Part Number: TMS320F2800137
Hi champs,
I am asking this for our customer.
The user uses bit-field codes by referring to our bit-field examples, but the user is confused about the ADC calibration address by default because their ADC results look bad.
After debugging, we found,
In bit-field codes,
C:\ti\c2000\C2000Ware_5_02_00_00\device_support\f280013x\common\source\f280013x_adc.c
In driverlib codes,
C:\ti\c2000\C2000Ware_5_02_00_00\driverlib\f280013x\driverlib\adc.c
They appear different.
Besides, TI OTP should start with 0x71000 from below Table 7-1 in the datasheet, so we are confused about the addresses used in bit-field codes.
Questions:
Would you please help clarify the above default calibration addresses in bit-field and in driverlib?
Which of them is correct or both are incorrect?
