Part Number: TMS320F28384S
Hi
I have installed CCS 20.0.2, when I try to open a cm project in the driverlib directory I had the following error:
Best Regards
Hi
Best Regards
Luca,
The project is set to use the older TI Arm Compiler vs the newer TI Arm Clang Compiler. What you can do is install the older compiler from here:
https://www.ti.com/tool/download/ARM-CGT
If you install it in under C:\ti it should be automatically discovered when CCS starts up. Or you can install somewhere else and just tell CCS to look there in the settings.
IN this capture you can see where my CCS is looking for compilers and then what it found at the bottom.
John
