TMS320F28388D: power management issue
Part Number: TMS320F28388D
Other Parts Discussed in Thread: C2000WARE, TMDSCNCD28388D
About TMS320F28388D power management,I have some questions.
1.How to understand the requirement of power supply voltage slope?
2、How to understand the seventh point below?
  • Hello Chu,
    The expert on this topic is currently out of office until Tuesday 9/3, so please expect a delayed response. Thank you for your flexibility.
    Aishwarya
  • Chu,
    I'm not sure how to further explain this, the data sheet shows our minimum and maximum slope for voltage supplies when powering on the MCU.
    This also seems straight forward. There needs to be a 56 Ohm resistor between VDD (1.2V) and VSS. If you check the schematic for F28388D controlcard, which can be found at [C2000WARE]/board/controlCARDs/TMDSCNCD28388D/ , then you will see this resistor.
    Ben Collier
