Part Number: TMS320F2800137
Hello expert!
S5 and S7 in the above figure are a set of ePWM (A and B), while S6 and S6 are a set of ePWM (A and B). When the sine value is positive, S5 and S7 complement each other at high frequencies, while S6 and S8 are at high levels with negative sine values. S6 and S8 complement each other at high frequencies, and S5 and S7 are at high levels. The sine cycle is 20ms.
I use the following configuration ePWM method:
SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_TBCLKSYNC);
//5
EPWM_setActionQualifierAction(HB_PWM_1_2_PWM_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_HIGH, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
EPWM_setActionQualifierAction(HB_PWM_1_2_PWM_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_LOW, EPWM_AQ_OUTPUT_ON_TIMEBASE_DOWN_CMPA);
//7
EPWM_setActionQualifierAction(HB_PWM_1_2_PWM_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_LOW, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
EPWM_setActionQualifierAction(HB_PWM_1_2_PWM_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_HIGH, EPWM_AQ_OUTPUT_ON_TIMEBASE_DOWN_CMPA);
EPWM_setDeadBandDelayPolarity(HB_PWM_1_2_PWM_BASE, EPWM_DB_FED, EPWM_DB_POLARITY_ACTIVE_LOW);
//6
EPWM_setActionQualifierAction(HB_PWM_3_4_PWM_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_HIGH, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
EPWM_setActionQualifierAction(HB_PWM_3_4_PWM_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_HIGH, EPWM_AQ_OUTPUT_ON_TIMEBASE_DOWN_CMPA);
//8
EPWM_setActionQualifierAction(HB_PWM_3_4_PWM_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_LOW, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
EPWM_setActionQualifierAction(HB_PWM_3_4_PWM_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_LOW, EPWM_AQ_OUTPUT_ON_TIMEBASE_DOWN_CMPA);
EPWM_setDeadBandDelayPolarity(HB_PWM_3_4_PWM_BASE, EPWM_DB_FED, EPWM_DB_POLARITY_ACTIVE_HIGH);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_TBCLKSYNC);
But I am concerned that frequent disabling and enabling of PWM clocks may affect the system's waveform. Is this usage reasonable? Is there a simpler and more effective way to implement ePWMA and switch between high-frequency complementary waves and high levels?
best regard!
yours
thanks
