Part Number: TMS320F28375D
I am trying to generate 4 PWM signals. The PWM modules available to me are ePWM8, ePWM9, ePWM10, and ePEM11. I am trying to keep ePWM8 as the master and the other PWMs will be shifted from the master by 90°,180°, and 270° respectively. I am getting the required phase shift in ePWM9, but ePWM10 and ePWM11 shows the same signal as ePWM8. Should I configure ePWM7 so that the sync chain works properly? Since I have the 100 pin configuration, the pins for ePWM7 are used for some other function. I am attaching the configuration I am using along with the query.
EPwm8Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT EPwm8Regs.TBCTL.bit.CLKDIV = TB_DIV1; EPwm8Regs.TBPRD = EPWM_TIMER_TBPRD; // Set timer period EPwm8Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up down EPwm8Regs.TBCTL.bit.PRDLD = TB_SHADOW; EPwm8Regs.TBCTL.bit.SYNCOSEL = TB_CTR_ZERO; // Enable sync EPwm8Regs.TBCTR = 0x0000; // Clear counter EPwm8Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Disable phase loading EPwm8Regs.AQCTLA.bit.CAU = AQ_SET; // Set PWM8A on Zero EPwm8Regs.AQCTLA.bit.CAD = AQ_CLEAR; // Clear PWM8A on event A, up count EPwm8Regs.AQCTLB.bit.CBU = AQ_SET; // Set PWM8B on Zero EPwm8Regs.AQCTLB.bit.CBD = AQ_CLEAR; // Clear PWM8B on event B, up count EPwm8Regs.ETSEL.bit.INTSEL = ET_CTR_ZERO; // Select INT on Period event EPwm8Regs.ETSEL.bit.INTEN = 1; // Enable INT EPwm8Regs.ETPS.bit.INTPRD = ET_1ST; // Generate INT on First event EPwm8Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE; EPwm8Regs.DBCTL.bit.POLSEL = DB_ACTV_LOC; EPwm8Regs.DBCTL.bit.IN_MODE = DBA_ALL; EPwm8Regs.DBRED.bit.DBRED = EPWM_DB; EPwm8Regs.DBFED.bit.DBFED = EPWM_DB; EPwm9Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT EPwm9Regs.TBCTL.bit.CLKDIV = TB_DIV1; EPwm9Regs.TBPRD = EPWM_TIMER_TBPRD; // Set timer period EPwm9Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up down EPwm9Regs.TBCTL.bit.PHSEN = TB_ENABLE; // Enable phase loading EPwm9Regs.TBCTL.bit.PRDLD = TB_SHADOW; EPwm9Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN; // Enable sync EPwm9Regs.TBCTL.bit.PHSDIR = TB_DOWN; EPwm9Regs.TBPHS.bit.TBPHS = EPWM_TIMER_TBPRD/2; // Phase is 90 EPwm9Regs.AQCTLA.bit.CAU = AQ_SET; // Set PWM8A on Zero EPwm9Regs.AQCTLA.bit.CAD = AQ_CLEAR; // Clear PWM8A on event A, up count EPwm9Regs.AQCTLB.bit.CBU = AQ_SET; // Set PWM8B on Zero EPwm9Regs.AQCTLB.bit.CBD = AQ_CLEAR; // Clear PWM8B on event B, up count EPwm9Regs.ETSEL.bit.INTSEL = ET_CTR_ZERO; // Select INT on Period event EPwm9Regs.ETSEL.bit.INTEN = 1; // Enable INT EPwm9Regs.ETPS.bit.INTPRD = ET_1ST; // Generate INT on First event EPwm9Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE; EPwm9Regs.DBCTL.bit.POLSEL = DB_ACTV_LOC; EPwm9Regs.DBCTL.bit.IN_MODE = DBA_ALL; EPwm9Regs.DBRED.bit.DBRED = EPWM_DB; EPwm9Regs.DBFED.bit.DBFED = EPWM_DB; EPwm10Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT EPwm10Regs.TBCTL.bit.CLKDIV = TB_DIV1; EPwm10Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up down EPwm10Regs.TBCTL.bit.PHSEN = TB_ENABLE; // Enable phase loading EPwm10Regs.TBCTL.bit.PHSDIR = TB_DOWN; EPwm10Regs.TBCTL.bit.PRDLD = TB_SHADOW; EPwm10Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN; // Enable sync EPwm10Regs.TBPRD = EPWM_TIMER_TBPRD; // Set timer period EPwm10Regs.TBPHS.bit.TBPHS = EPWM_TIMER_TBPRD; // Phase is 180 EPwm10Regs.AQCTLA.bit.CAU = AQ_SET; // Set PWM8A on Zero EPwm10Regs.AQCTLA.bit.CAD = AQ_CLEAR; // Clear PWM8A on event A, up count EPwm10Regs.AQCTLB.bit.CBU = AQ_SET; // Set PWM8B on Zero EPwm10Regs.AQCTLB.bit.CBD = AQ_CLEAR; // Clear PWM8B on event B, up count EPwm10Regs.ETSEL.bit.INTSEL = ET_CTR_ZERO; // Select INT on Period event EPwm10Regs.ETSEL.bit.INTEN = 1; // Enable INT EPwm10Regs.ETPS.bit.INTPRD = ET_1ST; // Generate INT on First event EPwm10Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE; EPwm10Regs.DBCTL.bit.POLSEL = DB_ACTV_LOC; EPwm10Regs.DBCTL.bit.IN_MODE = DBA_ALL; EPwm10Regs.DBRED.bit.DBRED = EPWM_DB; EPwm10Regs.DBFED.bit.DBFED = EPWM_DB; EPwm11Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT EPwm11Regs.TBCTL.bit.CLKDIV = TB_DIV1; EPwm11Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up down EPwm11Regs.TBCTL.bit.PHSEN = TB_ENABLE; // Enable phase loading EPwm11Regs.TBCTL.bit.PHSDIR = TB_UP; EPwm11Regs.TBCTL.bit.PRDLD = TB_SHADOW; EPwm11Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN; // Enable sync EPwm11Regs.TBPRD = EPWM_TIMER_TBPRD; // Set timer period EPwm11Regs.TBPHS.bit.TBPHS = EPWM_TIMER_TBPRD/2; // Phase is 270 EPwm11Regs.AQCTLA.bit.CAU = AQ_SET; // Set PWM8A on Zero EPwm11Regs.AQCTLA.bit.CAD = AQ_CLEAR; // Clear PWM8A on event A, up count EPwm11Regs.AQCTLB.bit.CBU = AQ_SET; // Set PWM8B on Zero EPwm11Regs.AQCTLB.bit.CBD = AQ_CLEAR; // Clear PWM8B on event B, up count EPwm11Regs.ETSEL.bit.INTSEL = ET_CTR_ZERO; // Select INT on Period event EPwm11Regs.ETSEL.bit.INTEN = 1; // Enable INT EPwm11Regs.ETPS.bit.INTPRD = ET_1ST; // Generate INT on First event EPwm11Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE; EPwm11Regs.DBCTL.bit.POLSEL = DB_ACTV_LOC; EPwm11Regs.DBCTL.bit.IN_MODE = DBA_ALL; EPwm11Regs.DBRED.bit.DBRED = EPWM_DB; EPwm11Regs.DBFED.bit.DBFED = EPWM_DB;
