TMS320F280049C: ADCDACLOOPBACK - Analog Subsystem Registers
Part Number: TMS320F280049C
Is the register ADCDACLOOPBACK available and writable in TMS320F28004x family uCs?
There is a discrepancy between documentation
TMS320F28004x - Techical Reference Manual (SPRUI33G)
and source files:
hw_asysctl.h
f28004x_analog_subsys_regs.xml
I cannot set the bits 2..0 from register ADCDACLOOPBACK using the KEY provided in the documentation: 0xA5A5
  • Hi Adrian,
    Can you do a quick experiment?  In memory browser, set pull down menu to "Data" and put address to 0x5D788.  Display as 32-bit Hex TI Style.  Go to memory location and overwrite the 32 bit data by double-clicking the 00000000 and overwrite 0xA5A50007 then hit return.  See if the location is written to.
    Joseph
  • Hi Joseph,
    Yes, it's working. The only remaining topic is the documentation, the address (offset) for ADCDACLOOPBACK is not defined for TMS320F28004x.
