TMS320F28377D: TMS320F28377D: Customized Bootloader for TMS320F28377D
Part Number: TMS320F28377D
Hello Sir,
We have developed customized bootloader on CAN for core1 of TMS320F28377D controller.
Now I need to program core2 from the same bootloader code.
Please suggest how can i access core2 flash from bootloader code. (CAN initialization done on core1 pin configuration)
Bharat
  • Hi Bharat,
    CPU1 can't program CPU2 flash directly -- CPU1/CPU2 can only program their allocated banks respectively. However, if you stream everything via CPU1, you can transfer that to CPU2 memory using shared RAM/IPC and let CPU2 handle programming it's bank.
    Please take a look at the SCI flash kernel example in C2000Ware. This uses the same SCI module for both CPU's (switches the SCI ownership to CPU2 when needed), you can implement this similarly for your CAN bootloader.
    Host: C2000Ware_X_XX_XX_XX\utilities\flash_programmers\serial_flash_programmer
    Target: C2000Ware_X_XX_XX_XX\device_support\f2837xd\examples\dual\F2837xD_sci_flash_kernels
    Documentation: SCI Flash Programming Guide
    Also, please reference the F2837xD IPC Driver User's Guide for more detailed information.
    Matt
