SCI problem
Other Parts Discussed in Thread: TMS320F28069
For tms320f28069 when it is communicating through  UART , if i pull out the wire between TX and RX then communication process permanently stops.
i want to setup again that communication without restarting the microcontroller , when i will connect that wire between TXD pin and RXD pin..How i can do that...?
thanx
Dipankar
  • Hi Dipankar,
    you need some kind of synchronization. Either with additional lines (CTS, RTS, ...) or within the protocol. Look at MODBUS protocol for an example (either synchronization with special characters-though it limits your payload data format, or timing synchronization)
    Regards, Mitja
