Is any information available about the F28M35 power consumtion - standard scenarios?
You can refer to the Current consumption section of F28M3x datasheet for the preliminary Operational power numbers. We plan to update the table with the preliminary Low Power numbers shortly.
Please note that these are not the final numbers. We will publish the final numbers after analyzing the characterization data.
- Vaish
Many thanks.
I was surprised - it's above 700 mW! - also Concerto declared as low power.
It can be more than for OMAP-L13x - also dual core ARM+DSP - also they (OMAP-s) are significantly stronger.
Roman
Roma
Just to clarify, what I mean by Low power numbers is the device low power mode numbers for Sleep and Deep sleep modes. The current data sheet does not have this section updated.
The Operational mode numbers that we have are the initial numbers with a typical configuration of peripherals.
Vaish
