Part Number: C2000WARE
This warnings are showing in CCS . I've add generated CLA code from matlat to CCS.
Hi Aishwarya,
Did you use a C2000ware example as a starting point for your code? If not, I would recommend taking this approach. Also, did you change the linker cmd file in any way?
It looks like CCS is having trouble locating some source files, can you verify that the include paths in your project are all correct?
Delaney
