concerto -- debugging dual projects
Hi All
I got Concerto examples for the m3 and dsp up and running.  Having problems getting the dual mode operation projects up and running.
Could use some advise in following areas.
1.  Is it possible to debug a dsp program and m3 program at same time.  If true, how?  ie two code composer instances ?? or from inside a single project.
2.  The Dual mode projects do not run for me.  Could use some advise on how to run these projects successfull.  As mentioned above I have successfully run the m3 and dsp programs in single mode.
