Part Number: TMS320F28388D
Greetings,
I must have changed a configuration in CCS because it always launches the debug session when the build completes. What did I change to make this happen?
Thank you,
Ed
Greetings,
Thank you,
Ed
Hi Ed,
Could you check your debug configuration under Run> Debug Configurations?
I am not familiar with a setting that does exactly this, but some of these settings could do something that looks like this.
Ben Collier
Hi Ben,
I checked the settings you suggested, and they are simply the default settings. So I deleted my workspace and all the intermediate files, started CCS again, and built everything. It has returned to prompting me for loads. And the Auto Run and Launch Options did not change between the old and the new. So unfortunately, it will remain a mystery for now.
Sorry,
Ed
Hi Ben,
I just realized that there is a check box in the dialog box which asks if I want to load the file. I must have inadvertently checked it. Once that has happened, is there a way to effectively "uncheck" it?
Thank you,
Ed
I believe you are looking for the below workspace option:
