TMS320F280049C: Some variables can not assign value through CAN
Part Number: TMS320F280049C
Dear expert,
My customer is developing bootloader. He program .out file through emulator. And then he run it, he want to modify some variables through CAN communication. But he find the right red box area could be assigned, the left red box area could not be assigned. I also attach the cmd file. Please help to check this issue, thank you.
通信变量无法赋值.docx
  • Hi Angela,
    Can you please confirm from customer if this is using the CAN bootloader kernel?  Also can you please translate the attachment?
    Joseph
  • Hi Joseph,
    You can ignore the bootloader, he just program .out file through emulator and use CAN communication tool to modify some variables. The attachment name is not important, the content of attachment is the cmd file.
  • Hi Angela,
    So if I am understanding the problem correctly, the basic issue is that CAN is not sending correct data?  Can you please give more details to understand the issue better?
              - What is the setup used (launch pad, control card, custom board??)
              - What is the baud rate
              - Are other variables updated  through CAN?
              - Can you ask customer to look at the error registers like CAN_ES when the problem happens?
    Joseph
