TMS320F28075: TMS320F28075PZPT Layout Question
Part Number: TMS320F28075
Hi expert,
     My customer applied the MCU’s (TMS320F28075PZPT) symbol and have a question regarding the land pattern. As shown in the attached screenshot, within the dashed area labeled "Metal covered by solder mask," should the vias be treated with via filling, or is it sufficient to cover them with solder mask over the area on the PCB?
Thanks for your help
Andre
  • Hi Andre,
    are you asking about the type of vias to be preferred then through hole should be enough, since its QFP package.
    Buried/filled vias add costs to the PCB and only used if you board is very small and no trace routing available.
    Uttam
