Part Number: TMS320F280039C
I don't use example and debug
This isn't an error. Please try selecting 'Confirm' and verify that you are able to open the file in Sysconfig.
Delaney
When I try to debug
it shows the following error:
.Texas Instruments XDS110 USB Debug Probe_0/IcePick_C_0 Error initializing emulator: (Error -260 @ 0x0) An attempt to connect to the XDS110 failed. The cause may be one or more of: no XDS110 is connected, invalid firmware update, invalid XDS110 serial number, or faulty USB cable. The firmware and serial number may be updated using the xdsdfu utility found in the .../ccs_base/common/uscif/xds110 directory of your installation. View the...
Hi Hieu,
I will loop in a CCS expert to help with this.
Delaney
I apologize for the delay, but please check out this app note: https://www.ti.com/lit/pdf/spracf0
Ben Collier
