00000022 DSP2833x_GlobalVariableDefs.obj (EPwm1RegsFile)
EPwm2RegsFile
* 1 00006840 00000022 UNINITIALIZED
00006840 00000022 DSP2833x_GlobalVariableDefs.obj (EPwm2RegsFile)
EPwm3RegsFile
* 1 00006880 00000022 UNINITIALIZED
00006880 00000022 DSP2833x_GlobalVariableDefs.obj (EPwm3RegsFile)
EPwm4RegsFile
* 1 000068c0 00000022 UNINITIALIZED
000068c0 00000022 DSP2833x_GlobalVariableDefs.obj (EPwm4RegsFile)
EPwm5RegsFile
* 1 00006900 00000022 UNINITIALIZED
00006900 00000022 DSP2833x_GlobalVariableDefs.obj (EPwm5RegsFile)
EPwm6RegsFile
* 1 00006940 00000022 UNINITIALIZED
00006940 00000022 DSP2833x_GlobalVariableDefs.obj (EPwm6RegsFile)
ECap1RegsFile
* 1 00006a00 00000020 UNINITIALIZED
00006a00 00000020 DSP2833x_GlobalVariableDefs.obj (ECap1RegsFile)
ECap2RegsFile
* 1 00006a20 00000020 UNINITIALIZED
00006a20 00000020 DSP2833x_GlobalVariableDefs.obj (ECap2RegsFile)
ECap3RegsFile
* 1 00006a40 00000020 UNINITIALIZED
00006a40 00000020 DSP2833x_GlobalVariableDefs.obj (ECap3RegsFile)
ECap4RegsFile
* 1 00006a60 00000020 UNINITIALIZED
00006a60 00000020 DSP2833x_GlobalVariableDefs.obj (ECap4RegsFile)
ECap5RegsFile
* 1 00006a80 00000020 UNINITIALIZED
00006a80 00000020 DSP2833x_GlobalVariableDefs.obj (ECap5RegsFile)
ECap6RegsFile
* 1 00006aa0 00000020 UNINITIALIZED
00006aa0 00000020 DSP2833x_GlobalVariableDefs.obj (ECap6RegsFile)
EQep1RegsFile
* 1 00006b00 00000040 UNINITIALIZED
00006b00 00000040 DSP2833x_GlobalVariableDefs.obj (EQep1RegsFile)
EQep2RegsFile
* 1 00006b40 00000040 UNINITIALIZED
00006b40 00000040 DSP2833x_GlobalVariableDefs.obj (EQep2RegsFile)
GpioCtrlRegsFile
* 1 00006f80 0000002e UNINITIALIZED
00006f80 0000002e DSP2833x_GlobalVariableDefs.obj (GpioCtrlRegsFile)
GpioDataRegsFile
* 1 00006fc0 00000020 UNINITIALIZED
00006fc0 00000020 DSP2833x_GlobalVariableDefs.obj (GpioDataRegsFile)
GpioIntRegsFile
* 1 00006fe0 0000000a UNINITIALIZED
00006fe0 0000000a DSP2833x_GlobalVariableDefs.obj (GpioIntRegsFile)
SysCtrlRegsFile
* 1 00007010 00000020 UNINITIALIZED
00007010 00000020 DSP2833x_GlobalVariableDefs.obj (SysCtrlRegsFile)
SpiaRegsFile
* 1 00007040 00000010 UNINITIALIZED
00007040 00000010 DSP2833x_GlobalVariableDefs.obj (SpiaRegsFile)
SciaRegsFile
* 1 00007050 00000010 UNINITIALIZED
00007050 00000010 DSP2833x_GlobalVariableDefs.obj (SciaRegsFile)
XIntruptRegsFile
* 1 00007070 00000010 UNINITIALIZED
00007070 00000010 DSP2833x_GlobalVariableDefs.obj (XIntruptRegsFile)
AdcRegsFile
* 1 00007100 0000001e UNINITIALIZED
00007100 0000001e DSP2833x_GlobalVariableDefs.obj (AdcRegsFile)
ScibRegsFile
* 1 00007750 00000010 UNINITIALIZED
00007750 00000010 DSP2833x_GlobalVariableDefs.obj (ScibRegsFile)
ScicRegsFile
* 1 00007770 00000010 UNINITIALIZED
00007770 00000010 DSP2833x_GlobalVariableDefs.obj (ScicRegsFile)
I2caRegsFile
* 1 00007900 00000022 UNINITIALIZED
00007900 00000022 DSP2833x_GlobalVariableDefs.obj (I2caRegsFile)
.ebss 1 0000c000 00000023 UNINITIALIZED
0000c000 00000018 DSP2833x_CpuTimers.obj (.ebss)
0000c018 00000004 rts2800_fpu32.lib : _lock.obj (.ebss)
0000c01c 00000004 : exit.obj (.ebss)
0000c020 00000003 Screen_Test.obj (.ebss)
.econst 1 0000d000 00000ca6
0000d000 00000ba5 Screen_Test.obj (.econst:_seg54)
0000dba5 00000001 --HOLE-- [fill = 0]
