TMS320F2800156-Q1: CAN commutaion
Part Number: TMS320F2800156-Q1
hi expert
i see in the datasheet as follows:
Messages can be updated or set to "not valid" at any time, even if a requested transmission is still pending. However, the data bytes are discarded if a message is updated before a pending transmission has started
how to discard the pending message?
can you give a methord?
  • Hi Youjun,
    Typically, the message ready/new data flag gets active when CPU detects an updated data, ID or mask value in the message object.  Not sure if user can set a message to be discarded or tag as not valid.  There is bit in the arbitration register CAN_IFxARB called MsgVal.  You can manually clear this to 0 so the mailbox will be disabled.  I think it will have the same effect as discardin the message.
    Joseph
