Part Number: TMS320F280037-Q1
Is there an excel tool available with the mentioned device pin out map?
I do not believe there is an excel tool for the datasheet device pin map, but will double check on this for you and update in the next day.
Allison
Hi Mouhcine,
What you could do is utilize our SysConfig GUI to view this information. If you haven't used SysConfig before, here would be the steps:
Let me know if this is helpful at all!
Allison
Hi Allison,
Thank you for your replay.
Yes, we are using the SysConfig GUI, but what I meant an Excel list template like in the picture.
Thank you and best regards,
Mouhcine
Hi Mouhcine,
Ah I see. Are you needing this for customer use? or internal?
Allison
Hi Allison,
I need it for an internal OBC DCDC project.
Thank you.
Mouhcine
Hi Mouhcine,
I checked and we do not have another tool for this. That csv file is the most parsable file we have for this information, so you can likely use it to generate what you want. You can also use the pinmux json that the pinmux tool uses to generate the pin diagram.
Allison
Hello Allison,
Ok, I will try it.
Thank you for your support.
Mouhcine
Sounds good, Mouhcine.
I will go ahead and close this thread, but feel free to open a new one should you run into issues.
Allison
