TMS320F28377D: How to use SFRA to identify the dual control loop parameter
Part Number: TMS320F28377D
Other Parts Discussed in Thread: SFRA, C2000WARE
Hi team
Customer want to use SFRA to design the power electronic control loop, inner loop is current loop and out loop is voltage. How to use SFRA to identify the dual control loop parameter.
Joe
  • Hi team
    Could you please kindly update this thread.
    Joe
  • Joe,
    At present, SFRA library can be used for a single loop analysis.
    SFRA_F32_INJECT and SFRA_F32_COLLECT functions helps in providing small signal frequency injection in addition to reference and collecting the output parameters based on open loop/closed loop selection in SFRA_F32_config function.
    More information is available on how to use in documentation (C2000Ware_DigitalPower_SDK_xxx\libraries\sfra\docs) and www.ti.com/lit/ug/spruik4a/spruik4a.pdf?ts=1717387316590
    Can you provide block diagram of dual loop, that would help to answer!
    Thanks and Regards,
    Shashank
