Part Number: TMS320F28379D
DSLite from UniFlash 8.8.1 does not support FlashEraseSelection setting as previous version (from 8.2.0) did.
log from DSLite running:
Executing: /home/pi/uniflash_linux/ccs_base/DebugServer/bin/DSLite flash -c /home/pi/uniflash/f28379d.ccxml -l /home/pi/uniflash/generated.ufsettings -s VerifyAfterProgramLoad="No verification" -e -f -v "/mnt/programator/Bootloader_cpu01-part2.hex"
DSLite version 12.8.0.3522
Configuring Debugger (may take a few minutes on first launch)...
Initializing Register Database...
Initializing: IcePick_C_0
Executing Startup Scripts: IcePick_C_0
Initializing: C28xx_CPU1
Executing Startup Scripts: C28xx_CPU1
Initializing: CPU1_CLA1
Executing Startup Scripts: CPU1_CLA1
Initializing: C28xx_CPU2
Executing Startup Scripts: C28xx_CPU2
Initializing: CPU2_CLA1
Executing Startup Scripts: CPU2_CLA1
Connecting...
C28xx_CPU1: GEL Output:
Memory Map Initialization Complete
GEL Expression: OnTargetConnect()
info: C28xx_CPU1: If erase/program (E/P) operation is being done on one core, the other core should not execute from shared-RAM (SR) as they are used for the E/P code. Also, CPU1 will be halted to determine SR ownership for the CPU which will run the Flash Plugin code, after which CPU1 will be set to run its application. User code execution from SR could commence after both flash banks are programmed.
Failed: Unknown Property: FlashEraseSelection
generated.settings file:
{"Texas Instruments XDS110 USB Debug Probe/C28xx_CPU1":{"FlashEraseSelection":"Necessary Sectors Only (for Program Load)"},"Texas Instruments XDS110 USB Debug Probe/C28xx_CPU2":{"FlashEraseSelection":"Necessary Sectors Only (for Program Load)"}}
f28379d.ccxml:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<configurations XML_version="1.2" id="configurations_0">
<configuration XML_version="1.2" id="Texas Instruments XDS110 USB Debug Probe_0">
<instance XML_version="1.2" desc="Texas Instruments XDS110 USB Debug Probe_0" href="connections/TIXDS110_Connection.xml" id="Texas Instruments XDS110 USB Debug Probe_0" xml="TIXDS110_Connection.xml" xmlpath="connections"/>
<connection XML_version="1.2" id="Texas Instruments XDS110 USB Debug Probe_0">
<instance XML_version="1.2" href="drivers/tixds510icepick_c.xml" id="drivers" xml="tixds510icepick_c.xml" xmlpath="drivers"/>
<instance XML_version="1.2" href="drivers/tixds510c28x.xml" id="drivers" xml="tixds510c28x.xml" xmlpath="drivers"/>
<instance XML_version="1.2" href="drivers/tixds510cla1.xml" id="drivers" xml="tixds510cla1.xml" xmlpath="drivers"/>
<instance XML_version="1.2" href="drivers/tixds510cs_child.xml" id="drivers" xml="tixds510cs_child.xml" xmlpath="drivers"/>
<property Type="choicelist" Value="1" id="Power Selection">
<choice Name="Probe supplied power" value="1">
<property Type="stringfield" Value="3.3V" id="Voltage Level"/>
<property Type="choicelist" Value="1" id="Power Isolation"/>
</choice>
</property>
<property Type="choicelist" Value="1" id="The JTAG TCLK Frequency (MHz)">
<choice Name="Fixed with user specified value" value="SPECIFIC">
<property Type="stringfield" Value="3.0MHz" id="-- Enter a value from 100.0kHz to 2.5MHz"/>
</choice>
</property>
<platform XML_version="1.2" id="platform_0">
<instance XML_version="1.2" desc="TMS320F28379D_0" href="devices/f28379d.xml" id="TMS320F28379D_0" xml="f28379d.xml" xmlpath="devices"/>
<device HW_revision="1" XML_version="1.2" description="" id="TMS320F28379D_0" partnum="TMS320F28379D" simulation="no">
<router HW_revision="1.0" XML_version="1.2" description="ICEPick_C router" id="IcePick_C_0" isa="ICEPICK_C">
<subpath id="Subpath_1">
<property Type="numericfield" Value="0x11" desc="Port Number_0" id="Port Number"/>
</subpath>
</router>
</device>
</platform>
</connection>
</configuration>
</configurations>
It is very critical, because it does not allow programming memories in parts (flash, otp) because it erases all sectors.
I installed uniflash 8.8.1 on linux (ubuntu 24.04).
I selected the options and jtag emulator type and generated package with command line tools.
Unfortunately DSLite is not working properly.
Piotr Romaniuk
