I am currently working on a TMS320F28379D controller for driving a 3-phase motor. The controller generates 6 firing pulses, which are connected to an IGBT driver. To monitor the health of the IGBTs, the driver provides a pulse signal on every firing event with a duration of 750ns. If the pulse width exceeds 1.2µs, it is considered a failure for the respective IGBT.
I need guidance on the following aspects:
Can the TMS320F28379D measure a 750ns pulse?
Since the controller operates at 200 MHz (5ns per clock cycle), I believe it should be capable of capturing the pulse width using an appropriate peripheral.
How to ensure measurement occurs only during each firing event, not continuously?
I want to measure the pulse width only when the PWM pulse is generated, not continuously monitoring all signals.
Which comparator or peripheral should be used for pulse width comparison?
Would eCAP (Enhanced Capture module) be suitable for measuring this pulse width?
Is there a way to use CMPSS (Comparator Subsystem) for detecting if the pulse width exceeds 1.2µs?