0000dba6 00000100 DSP2833x_PieVect.obj (.econst)
CsmPwlFile
* 1 0033fff8 00000008 UNINITIALIZED
0033fff8 00000008 DSP2833x_GlobalVariableDefs.obj (CsmPwlFile)
PartIdRegsFile
* 1 00380090 00000001 UNINITIALIZED
00380090 00000001 DSP2833x_GlobalVariableDefs.obj (PartIdRegsFile)
GLOBAL SYMBOLS: SORTED ALPHABETICALLY BY Name
address name
00009000 .text
00009817 C$$EXIT
000090e6 _ADCINT_ISR
00380080 _ADC_cal
00000b00 _AdcMirror
00007100 _AdcRegs
0000952e _Clear_Screen
000094e9 _Command_Write
00009735 _ConfigCpuTimer
0000c010 _CpuTimer0
00000c00 _CpuTimer0Regs
0000c000 _CpuTimer1
00000c08 _CpuTimer1Regs
0000c008 _CpuTimer2
00000c10 _CpuTimer2Regs
0033fff8 _CsmPwl
00000ae0 _CsmRegs
000096cb _CsmUnlock
00009014 _DATALOG_ISR
00009208 _DINTCH1_ISR
00009212 _DINTCH2_ISR
0000921c _DINTCH3_ISR
00009226 _DINTCH4_ISR
00009230 _DINTCH5_ISR
0000923a _DINTCH6_ISR
0000803d _DSP28x_usDelay
00000880 _DevEmuRegs
0000961c _DisableDog
00001000 _DmaRegs
00009294 _ECAN0INTA_ISR
000092a8 _ECAN0INTB_ISR
0000929e _ECAN1INTA_ISR
000092b2 _ECAN1INTB_ISR
0000917c _ECAP1_INT_ISR
00009186 _ECAP2_INT_ISR
00009190 _ECAP3_INT_ISR
0000919a _ECAP4_INT_ISR
000091a4 _ECAP5_INT_ISR
000091ae _ECAP6_INT_ISR
00006040 _ECanaLAMRegs
000060c0 _ECanaMOTORegs
00006080 _ECanaMOTSRegs
00006100 _ECanaMboxes
00006000 _ECanaRegs
00006240 _ECanbLAMRegs
000062c0 _ECanbMOTORegs
00006280 _ECanbMOTSRegs
00006300 _ECanbMboxes
00006200 _ECanbRegs
00006a00 _ECap1Regs
00006a20 _ECap2Regs
00006a40 _ECap3Regs
00006a60 _ECap4Regs
00006a80 _ECap5Regs
00006aa0 _ECap6Regs
00009028 _EMUINT_ISR
00009140 _EPWM1_INT_ISR
00009104 _EPWM1_TZINT_ISR
0000914a _EPWM2_INT_ISR
0000910e _EPWM2_TZINT_ISR
00009154 _EPWM3_INT_ISR
00009118 _EPWM3_TZINT_ISR
0000915e _EPWM4_INT_ISR
00009122 _EPWM4_TZINT_ISR
00009168 _EPWM5_INT_ISR
0000912c _EPWM5_TZINT_ISR
00009172 _EPWM6_INT_ISR
00009136 _EPWM6_TZINT_ISR
00006800 _EPwm1Regs
00006840 _EPwm2Regs
00006880 _EPwm3Regs
000068c0 _EPwm4Regs
00006900 _EPwm5Regs
00006940 _EPwm6Regs
000091b8 _EQEP1_INT_ISR
000091c2 _EQEP2_INT_ISR
00006b00 _EQep1Regs
00006b40 _EQep2Regs
000097d5 _EnableInterrupts
00000a80 _FlashRegs
00006f80 _GpioCtrlRegs
00006fc0 _GpioDataRegs
00006fe0 _GpioIntRegs
00009316 _Gpio_setup
00009244 _I2CINT1A_ISR
0000924e _I2CINT2A_ISR
00007900 _I2caRegs
0000903c _ILLEGAL_ISR
00009000 _INT13_ISR
0000900a _INT14_ISR
000096fc _InitCpuTimers
00008022 _InitFlash
00009670 _InitPeripheralClocks
000097b6 _InitPieCtrl
000097de _InitPieVectTable
00009624 _InitPll
00009609 _InitSysCtrl
000092f8 _LUF_ISR
000092ee _LVF_ISR
000091f4 _MRINTA_ISR
000091e0 _MRINTB_ISR
000091fe _MXINTA_ISR
000091ea _MXINTB_ISR
00005000 _McbspaRegs
00005040 _McbspbRegs
00009032 _NMI_ISR
00009302 _PIE_RESERVED
00380090 _PartIdRegs
00000ce0 _PieCtrlRegs
00000d00 _PieVectTable
0000dba6 _PieVectTableInit
0000901e _RTOSINT_ISR
000094f3 _Read_Data
0000926c _SCIRXINTA_ISR
00009280 _SCIRXINTB_ISR
00009258 _SCIRXINTC_ISR
00009276 _SCITXINTA_ISR
0000928a _SCITXINTB_ISR
00009262 _SCITXINTC_ISR
000090be _SEQ1INT_ISR
000090c8 _SEQ2INT_ISR
000091cc _SPIRXINTA_ISR
000091d6 _SPITXINTA_ISR
00007050 _SciaRegs
00007750 _ScibRegs
00007770 _ScicRegs
00009325 _Screen_Init
00009612 _ServiceDog
00007040 _SpiaRegs
00007010 _SysCtrlRegs
000090f0 _TINT0_ISR
000090a0 _USER10_ISR
