Device IO and peripherals configuration
Other Parts Discussed in Thread: CONTROLSUITE
I'm new to using this DSP and CCS. I'd like to know if TI has a GUI tool to graphically configure the device's GPIO pins and peripherals and automatically generate the code. I've done a design and now I'm sitiing here manually configuring more than 100 GPIOs without talking about the different peripherals... Please help!
Regards!
Albert
    Regards!
    Albert
    Albert,
    For C2000 there is a pin MUX utility included in control suite (www.ti.com/controlSUITE).  In the default install location it will be found under:
    TI\controlSUITE\device_support\~Utilities
    The utility will generate header files that you can then use in your code to configure the pins.
    Lori
