I occasionally get denormalized values after some calculations and I am trying to determine whether it affects later calculations or not and also how to test for these values.
In all cases, I am using float32_t with the relaxed floating point option on.
For example, if x is a float32_t and is DEN, what happens on the CLA if you take the sin(x)? Does it consider x to be 0? Does it fail or generate exception flags or interrupts in any way?
How do I test x to see if it is denormalized? On the C28x, I would use the following code, but fpclassify() (found in math.h) isn't implemented for the CLA in CLA_math.h.
if (fpclassify(x) == FP_SUBNORMAL) { x = 0.0f; }
