Hello everyone,
I am running a tcp server using the enet_lwip example provided for the F28388D board. I am using a sample application code for TCP Server, this code is tcpechoserver. This code works fine, it reflects the incoming data back in the same way, but in the application I am going to use, the server and client devices are of different sizes to send data independently without waiting for each other. I tried something by changing the tcpechoserver code so that the client and server send data without waiting for each other, but after a while, either F28388D Fault ISR drops or I get TCP ZERO Windowns error on the server or client side while monitoring from Wireshark. Can you give me sample code that you are sure works on your side.
/** * Copyright (c) 2001-2004 Swedish Institute of Computer Science. * All rights reserved. * * Redistribution and use in source and binary forms, with or without modification, * are permitted provided that the following conditions are met: * * 1. Redistributions of source code must retain the above copyright notice, * this list of conditions and the following disclaimer. * 2. Redistributions in binary form must reproduce the above copyright notice, * this list of conditions and the following disclaimer in the documentation * and/or other materials provided with the distribution. * 3. The name of the author may not be used to endorse or promote products * derived from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY * OF SUCH DAMAGE. * * This file is part of and a contribution to the lwIP TCP/IP stack. * * Credits go to Adam Dunkels (and the current maintainers) of this software. * * Christiaan Simons rewrote this file to get a more stable echo application. * **/ /* This file was modified by ST */ #include "lwip/debug.h" #include "lwip/stats.h" #include "lwip/tcp.h" #if LWIP_TCP static struct tcp_pcb *tcp_echoserver_pcb; /* ECHO protocol states */ enum tcp_echoserver_states { ES_NONE = 0, ES_ACCEPTED, ES_RECEIVED, ES_CLOSING }; /* structure for maintaing connection infos to be passed as argument to LwIP callbacks*/ struct tcp_echoserver_struct { u8_t state; /* current connection state */ u8_t retries; struct tcp_pcb *pcb; /* pointer on the current tcp_pcb */ struct pbuf *p; /* pointer on the received/to be transmitted pbuf */ }; static err_t tcp_echoserver_accept(void *arg, struct tcp_pcb *newpcb, err_t err); static err_t tcp_echoserver_recv(void *arg, struct tcp_pcb *tpcb, struct pbuf *p, err_t err); static void tcp_echoserver_error(void *arg, err_t err); static err_t tcp_echoserver_poll(void *arg, struct tcp_pcb *tpcb); static err_t tcp_echoserver_sent(void *arg, struct tcp_pcb *tpcb, u16_t len); static void tcp_echoserver_send(struct tcp_pcb *tpcb, struct tcp_echoserver_struct *es); static void tcp_echoserver_connection_close(struct tcp_pcb *tpcb, struct tcp_echoserver_struct *es); /** * @brief Initializes the tcp echo server * @param None * @retval None */ void tcp_echoserver_init(void) { /* create new tcp pcb */ tcp_echoserver_pcb = tcp_new(); if (tcp_echoserver_pcb != NULL) { err_t err; /* bind echo_pcb to port 7 (ECHO protocol) */ err = tcp_bind(tcp_echoserver_pcb, IP_ADDR_ANY, 7); if (err == ERR_OK) { /* start tcp listening for echo_pcb */ tcp_echoserver_pcb = tcp_listen(tcp_echoserver_pcb); /* initialize LwIP tcp_accept callback function */ tcp_accept(tcp_echoserver_pcb, tcp_echoserver_accept); } else { /* deallocate the pcb */ memp_free(MEMP_TCP_PCB, tcp_echoserver_pcb); } } } /** * @brief