000090aa _USER11_ISR
000090b4 _USER12_ISR
00009046 _USER1_ISR
00009050 _USER2_ISR
0000905a _USER3_ISR
00009064 _USER4_ISR
0000906e _USER5_ISR
00009078 _USER6_ISR
00009082 _USER7_ISR
0000908c _USER8_ISR
00009096 _USER9_ISR
000090fa _WAKEINT_ISR
00009501 _Window_Set
00009435 _Write_Char
000093eb _Write_Command
00009410 _Write_Data
000094da _Write_RGB
000090d2 _XINT1_ISR
000090dc _XINT2_ISR
000092bc _XINT3_ISR
000092c6 _XINT4_ISR
000092d0 _XINT5_ISR
000092da _XINT6_ISR
000092e4 _XINT7_ISR
00007070 _XIntruptRegs
00000b20 _XintfRegs
00000700 __STACK_END
00000300 __STACK_SIZE
00000001 __TI_args_main
ffffffff ___binit__
ffffffff ___c_args__
00008000 ___cinit__
00009841 ___etext__
ffffffff ___pinit__
00009000 ___text__
000097fe __args_main
0000c01c __cleanup_ptr
0000c01e __dtors_ptr
0000c01a __lock
00009838 __nop
00009834 __register_lock
00009830 __register_unlock
00000400 __stack
0000c018 __unlock
00009817 _abort
0000c021 _blue
00009770 _c_int00
0000954e _delayms
00009819 _exit
0000c020 _green
0000956c _main
0000c022 _red
0000930c _rsvd_ISR
0000d000 _seg54
ffffffff binit
00008000 cinit
00000000 code_start
00009841 etext
ffffffff pinit
GLOBAL SYMBOLS: SORTED BY Symbol Address
address name
00000000 code_start
00000400 __stack
00000a80 _FlashRegs
00000ae0 _CsmRegs
00000b00 _AdcMirror
00000b20 _XintfRegs
00001000 _DmaRegs
00006000 _ECanaRegs
00006200 _ECanbRegs
00006800 _EPwm1Regs
00006840 _EPwm2Regs
00006880 _EPwm3Regs
000068c0 _EPwm4Regs
00006900 _EPwm5Regs
00006940 _EPwm6Regs
00006a00 _ECap1Regs
00006a20 _ECap2Regs
00006a40 _ECap3Regs
00006a60 _ECap4Regs
00006a80 _ECap5Regs
00006aa0 _ECap6Regs
00006b00 _EQep1Regs
00006b40 _EQep2Regs
00007040 _SpiaRegs
00007050 _SciaRegs
00007100 _AdcRegs
00007750 _ScibRegs
00007770 _ScicRegs
00007900 _I2caRegs
00008000 ___cinit__
00008000 cinit
00008022 _InitFlash
00009000 .text
00009000 _INT13_ISR
00009000 ___text__
0000900a _INT14_ISR
00009032 _NMI_ISR
00009046 _USER1_ISR
00009050 _USER2_ISR
0000905a _USER3_ISR
00009064 _USER4_ISR
0000906e _USER5_ISR
00009078 _USER6_ISR
00009082 _USER7_ISR
0000908c _USER8_ISR
00009096 _USER9_ISR
000090d2 _XINT1_ISR
000090dc _XINT2_ISR
000090f0 _TINT0_ISR
000092bc _XINT3_ISR
000092c6 _XINT4_ISR
000092d0 _XINT5_ISR
000092da _XINT6_ISR
000092e4 _XINT7_ISR
000092ee _LVF_ISR
000092f8 _LUF_ISR
0000930c _rsvd_ISR
000094da _Write_RGB
000094f3 _Read_Data
0000954e _delayms
0000956c _main
00009624 _InitPll
000096cb _CsmUnlock
00009770 _c_int00
00009817 C$$EXIT
00009817 _abort
00009819 _exit
00009838 __nop
00009841 ___etext__
00009841 etext
0000c000 _CpuTimer1
0000c008 _CpuTimer2
0000c010 _CpuTimer0
0000c018 __unlock
0000c01a __lock
0000c020 _green
0000c021 _blue
0000c022 _red
0000d000 _seg54
0033fff8 _CsmPwl
00380080 _ADC_cal
ffffffff ___binit__
ffffffff ___pinit__
ffffffff binit
ffffffff pinit
[191 symbols]
I tried declaring the file name as you suggested and had the same results as before successful read the first time, failure each subsequent time.
Unfortunately, due to the headaches we've had thus far, I've been instructed by the powers that be to abandon development with this processor. However, as a learning opportunity, I would like to continue to debug this issue, just for my own benefit.
