Part Number: C2000WARE-MOTORCONTROL-SDK
Hi, I am using F280049 uC for motor control application. I am using sincos encoder and not the fast estimator.
Can you help me understand the use of delay compensation in FOC algorithm and whether should I add it or not?
I understand that the currents and position sensor is captured at the start of PWM cycle and voltage is applied only at the end of the PWM cycle. Is this why we do a delay compensation?
Is the compensated angle used for converting Vdq to Vabc or also for converting Iabc to Idq ?
I am confused. Some explanation will help.
Thanks in advance.
