InstaSPIN-BLDC
Other Parts Discussed in Thread: CONTROLSUITE, INSTASPIN-BLDC, DRV8301, TMS320F28035, DRV8312, DRV8302
Refer to InstaSPIN_2D00_BLDC-Sensorless-Control.pdf in C:\TI\controlSUITE\development_kits\DRV830x-HC-C2-KIT_v100\BLDC_Int\~Doc ,  it's talking about config,set up and testing of BLDC_Int only. There is no details of InstaSPIN-BLDC module.
So, How to get source code or document explain of "InstaSPIN-BLDC" module ?  Thank you.
  • Dear Chris,
    But when I imported the example (InstaSPIN_BLDC) for DRV8302-HC-C2-Kit F28035 -I did not find the source code for InstaSPIN_BLDC integration technique.
    I just found the definition for InstaSPIN BLDC struct.
    C:\ti\controlSUITE\libs\app_libs\motor_control\libs\InstaSPIN-BLDC\v100\include
    and also there is no document to explain this module.
    Khaled
  • correct, the software source is not available and the documentation for the module is lacking.
    the technique itself is discussed here, especially in the videos.
    www.ti.com/instaspin-bldc
  • Thank you for your soon replying
    1-Will it be released public or not?
    2-I have another question:
    I used the (Example_2803xSci_Echoback.c) from controlSUITE, it worked well as transmission and the following appears in the hyperterminal:
    Hello World!
    You will enter a character, and the DSP will echo it back!
    Enter a character:
    When I enter a character, nothing happens and it seems that SCIRXBUF does not receive any character.
    When I used the CCS5 debugger with breakpoint, the program stuck at the following line:
     while(SciaRegs.SCIFFRX.bit.RXFFST !=1){}; // wait for XRDY =1 for empty state
    It seems that nothing received by RX FIFO.
    I imported the same exactly Example_2803xSci_Echoback example with the same configurations of GPIO.
    What is wrong? please help..
    Khaled
  • 1 - no, source code will not be given, just the library. yes, we should document the interface better, no timeline.
    2 - I recommend starting a new post so someone with that expertise can attemp to answer
