Concerto Startup Error
Other Parts Discussed in Thread: TMS320F28335
Have you seen this error?
C28xx: Flash Programmer: Warning: The configured device (TMS320F28335), does not match the detected device (). Flash Programming operations could be affected. Please consider modifying your target configuration file.
C28xx: GEL Output:
ADC Calibration not complete, check if device is unlocked and recalibrate.C28xx: GEL Output:
ADC Calibration not complete, check if device is unlocked and recalibrate.C28xx: Flash Programmer: Error erasing flash memory. Device is locked or not connected. Operation cancelled
C28xx: Flash Programmer: Error erasing Flash memory.
C28xx: Flash Programmer: Device is locked or not connected. Operation cancelled.
C28xx: Trouble Writing Memory Block at 0x33fff6 on Page 0 of Length 0x2
Cannot write to target
I just started getting this issue all of a sudden.
    It looks like the target configuration is set for a 2833x device instead of an F28M35x.  This wiki page describes how to see the target configuration.  Make sure the device selected is 28M35x
    http://processors.wiki.ti.com/index.php/C2000_Getting_Started_with_Code_Composer_Studio_v4#Set_up_the_Target_Configuration_Options_for_Device_Emulation
    -Lori
