Part Number: TMS320F280041C
Dear TI experts,
I often encountered an issue with my CCS project. My projects are located in a folder "D:\OneDrive\TIWorkSpace". I use Microsoft Onedirve to synchronize this folder on different PCs.
When I build a project, it often gives an error "This project does not contain a buildable RTSC Configuration (.cfg) file. In order for it to build, this project must contain one RTSC Configuration file that is not excluded from build.". I check the property of this project, it can be found that the "Output type" is changed to "RTSC Application (Executable)", which is non-editable. For normal project, it should be "Executable".
I have to recreate this project, which costs some time.
I believe it is the Onedrive synchronization cause this issue, since such issue would disapprea if I close the Onedrive. Besides, the CCS often gives a Problem Occurred dialogue saying: "Periodic workspace save." have encountered a problem. Could not write metadata for '/RemoteSystemsTempFiles'.
Such issue is so annoying, could you please advise how to address it?
Jiaxing Lei