This function is the implementation of tcp_accept LwIP callback * @param arg: not used * @param newpcb: pointer on tcp_pcb struct for the newly created tcp connection * @param err: not used * @retval err_t: error status */ static err_t tcp_echoserver_accept(void *arg, struct tcp_pcb *newpcb, err_t err) { err_t ret_err; struct tcp_echoserver_struct *es; LWIP_UNUSED_ARG(arg); LWIP_UNUSED_ARG(err); /* set priority for the newly accepted tcp connection newpcb */ tcp_setprio(newpcb, TCP_PRIO_MIN); /* allocate structure es to maintain tcp connection informations */ es = (struct tcp_echoserver_struct *)mem_malloc(sizeof(struct tcp_echoserver_struct)); if (es != NULL) { es->state = ES_ACCEPTED; es->pcb = newpcb; es->retries = 0; es->p = NULL; /* pass newly allocated es structure as argument to newpcb */ tcp_arg(newpcb, es); /* initialize lwip tcp_recv callback function for newpcb */ tcp_recv(newpcb, tcp_echoserver_recv); /* initialize lwip tcp_err callback function for newpcb */ tcp_err(newpcb, tcp_echoserver_error); /* initialize lwip tcp_poll callback function for newpcb */ tcp_poll(newpcb, tcp_echoserver_poll, 0); ret_err = ERR_OK; } else { /* close tcp connection */ tcp_echoserver_connection_close(newpcb, es); /* return memory error */ ret_err = ERR_MEM; } return ret_err; } /** * @brief This function is the implementation for tcp_recv LwIP callback * @param arg: pointer on a argument for the tcp_pcb connection * @param tpcb: pointer on the tcp_pcb connection * @param pbuf: pointer on the received pbuf * @param err: error information regarding the reveived pbuf * @retval err_t: error code */ static err_t tcp_echoserver_recv(void *arg, struct tcp_pcb *tpcb, struct pbuf *p, err_t err) { struct tcp_echoserver_struct *es; err_t ret_err; LWIP_ASSERT("arg != NULL",arg != NULL); es = (struct tcp_echoserver_struct *)arg; /* if we receive an empty tcp frame from client => close connection */ if (p == NULL) { /* remote host closed connection */ es->state = ES_CLOSING; if(es->p == NULL) { /* we're done sending, close connection */ tcp_echoserver_connection_close(tpcb, es); } else { /* we're not done yet */ /* acknowledge received packet */ tcp_sent(tpcb, tcp_echoserver_sent); /* send remaining data*/ tcp_echoserver_send(tpcb, es); } ret_err = ERR_OK; } /* else : a non empty frame was received from client but for some reason err != ERR_OK */ else if(err != ERR_OK) { /* free received pbuf*/ if (p != NULL) { es->p = NULL; pbuf_free(p); } ret_err = err; } else if(es->state == ES_ACCEPTED) { /* first data chunk in p->payload */ es->state = ES_RECEIVED; /* store reference to incoming pbuf (chain) */ es->p = p; /* initialize LwIP tcp_sent callback function */ tcp_sent(tpcb, tcp_echoserver_sent); /* send back the received data (echo) */ es->p->payload = "STM32F407\r\n"; tcp_echoserver_send(tpcb, es); ret_err = ERR_OK; } else if (es->state == ES_RECEIVED) { /* more data received from client and previous data has been already sent*/ if(es->p == NULL) { es->p = p; /* send back received data */ es->p->payload = "STM32F407\r\n"; tcp_echoserver_send(tpcb, es); } else { struct pbuf *ptr; /* chain pbufs to the end of what we recv'ed previously */ ptr = es->p; pbuf_chain(ptr,p); } ret_err = ERR_OK; } else if(es->state == ES_CLOSING) { /* odd case, remote side closing twice, trash data */ tcp_recved(tpcb, p->tot_len); es->p = NULL; pbuf_free(p); ret_err = ERR_OK; } else { /* unkown es->state, trash data */ tcp_recved(tpcb, p->tot_len); es->p = NULL; pbuf_free(p); ret_err = ERR_OK; } return ret_err; } /** * @brief This function implements the tcp_err callback function (called * when a fatal tcp_connection error occurs. * @param arg: pointer on argument parameter * @param err: not used * @retval None */ static void tcp_echoserver_error(void *arg, err_t err) { struct tcp_echoserver_struct *es; LWIP_UNUSED_ARG(err); es = (struct tcp_echoserver_struct *)arg; if (es != NULL) { /* free es structure */ mem_free(es); } } /** * @brief This function implements the tcp_poll LwIP callback function * @param arg: pointer on argument passed to callback * @param tpcb: pointer on the tcp_pcb for the current tcp connection * @retval err_t: error code */ static err_t tcp_echoserver_poll(void *arg, struct tcp_pcb *tpcb) { err_t ret_err; struct tcp_echoserver_struct *es; es = (struct tcp_echoserver_struct *)arg; if (es != NULL) { if (es->p != NULL) { tcp_sent(tpcb, tcp_echoserver_sent); /* there is a remaining pbuf (chain) , try to send data */ tcp_echoserver_send(tpcb, es); } else { /* no remaining pbuf (chain) */ if(es->state == ES_CLOSING) { /* close tcp connection */ tcp_echoserver_connection_close(tpcb, es); } } ret_err = ERR_OK; } else { /* nothing to be done */ tcp_abort(tpcb); ret_err = ERR_ABRT; } return ret_err; } /** * @brief This function implements the tcp_sent LwIP callback (called when ACK * is received from remote host for sent data) * @param None * @retval None */ static err_t tcp_echoserver_sent(void *arg, struct tcp_pcb *tpcb, u16_t len) { struct tcp_echoserver_struct *es; LWIP_UNUSED_ARG(len); es = (struct tcp_echoserver_struct *)arg; es->retries = 0; if(es->p != NULL) { /* still got pbufs to send */ tcp_sent(tpcb, tcp_echoserver_sent); tcp_echoserver_send(tpcb, es); } else { /* if no more data to send and client closed connection*/ if(es->state == ES_CLOSING) tcp_echoserver_connection_close(tpcb, es); } return ERR_OK; } /** * @brief This function is used to send data for tcp connection * @param tpcb: pointer on the tcp_pcb connection * @param es: pointer on echo_state structure * @retval None */ static void tcp_echoserver_send(struct tcp_pcb *tpcb, struct tcp_echoserver_struct *es) { struct pbuf *ptr; err_t wr_err = ERR_OK; while ((wr_err == ERR_OK) && (es->p != NULL) && (es->p->len <= tcp_sndbuf(tpcb))) { /* get pointer on pbuf from es structure */ ptr = es->p; /* enqueue data for transmission */ wr_err = tcp_write(tpcb, ptr->payload, ptr->len, 1); if (wr_err == ERR_OK) { u16_t plen; u8_t freed; plen = ptr->len; /* continue with next pbuf in chain (if any) */ es->p = ptr->next; if(es->p != NULL) { /* increment reference count for es->p */ pbuf_ref(es->p); } /* chop first pbuf from chain */ do { /* try hard to free pbuf */ freed = pbuf_free(ptr); } while(freed == 0); /* we can read more data now */ tcp_recved(tpcb, plen); } else if(wr_err == ERR_MEM) { /* we are low on memory, try later / harder, defer to poll */ es->p = ptr; } else { /* other problem ?? */ } } } /** * @brief This functions closes the tcp connection * @param tcp_pcb: pointer on the tcp connection * @param es: pointer on echo_state structure * @retval None */ static void tcp_echoserver_connection_close(struct tcp_pcb *tpcb, struct tcp_echoserver_struct *es) { /* remove all callbacks */ tcp_arg(tpcb, NULL); tcp_sent(tpcb, NULL); tcp_recv(tpcb, NULL); tcp_err(tpcb, NULL); tcp_poll(tpcb, NULL, 0); /* delete es structure */ if (es != NULL) { mem_free(es); } /* close tcp connection */ tcp_close(tpcb); } #endif /* LWIP_TCP */
