Part Number: TMS320F28P659DH-Q1
Hi experts,
Good day! I am asking for customer.
My customer wants to erase and program flash when ecc occurs. So she use "ECC test mode enable" to flip one bit and wants to initial flash api througn erase flash after enable the test mode.
She found that if enable the "ECC test mode enable", once she call "Fapi_initializeAPI" function, then will jump to NMI interrupt.
However, the ECC interrupt should trigger only with a flash read. So she wants to know why the use of Fapi_initializeAPI function will also cause an interrupt ECC interrupt? In the Fapi_initializeAPI function, will the flash be read?
Could you help to check this?
Thanks!
Best Regards
Kita
