TMS320F2800137: "Texas Instruments XDS110 USB Debug Probe_0/C28xx_CPU1 : Target must be connected before loading program."
Part Number: TMS320F2800137
Other Parts Discussed in Thread: UNIFLASH, TEST2
I have a problem.
I copied the correct project from CCS.
I did not modify anything in the copied project, and the compilation is completed, but when I start debugging, the following error occurs.
The original project has no problem.
Why does this happen?
There is no problem in the copied ccxml, Test Connect is completed normally, and the out file generated from the copied project is written normally to UniFlash.
It's just that the CCS debugging connection does not work.
Thank you.
