LAUNCHXL-F28379D: F28379D
Part Number: LAUNCHXL-F28379D
Most is copy from segbot/github : but i cant strat it up becauseof of some issues with memory: //#############################################################################
// FILE: segbot_main.c
// TITLE: Segbot
// Included Files
#include "segbot.h"
#include "F2837xD_device.h"
#include "device.h"
#include "driverlib.h"
#include "segbot.h"
#include "F2837xD_Examples.h"
#include <stdint.h>
#include <math.h>
#include "buffer.h"
// Include buffer instance
buffer_t dataBuffer;
// Global variables
float accelXreading = 0.0;
float accely_offset = 0.0;
float accelz_offset = 0.0;
float adcina2Volts = 0.0;
float adcina3Volts = 0.0;
uint16_t calibration_count = 0;
uint16_t calibration_state = 0;
float kalman_K = 0.0;
float kalman_P = 0.0;
float kalman_tilt = 0.0;
uint16_t numSWIcalls = 0;
float leftVel = 0.0;
float leftVelPrev = 0.0;
float leftWheel = 0.0;
float LeftWheelArray[4] = {0.0};
float leftWheelPrev = 0.0;
float rightVel = 0.0;
float rightVelPrev = 0.0;
float rightWheel = 0.0;
float RightWheelArray[4] = {0.0};
float rightWheelPrev = 0.0;
float tilt_array[4] = {0.0};
float tilt_value = 0.0;
uint16_t timecount = 0;
float turn = 0.0;
float turnError = 0.0;
float turnErrorInt = 0.0;
float turnErrorIntPrev = 0.0;
float turnErrorPrev = 0.0;
float turnRate = 0.0;
float turnRatePrev = 0.0;
float turnRef = 0.0;
float turnRefPrev = 0.0;
uint16_t UARTPrint = 0;
float ubal = 0.0;
float wheelDiff = 0.0;
float wheelDiffPrev = 0.0;
float wheelDiffVel = 0.0;
float wheelDiffVelPrev = 0.0;
int16_t SpibNumCalls = -1;
void main(void) {
// System initialization
DINT;
InitSysCtrl();
InitGpio();
EINT;
// Initialize buffer
buf_clear(&dataBuffer);
// GPIO setup
// Blue LED on LaunchPad
GPIO_SetupPinMux(31, GPIO_MUX_CPU1, 0);
GPIO_SetupPinOptions(31, GPIO_OUTPUT, GPIO_PUSHPULL);
GpioDataRegs.GPASET.bit.GPIO31 = 1;
// Red LED on LaunchPad
GPIO_SetupPinMux(34, GPIO_MUX_CPU1, 0);
GPIO_SetupPinOptions(34, GPIO_OUTPUT, GPIO_PUSHPULL);
GpioDataRegs.GPBSET.bit.GPIO34 = 1;
// Setup LEDs
// LED1 and PWM Pin
GPIO_SetupPinMux(22, GPIO_MUX_CPU1, 0);
GPIO_SetupPinOptions(22, GPIO_OUTPUT, GPIO_PUSHPULL);
GpioDataRegs.GPACLEAR.bit.GPIO22 = 1;
// LED2
GPIO_SetupPinMux(52, GPIO_MUX_CPU1, 0);
GPIO_SetupPinOptions(52, GPIO_OUTPUT, GPIO_PUSHPULL);
GpioDataRegs.GPBCLEAR.bit.GPIO52 = 1;
// Additional LEDs (LED3 to LED23)
// Other initializations
setupSpib();
init_eQEPs();
setupEPWM5();
setupADC();
setupDAC();
// Initialize timers
InitCpuTimers();
