The generated code in board.c adds lines to configure trip zone when the sysconfig is only configured for digital compare and events.
Since my outputs are not correct, I am thinking this is an error.
Sysconfig:
epwm9.epwmTimebase_hsClockDiv = "EPWM_HSCLOCK_DIVIDER_1";
epwm9.epwmTimebase_phaseEnable = true;
epwm9.$name = "pwmG9";
epwm9.epwmDeadband_enableRED = true;
epwm9.epwmDeadband_enableFED = true;
epwm9.epwmDigitalCompare_EPWM_TZ_DC_OUTPUT_A1 = "EPWM_TZ_EVENT_DCXH_HIGH";
epwm9.epwmActionQualifier_t2Source = "EPWM_AQ_TRIGGER_EVENT_TRIG_DCA_2";
epwm9.epwmDigitalCompare_EPWM_TZ_DC_OUTPUT_A2 = "EPWM_TZ_EVENT_DCXH_LOW";
epwm9.epwmDigitalCompare_EPWM_DC_MODULE_A_EPWM_DC_EVENT_1_latchMode = "EPWM_DC_CBC_LATCH_ENABLED";
epwm9.epwmDigitalCompare_EPWM_DC_MODULE_A_EPWM_DC_EVENT_2_latchMode = "EPWM_DC_CBC_LATCH_ENABLED";
epwm9.epwmTimebase_counterMode = "EPWM_COUNTER_MODE_UP_DOWN";
epwm9.epwmTimebase_period = 1000;
epwm9.epwmTimebase_counterModeAfterSync = "EPWM_COUNT_MODE_UP_AFTER_SYNC";
epwm9.epwmTimebase_phaseShift = 2;
epwm9.epwmDigitalCompare_EPWM_DC_MODULE_A_EPWM_DC_EVENT_1_latchClearEvent = "EPWM_DC_CBC_LATCH_CLR_ON_CNTR_PERIOD";
epwm9.epwm.$assign = "EPWM11";
epwm9.epwm.epwm_aPin.$assign = "GPIO20";
epwm9.epwm.epwm_bPin.$assign = "GPIO21";
board.c
EPWM_setClockPrescaler(pwmG9_BASE, EPWM_CLOCK_DIVIDER_1, EPWM_HSCLOCK_DIVIDER_1);
EPWM_setTimeBasePeriod(pwmG9_BASE, 1000);
EPWM_setTimeBaseCounter(pwmG9_BASE, 0);
EPWM_setTimeBaseCounterMode(pwmG9_BASE, EPWM_COUNTER_MODE_UP_DOWN);
EPWM_setCountModeAfterSync(pwmG9_BASE, EPWM_COUNT_MODE_UP_AFTER_SYNC);
EPWM_enablePhaseShiftLoad(pwmG9_BASE);
EPWM_setPhaseShift(pwmG9_BASE, 2);
EPWM_setCounterCompareValue(pwmG9_BASE, EPWM_COUNTER_COMPARE_A, 0);
EPWM_setCounterCompareShadowLoadMode(pwmG9_BASE, EPWM_COUNTER_COMPARE_A, EPWM_COMP_LOAD_ON_CNTR_ZERO);
EPWM_setCounterCompareValue(pwmG9_BASE, EPWM_COUNTER_COMPARE_B, 0);
EPWM_setCounterCompareShadowLoadMode(pwmG9_BASE, EPWM_COUNTER_COMPARE_B, EPWM_COMP_LOAD_ON_CNTR_ZERO);
EPWM_setActionQualifierT2TriggerSource(pwmG9_BASE, EPWM_AQ_TRIGGER_EVENT_TRIG_DCA_2);
EPWM_setActionQualifierAction(pwmG9_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_ZERO);
EPWM_setActionQualifierAction(pwmG9_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_PERIOD);
EPWM_setActionQualifierAction(pwmG9_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
EPWM_setActionQualifierAction(pwmG9_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_DOWN_CMPA);
EPWM_setActionQualifierAction(pwmG9_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPB);
EPWM_setActionQualifierAction(pwmG9_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_DOWN_CMPB);
EPWM_setActionQualifierAction(pwmG9_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_ZERO);
EPWM_setActionQualifierAction(pwmG9_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_PERIOD);
EPWM_setActionQualifierAction(pwmG9_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
EPWM_setActionQualifierAction(pwmG9_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_DOWN_CMPA);
EPWM_setActionQualifierAction(pwmG9_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPB);
EPWM_setActionQualifierAction(pwmG9_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_DOWN_CMPB);
EPWM_setDeadBandDelayMode(pwmG9_BASE, EPWM_DB_RED, true);
EPWM_setRisingEdgeDelayCountShadowLoadMode(pwmG9_BASE, EPWM_RED_LOAD_ON_CNTR_ZERO);
EPWM_disableRisingEdgeDelayCountShadowLoadMode(pwmG9_BASE);
EPWM_setDeadBandDelayMode(pwmG9_BASE, EPWM_DB_FED, true);
EPWM_setFallingEdgeDelayCountShadowLoadMode(pwmG9_BASE, EPWM_FED_LOAD_ON_CNTR_ZERO);
EPWM_disableFallingEdgeDelayCountShadowLoadMode(pwmG9_BASE);
EPWM_setTripZoneDigitalCompareEventCondition(pwmG9_BASE, EPWM_TZ_DC_OUTPUT_A1, EPWM_TZ_EVENT_DCXH_HIGH);
EPWM_setTripZoneDigitalCompareEventCondition(pwmG9_BASE, EPWM_TZ_DC_OUTPUT_A2, EPWM_TZ_EVENT_DCXH_LOW);
EPWM_setDigitalCompareCBCLatchMode(pwmG9_BASE, EPWM_DC_MODULE_A, EPWM_DC_EVENT_1, EPWM_DC_CBC_LATCH_ENABLED);
EPWM_selectDigitalCompareCBCLatchClearEvent(pwmG9_BASE, EPWM_DC_MODULE_A, EPWM_DC_EVENT_1, EPWM_DC_CBC_LATCH_CLR_ON_CNTR_PERIOD);
EPWM_setDigitalCompareCBCLatchMode(pwmG9_BASE, EPWM_DC_MODULE_A, EPWM_DC_EVENT_2, EPWM_DC_CBC_LATCH_ENABLED);
