Part Number: TMS320F280039C
;* BOOT v6.4.11
;* Copyright (c) 2000-2016 Texas Instruments Incorporated
;* http://www.ti.com/
;* Redistribution and use in source and binary forms, with or without
;* modification, are permitted provided that the following conditions
;* are met:
;* Redistributions of source code must retain the above copyright
;* notice, this list of conditions and the following disclaimer.
;* Redistributions in binary form must reproduce the above copyright
;* notice, this list of conditions and the following disclaimer in
;* the documentation and/or other materials provided with the
;* distribution.
;* Neither the name of Texas Instruments Incorporated nor the names
;* of its contributors may be used to endorse or promote products
;* derived from this software without specific prior written
;* permission.
;* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
;* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
;* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
;* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
;* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
;* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
;* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
;* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
;* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
;* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
;* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
.global _c_int00
.global _exit
.global _bootstrap_main
.global _start_ebss
.global _end_ebss
.text
* FUNCTION DEF : _bootstrap_main *
_bootstrap_main: .asmfunc
MOVL XAR0, #_start_ebss
MOV AL, #0
MOV AH, #(_end_ebss - _start_ebss - 1)
RPT AH || MOV *XAR0++, AL
* CALL USER'S PROGRAM *
LB _c_int00 ; execute TI init routines
LCR _exit
.endasmfunc
i am using f280039c Lunchpad ..unable build this code getting error
In CCS tool output file ,libery ,linker file i used FAPI_F28003x_EABI_v1_58_10.lib
Description Resource Path Location Type
[E0200] Unable to resolve this relocatable expression; relocation support for arbitrary expressions is not available in the C6000 EABI bootstrap_app.asm /can_bl/bootloader line 59 C/C++ Problem