ConfigCpuTimer(&CpuTimer0, 200, 1000);
ConfigCpuTimer(&CpuTimer1, 200, 4000);
ConfigCpuTimer(&CpuTimer2, 200, 40000);
CpuTimer0Regs.TCR.all = 0x4000;
CpuTimer1Regs.TCR.all = 0x4000;
CpuTimer2Regs.TCR.all = 0x4000;
// Initialize serial communication
init_serial(&SerialA, 115200, serialRXA);
// Enable interrupts
IER |= M_INT1;
IER |= M_INT8;
IER |= M_INT9;
IER |= M_INT12;
IER |= M_INT13;
IER |= M_INT14;
IER |= M_INT6;
// Enable individual PIE interrupts
PieCtrlRegs.PIEIER1.bit.INTx7 = 1;
PieCtrlRegs.PIEIER12.bit.INTx9 = 1;
PieCtrlRegs.PIEIER1.bit.INTx1 = 1;
PieCtrlRegs.PIEIER6.bit.INTx3 = 1;
// Global interrupt enable
EINT;
ERTM;
// Main loop
while(1) {
if (UARTPrint == 1) {
serial_printf(&SerialA, "tilt_value: %.3f, gyro_value: %.3f, wheel vel: (%.3f, %.3f)\r\n", tilt_value, gyro_value, leftWheel, rightWheel);
UARTPrint = 0;
// Rest of the code with comments for each function
__interrupt void ADCA_ISR(void) {
GpioDataRegs.GPBSET.bit.GPIO52 = 1;
float adca2out = AdcaResultRegs.ADCRESULT0;
float adca3out = AdcaResultRegs.ADCRESULT1;
adcina2Volts = adca2out * (3.0 / 4095.0);
adcina3Volts = adca3out * (3.0 / 4095.0);
GpioDataRegs.GPCCLEAR.bit.GPIO66 = 1;
SpibRegs.SPIFFRX.bit.RXFFIL = 8;
SpibRegs.SPITXBUF = ((0x8000) | (0x3A00));
SpibRegs.SPITXBUF = 0;
AdcaRegs.ADCINTFLGCLR.bit.ADCINT1 = 1;
PieCtrlRegs.PIEACK.all = PIEACK_GROUP1;
__interrupt void SPIB_isr(void) {
SPIB_isr_count++;
GpioDataRegs.GPCSET.bit.GPIO66 = 1;
int16_t temp = SpibRegs.SPIRXBUF;
int16_t accelXraw = SpibRegs.SPIRXBUF;
int16_t accelYraw = SpibRegs.SPIRXBUF;
int16_t accelZraw = SpibRegs.SPIRXBUF;
int16_t gyroXraw = SpibRegs.SPIRXBUF;
int16_t gyroYraw = SpibRegs.SPIRXBUF;
int16_t gyroZraw = SpibRegs.SPIRXBUF;
accelXreading = accelXraw * 4.0 / 32767.0;
accelYreading = accelYraw * 4.0 / 32767.0;
accelZreading = accelZraw * 4.0 / 32767.0;
gyroXreading = gyroXraw * 250.0 / 32767.0;
gyroYreading = gyroYraw * 250.0 / 32767.0;
gyroZreading = gyroZraw * 250.0 / 32767.0;
leftWheel = -readEncLeft();
rightWheel = -readEncRight();
if (calibration_state == 0) {
calibration_count++;
if (calibration_count == 2000) {
calibration_state = 1;
} else if (calibration_state == 1) {
accelx_offset += accelXreading;
accely_offset += accelYreading;
accelz_offset += accelZreading;
gyrox_offset += gyroXreading;
gyroy_offset += gyroYreading;
gyroz_offset += gyroZreading;
calibration_state = 2;
accelx_offset /= 2000.0;
accely_offset /= 2000.0;
accelz_offset /= 2000.0;
gyrox_offset /= 2000.0;
gyroy_offset /= 2000.0;
gyroz_offset /= 2000.0;
doneCal = 1;
} else if (calibration_state == 2) {
accelXreading -= (accelx_offset);
accelYreading -= (accely_offset);
accelZreading -= (accelz_offset - accelzBalancePoint);
gyroXreading -= gyrox_offset;
gyroYreading -= gyroy_offset;
gyroZreading -= gyroz_offset;
float tiltrate = (gyroXreading * M_PI) / 180.0;
float pred_tilt, z, y, S;
pred_tilt = kalman_tilt + T * tiltrate;
pred_P = kalman_P + Q;
z = -accelZreading;
y = z - pred_tilt;
S = pred_P + R;
kalman_K = pred_P / S;
kalman_tilt = pred_tilt + kalman_K * y;
kalman_P = (1 - kalman_K) * pred_P;
SpibNumCalls++;
tilt_array[SpibNumCalls] = kalman_tilt;
gyro_array[SpibNumCalls] = tiltrate;
LeftWheelArray[SpibNumCalls] = -readEncLeft();
RightWheelArray[SpibNumCalls] = -readEncRight();
if (SpibNumCalls >= 3) {
tilt_value = (tilt_array[0] + tilt_array[1] + tilt_array[2] + tilt_array[3]) / 4.0;
gyro_value = (gyro_array[0] + gyro_array[1] + gyro_array[2] + gyro_array[3]) / 4.0;
leftWheel = (LeftWheelArray[0] + LeftWheelArray[1] + LeftWheelArray[2] + LeftWheelArray[3]) / 4.0;
rightWheel = (RightWheelArray[0] + RightWheelArray[1] + RightWheelArray[2] + RightWheelArray[3]) / 4.0;
SpibNumCalls = -1;
PieCtrlRegs.PIEIFR12.bit.INTx9 = 1;
timecount++;
if ((timecount % 200) == 0) {
if (doneCal == 0) GpioDataRegs.GPATOGGLE.bit.GPIO31 = 1;
GpioDataRegs.GPBTOGGLE.bit.GPIO34 = 1;
UARTPrint = 1;
SpibRegs.SPIFFRX.bit.RXFFOVFCLR = 1;
SpibRegs.SPIFFRX.bit.RXFFINTCLR = 1;
PieCtrlRegs.PIEACK.all = PIEACK_GROUP6;
__interrupt void SWI_isr(void) {
PieCtrlRegs.PIEACK.all = PIEACK_GROUP12;
asm(" NOP");
EINT;
leftVel = 0.6 * leftVelPrev + 100 * (leftWheel - leftWheelPrev);
rightVel = 0.6 * rightVelPrev + 100 * (rightWheel - rightWheelPrev);
ubal = -K1 * tilt_value - K2 * gyro_value - K3 * ((leftVel + rightVel) / 2.0);
wheelDiff = leftWheel - rightWheel;
wheelDiffVel = 0.333 * wheelDiffVelPrev + 166.667 * (wheelDiff - wheelDiffPrev);
turnError = turnRef - wheelDiff;
turnErrorInt = turnErrorIntPrev + 0.004 * ((turnError + turnErrorPrev) / 2);
turnRef = turnRefPrev + 0.004 * ((turnRate + turnRatePrev) / 2);
turn = Kp * turnError + Ki * turnErrorInt - Kd * wheelDiffVel;
if (fabs(turn) > 3) turnErrorInt = turnErrorIntPrev;
if (turn >= 4) turn = 4;
if (turn <= -4) turn = -4;
uLeft = (ubal / 2) + turn + FwdBackOffset;
uRight = (ubal / 2) - turn + FwdBackOffset;
if (uLeft > 10) uLeft = 10;
if (uLeft < -10) uLeft = -10;
if (uRight > 10) uRight = 10;
if (uRight < -10) uRight = -10;
setEPWM6A(uLeft);
setEPWM6B(uRight);
leftVelPrev = leftVel;
leftWheelPrev = leftWheel;
rightVelPrev = rightVel;
rightWheelPrev = rightWheel;
wheelDiffPrev = wheelDiff;
wheelDiffVelPrev = wheelDiffVel;
turnErrorIntPrev = turnErrorInt;
turnErrorPrev = turnError;
turnRefPrev = turnRef;
turnRatePrev = turnRate;
numSWIcalls++;
DINT;
float readEncLeft(void) {
int32_t raw = 0;
uint32_t QEP_maxvalue = 0xFFFFFFFFU;
raw = EQep1Regs.QPOSCNT;
if (raw >= QEP_maxvalue / 2) raw -= QEP_maxvalue;
return (raw * (-2 * M_PI / (80 * 18.7)));
float readEncRight(void) {
int32_t raw = 0;
raw = EQep2Regs.QPOSCNT;
return (raw * (2 * M_PI / (80 * 18.7)));
void setEPWM6A(float controleffort) {
controleffort = -controleffort;
if (controleffort > 10) controleffort = 10;
if (controleffort < -10) controleffort = -10;
if (controleffort >= 0) GpioDataRegs.GPACLEAR.bit.GPIO29 = 1;
else GpioDataRegs.GPASET.bit.GPIO29 = 1;
EPwm6Regs.CMPA.bit.CMPA = (fabs(controleffort) / 10.0) * EPwm6Regs.TBPRD;
void setEPWM6B(float controleffort) {
if (controleffort >= 0) GpioDataRegs.GPBSET.bit.GPIO32 = 1;
else GpioDataRegs.GPBCLEAR.bit.GPIO32 = 1;
EPwm6Regs.CMPB.bit.CMPB = (fabs(controleffort) / 10.0) * EPwm6Regs.TBPRD;
void setDACA(float dacouta0) {
if (dacouta0 > 3.0) dacouta0 = 3.0;
if (dacouta0 < 0.0) dacouta0 = 0.0;
DacaRegs.DACVALS.bit.DACVALS = (int)(dacouta0 / 3.0 * 4095);
void setDACB(float dacouta1) {
if (dacouta1 > 3.0) dacouta1 = 3.0;
if (dacouta1 < 0.0) dacouta1 = 0.0;
DacbRegs.DACVALS.bit.DACVALS = (int)(dacouta1 / 3.0 * 4095);
void serialRXA(serial_t *s, char data) {
numRXA++;
if (data == 'a') {
turnRate = turnRate - 0.2;
} else if (data == 'd') {
turnRate = turnRate + 0.2;
} else if (data == 'w') {
FwdBackOffset = FwdBackOffset - 0.2;
} else if (data == 's') {
FwdBackOffset = FwdBackOffset + 0.2;
} else {
turnRate = 0;
FwdBackOffset = 0;
// Write data to buffer
buf_write_1(&dataBuffer, data);
__interrupt void cpu_timer0_isr(void) {
CpuTimer0.InterruptCount++;
__interrupt void cpu_timer1_isr(void) {
CpuTimer1.InterruptCount++;
__interrupt void cpu_timer2_isr(void) {
CpuTimer2.InterruptCount++;
void init_eQEPs(void) {
EALLOW;
GpioCtrlRegs.GPAPUD.bit.GPIO20 = 1;
GpioCtrlRegs.GPAPUD.bit.GPIO21 = 1;
GpioCtrlRegs.GPAQSEL2.bit.GPIO20 = 2;
GpioCtrlRegs.GPAQSEL2.bit.GPIO21 = 2;
EDIS;
GPIO_SetupPinMux(20, GPIO_MUX_CPU1, 1);
GPIO_SetupPinMux(21, GPIO_MUX_CPU1, 1);
EQep1Regs.QEPCTL.bit.QPEN = 0;
EQep1Regs.QDECCTL.bit.QSRC = 0;
EQep1Regs.QPOSCTL.all = 0x0;
EQep1Regs.QCAPCTL.all = 0x0;
EQep1Regs.QEINT.all = 0x0;
EQep1Regs.QPOSMAX = 0xFFFFFFFF;
EQep1Regs.QEPCTL.bit.FREE_SOFT = 2;
EQep1Regs.QEPCTL.bit.QPEN = 1;
EQep1Regs.QPOSCNT = 0;
EALLOW;
GpioCtrlRegs.GPBPUD.bit.GPIO54 = 1;
GpioCtrlRegs.GPBPUD.bit.GPIO55 = 1;
GpioCtrlRegs.GPBQSEL2.bit.GPIO54 = 2;
GpioCtrlRegs.GPBQSEL2.bit.GPIO55 = 2;
EDIS;
GPIO_SetupPinMux(54, GPIO_MUX_CPU1, 5);
GPIO_SetupPinMux(55, GPIO_MUX_CPU1, 5);
EQep2Regs.QEPCTL.bit.QPEN = 0;
EQep2Regs.QDECCTL.bit.QSRC = 0;
EQep2Regs.QPOSCTL.all = 0x0;
EQep2Regs.QCAPCTL.all = 0x0;
EQep2Regs.QEINT.all = 0x0;
EQep2Regs.QPOSMAX = 0xFFFFFFFF;
EQep2Regs.QEPCTL.bit.FREE_SOFT = 2;
EQep2Regs.QEPCTL.bit.QPEN = 1;
EQep2Regs.QPOSCNT = 0;
void setupEPWM5(void) {
EALLOW;
EPwm5Regs.ETSEL.bit.SOCAEN = 0;
EPwm5Regs.TBCTL.bit.CTRMODE = 3;
EPwm5Regs.ETSEL.bit.SOCASEL = 2;
EPwm5Regs.ETPS.bit.SOCAPRD = 1;
EPwm5Regs.TBCTR = 0x0;
EPwm5Regs.TBPHS.bit.TBPHS = 0x0000;
EPwm5Regs.TBCTL.bit.PHSEN = 0;
EPwm5Regs.TBCTL.bit.CLKDIV = 0;
EPwm5Regs.TBPRD = 50000;
EPwm5Regs.ETSEL.bit.SOCAEN = 1;
EPwm5Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP;
EDIS;
void setupADC(void) {
EALLOW;
AdcaRegs.ADCCTL2.bit.PRESCALE = 6;
AdcbRegs.ADCCTL2.bit.PRESCALE = 6;
AdccRegs.ADCCTL2.bit.PRESCALE = 6;
AdcdRegs.ADCCTL2.bit.PRESCALE = 6;
AdcSetMode(ADC_ADCA, ADC_RESOLUTION_12BIT, ADC_SIGNALMODE_SINGLE);
AdcSetMode(ADC_ADCB, ADC_RESOLUTION_12BIT, ADC_SIGNALMODE_SINGLE);
AdcSetMode(ADC_ADCC, ADC_RESOLUTION_12BIT, ADC_SIGNALMODE_SINGLE);
AdcSetMode(ADC_ADCD, ADC_RESOLUTION_12BIT, ADC_SIGNALMODE_SINGLE);
AdcaRegs.ADCCTL1.bit.INTPULSEPOS = 1;
AdcbRegs.ADCCTL1.bit.INTPULSEPOS = 1;
AdccRegs.ADCCTL1.bit.INTPULSEPOS = 1;
AdcdRegs.ADCCTL1.bit.INTPULSEPOS = 1;
AdcaRegs.ADCCTL1.bit.ADCPWDNZ = 1;
AdcbRegs.ADCCTL1.bit.ADCPWDNZ = 1;
AdccRegs.ADCCTL1.bit.ADCPWDNZ = 1;
AdcdRegs.ADCCTL1.bit.ADCPWDNZ = 1;
DELAY_US(1000);
AdcaRegs.ADCSOC0CTL.bit.CHSEL = 0x2;
AdcaRegs.ADCSOC0CTL.bit.ACQPS = 14;
AdcaRegs.ADCSOC0CTL.bit.TRIGSEL = 0xD;
AdcaRegs.ADCSOC1CTL.bit.CHSEL = 0x3;
AdcaRegs.ADCSOC1CTL.bit.ACQPS = 14;
AdcaRegs.ADCSOC1CTL.bit.TRIGSEL = 0xD;
AdcaRegs.ADCINTSEL1N2.bit.INT1SEL = 0;
AdcaRegs.ADCINTSEL1N2.bit.INT1E = 1;
EDIS;
void setupDAC(void) {
EALLOW;
DacaRegs.DACCTL.bit.LOADMODE = 0;
DacaRegs.DACOUTEN.bit.DACOUTEN = 1;
DacaRegs.DACCTL.bit.DACREFSEL = 1;
DacbRegs.DACOUTEN.bit.DACOUTEN = 1;
DacbRegs.DACCTL.bit.LOADMODE = 0;
DacbRegs.DACCTL.bit.DACREFSEL = 1;
EDIS;
void setupSpib(void) {
// Initialiser GPIO for SPI-bruk
GPIO_SetupPinMux(2, GPIO_MUX_CPU1, 0);
GPIO_SetupPinOptions(2, GPIO_OUTPUT, GPIO_PUSHPULL);
GpioDataRegs.GPASET.bit.GPIO2 = 1;
GPIO_SetupPinMux(66, GPIO_MUX_CPU1, 0);
GPIO_SetupPinOptions(66, GPIO_OUTPUT, GPIO_PUSHPULL);
GPIO_SetupPinMux(63, GPIO_MUX_CPU1, 15);
GPIO_SetupPinMux(64, GPIO_MUX_CPU1, 15);
GPIO_SetupPinMux(65, GPIO_MUX_CPU1, 15);
EALLOW;
GpioCtrlRegs.GPBPUD.bit.GPIO63 = 0;
GpioCtrlRegs.GPCPUD.bit.GPIO64 = 0;
GpioCtrlRegs.GPCPUD.bit.GPIO65 = 0;
GpioCtrlRegs.GPBQSEL2.bit.GPIO63 = 3;
GpioCtrlRegs.GPCQSEL1.bit.GPIO64 = 3;
GpioCtrlRegs.GPCQSEL1.bit.GPIO65 = 3;
EDIS;
// Initialiser SPIB-registrene
SpibRegs.SPICCR.bit.SPISWRESET = 0;
SpibRegs.SPICTL.bit.CLK_PHASE = 1;
SpibRegs.SPICCR.bit.CLKPOLARITY = 0;
SpibRegs.SPICTL.bit.MASTER_SLAVE = 1;
SpibRegs.SPICCR.bit.SPICHAR = 0xF;
SpibRegs.SPICTL.bit.TALK = 0x1;
SpibRegs.SPIPRI.bit.FREE = 1;
SpibRegs.SPICTL.bit.SPIINTENA = 0;
SpibRegs.SPIBRR.bit.SPI_BIT_RATE = 0x32;
SpibRegs.SPISTS.all = 0x0000;
SpibRegs.SPIFFTX.bit.SPIRST = 0x1;
SpibRegs.SPIFFTX.bit.SPIFFENA = 0x1;
SpibRegs.SPIFFTX.bit.TXFIFO = 0;
SpibRegs.SPIFFTX.bit.TXFFINTCLR = 1;
SpibRegs.SPIFFRX.bit.RXFIFORESET = 0;
SpibRegs.SPIFFRX.bit.RXFFINTCLR = 0x1;
SpibRegs.SPIFFRX.bit.RXFFIENA = 0x1;
SpibRegs.SPIFFCT.bit.TXDLY = 0x00;
SpibRegs.SPICCR.bit.SPISWRESET = 0x1;
SpibRegs.SPIFFTX.bit.TXFIFO = 0x1;
SpibRegs.SPIFFRX.bit.RXFIFORESET = 1;
SpibRegs.SPICTL.bit.SPIINTENA = 1;
SpibRegs.SPIFFRX.bit.RXFFIL = 0x10;
// Initialiser SPI-kommunikasjon med slaven
SpibRegs.SPITXBUF = (0x1300 | 0x0000);
SpibRegs.SPITXBUF = (0x0000 | 0x0000);
SpibRegs.SPITXBUF = (0x0000 | 0x0013);
SpibRegs.SPITXBUF = (0x0200 | 0x0000);
SpibRegs.SPITXBUF = (0x0800 | 0x0006);
// Vent til mottaksbufferen er fylt opp
while (SpibRegs.SPIFFRX.bit.RXFFST != 7);
GpioDataRegs.GPCSET.bit.GPIO66 = 1; // Slave Select High
// Les av verdiene fra mottaksbufferen
int i;
float temp;
for (i = 0; i < 7; i++) {
// Legg til en dummy operasjon for å unngå advarsel om ubrukt variabel
temp += 0.0;
DELAY_US(10); // Delay 10us to allow time for the MPU-2950 to get ready for next transfer.
// Fortsett initialisering av MPU-9250-registere
GpioDataRegs.GPCCLEAR.bit.GPIO66 = 1; // Slave Select Low
SpibRegs.SPITXBUF = (0x2300 | 0x0000);
SpibRegs.SPITXBUF = (0x4000 | 0x008C);
SpibRegs.SPITXBUF = (0x0200 | 0x0088);
SpibRegs.SPITXBUF = (0x0C00 | 0x000A);
while (SpibRegs.SPIFFRX.bit.RXFFST != 4);
for (i = 0; i < 4; i++) {
temp += 0.0; // Dummy operation
DELAY_US(10);
// Flere MPU-registere
SpibRegs.SPITXBUF = (0x2A00 | 0x0081);
while (SpibRegs.SPIFFRX.bit.RXFFST != 1);
DELAY_US(10);
// Fortsett med flere overføringer
SpibRegs.SPITXBUF = (0x3800 | 0x0001);
DELAY_US(10);
// Fortsett med resten av initialiseringen på samme måte...
SpibRegs.SPITXBUF = (0x3A00 | 0x0001);
DELAY_US(10);
SpibRegs.SPITXBUF = (0x6400 | 0x0001);
DELAY_US(10);
SpibRegs.SPITXBUF = (0x6700 | 0x0003);
DELAY_US(10);
SpibRegs.SPITXBUF = (0x6A00 | 0x0020);
DELAY_US(10);
SpibRegs.SPITXBUF = (0x6B00 | 0x0001);
DELAY_US(10);
SpibRegs.SPITXBUF = (0x7500 | 0x0071);
DELAY_US(10);
SpibRegs.SPITXBUF = (0x7700 | 0x0000);
DELAY_US(10);
SpibRegs.SPITXBUF = (0x7800 | 0x0000);
DELAY_US(10);
SpibRegs.SPITXBUF = (0x7A00 | 0x0000);
DELAY_US(10);
SpibRegs.SPITXBUF = (0x7B00 | 0x0000);
DELAY_US(10);
SpibRegs.SPITXBUF = (0x7D00 | 0x0021);
DELAY_US(10);
SpibRegs.SPITXBUF = (0x7E00 | 0x0050);
DELAY_US(50);
// Clear SPIB interrupt source just in case it was issued due to any of the above
SpibRegs.SPIFFRX.bit.RXFFOVFCLR=1;
SpibRegs.SPIFFRX.bit.RXFFINTCLR=1;
segbot.h
#ifndef SEGBOT_H_
#define SEGBOT_H_
#include "f28379dSerial.h"
// Globale variabler
extern uint32_t numRXA;
extern uint32_t SPIB_isr_count;
extern float K1, K2, K3;
extern float Kp, Ki, Kd;
extern float adcina2Volts, adcina3Volts;
extern float T;
extern float Q;
extern float R;
extern float pred_P;
extern buffer_t dataBuffer;
extern serial_t SerialA;
extern float uLeft, uRight;
extern float accelxBalancePoint, accelyBalancePoint, accelzBalancePoint;
extern float accelx_offset, accely_offset, accelz_offset, accelXreading, accelYreading, accelZreading;
extern float gyroXreading, gyroYreading, gyroZreading, gyrox_offset, gyroy_offset, gyroz_offset;
extern float kalman_tilt, kalman_P, kalman_K;
extern float leftWheel, rightWheel, leftVel, rightVel, ubal, tilt_value, gyro_value;
extern float FwdBackOffset, turn, turnError, turnErrorInt, turnRef, turnRate, wheelDiff, wheelDiffVel;
extern float turnErrorIntPrev, turnErrorPrev, turnRefPrev, turnRatePrev, leftVelPrev, rightVelPrev, leftWheelPrev, rightWheelPrev, wheelDiffPrev, wheelDiffVelPrev;
extern uint32_t doneCal;
extern float tilt_array[4], gyro_array[4], LeftWheelArray[4], RightWheelArray[4];
// Funksjonsprototyper
void F28x_usDelay(long);
void ConfigCpuTimer(struct CPUTIMER_VARS *, float, float);
void InitCpuTimers(void);
void InitGpio(void);
void InitSysCtrl(void);
uint16_t init_serial(serial_t *, Uint32, void (*)(serial_t *, char));
void GPIO_SetupPinMux(Uint16, Uint16, Uint16);
void GPIO_SetupPinOptions(Uint16, Uint16, Uint16);
void AdcSetMode(Uint16, Uint16, Uint16);
uint16_t serial_printf(serial_t *, char *, ...);
void setupSpib(void);
void init_eQEPs(void);
void setupEPWM5(void);
void setupADC(void);
void setupDAC(void);
void serialRXA(serial_t *s, char data);
float readEncLeft(void);
float readEncRight(void);
void setEPWM6A(float controleffort);
void setEPWM6B(float controleffort);
void setDACA(float dacouta0);
void setDACB(float dacouta1);
#endif /* SEGBOT_H_ */
buffer.h
* buffer.h
* Created on: 5. jul. 2024
* Author: obsfe
#ifndef __BUFFER_H__
#define __BUFFER_H__
#define BUF_SIZE (4*1000 + 8)
typedef volatile struct buffer_s {
volatile char buf[BUF_SIZE];
volatile Uint16 head, tail, size;
} buffer_t;
extern inline void init_buffer(buffer_t *b)
b->size = b->head = b->tail = 0;
#define buf_clear(b) init_buffer(b)
#ifdef _FLASH
#pragma CODE_SECTION(buf_write_1, ".TI.ramfunc");
#endif
extern inline uint16_t buf_write_1(buffer_t *b, char data)
if (b->size == BUF_SIZE) return 2;
b->buf[b->head] = data;
b->head = (b->head+1)%BUF_SIZE;
b->size++;
return 0;
#ifdef _FLASH
#pragma CODE_SECTION(buf_read_1, ".TI.ramfunc");
#endif
extern inline uint16_t buf_read_1(buffer_t *b, Uint16 offset, char *data)
if (b->size == 0 || b->size < offset) return 3;
*data = b->buf[ (b->tail+offset)%BUF_SIZE ];
return 0;
#ifdef _FLASH
#pragma CODE_SECTION(buf_remove, ".TI.ramfunc");
#endif
extern inline uint16_t buf_remove(buffer_t *b, Uint16 len)
len = (len > b->size) ? b->size : len;
b->tail = (b->tail+len)%BUF_SIZE;
b->size -= len;
return len;
#endif /* __BUFFER_H__ */
  • the code is from segbo/github:
    // TITLE: Segbot
    // Included Files
    #include "segbot.h"
    #include "device.h"
    #include "segbot.h"
    #include <stdint.h>
    #include <math.h>
    #include "buffer.h"
    // Global variables
    float turn = 0.0;
    float ubal = 0.0;
    void main(void) {
    DINT;
    InitSysCtrl();
    InitGpio();
    EINT;
    // GPIO setup
    // Setup LEDs
    // LED1 and PWM Pin
    // LED2
    setupSpib();
    init_eQEPs();
    setupEPWM5();
    setupADC();
    setupDAC();
    InitCpuTimers();
    IER |= M_INT1;
    IER |= M_INT8;
    IER |= M_INT9;
    IER |= M_INT12;
    IER |= M_INT13;
    IER |= M_INT14;
    IER |= M_INT6;
    EINT;
    ERTM;
    // Main loop
    while(1) {
    UARTPrint = 0;
    SPIB_isr_count++;
    doneCal = 1;
    z = -accelZreading;
    y = z - pred_tilt;
    S = pred_P + R;
    SpibNumCalls++;
    SpibNumCalls = -1;
    timecount++;
    UARTPrint = 1;
    asm(" NOP");
    EINT;
    setEPWM6A(uLeft);
    setEPWM6B(uRight);
    numSWIcalls++;
    DINT;
    int32_t raw = 0;
    int32_t raw = 0;
    numRXA++;
    if (data == 'a') {
    } else {
    turnRate = 0;
    FwdBackOffset = 0;
    EALLOW;
    EDIS;
    EALLOW;
    EDIS;
    EALLOW;
    EDIS;
    EALLOW;
    DELAY_US(1000);
    EDIS;
    EALLOW;
    EDIS;
    EALLOW;
    EDIS;
    int i;
    float temp;
    temp += 0.0;
    DELAY_US(10);
    DELAY_US(10);
    DELAY_US(10);
    DELAY_US(10);
    DELAY_US(10);
    DELAY_US(10);
    DELAY_US(10);
    DELAY_US(10);
    DELAY_US(10);
    DELAY_US(10);
    DELAY_US(10);
    DELAY_US(10);
    DELAY_US(10);
    DELAY_US(10);
    DELAY_US(50);
    A couple of notes. First, when posting code excerpts this long, try and attach them as documents to allow us to view them and your post more easily. Second, what is happening? You don't state what the issue is.
    Jason Osborn
  • sorry im confused i just need more experience
