TMS320F28P650SH: CMPSS CBC goes wrong
Part Number: TMS320F28P650SH
Hi  ,
    I encountered a problem when I used the CMPSS CBC to achieve the peak mode control buck.
    The PWM will be high at the start of the cycle and the current of inductance will rise, and the CMPSS will compare the ADC of current of inductance and the DAC value to produce a signal to shut down the PWM. In this way, I can  control the buck convertor.
    You can see the picture below:
CH1: ADC of current of inductance
CH3: Output Xbar of CMPSS CTRIPOUTL(CMPSS output)
CH4:DAC value(by DACA module)(Used to see the changing trend)
      You can see the current go up at the start of the cycle, and go down when the current equal to the DAC value。
     But see the  red box circled part,  the ouput Xbar sustained high when the current goes down(the DAC value didn't changed), and the current didn't goes up when the next cycle comes.
     Ask the TI's engineers what will cause the above problems, thanks
    Thanks for your patience.
    From this image it is obvious there are noise in the signals.
    Can you try to use the digital filter inside CMPSS module to remove the noise ? there is an example inside your C2000ware directory for configuring the digital filter.
    Hadi
  • Hi Hadi,
           According to my recent use of CMPSS,  I found two problems with CMPSS:
          1. the first one is my question below,  I used the CMPSS ramp delay function,if the current sample matched the comparison value just at he moment when RAMP DELAY = 0, the comparator will assert until the next period start, and the EPWM TZ CBC will be latch in the next period. That's why the epwm output is low in the next period
         2. I found in the test that the RAMP DELAY's clock is systick instead of RAMPxCLK
