Part Number: TMS320F28388D
Hi experts,
i'm using 24 message object as shown below
but when adding new message object, this message is shown to me
i want to know what's the issue here ?
Hi experts,
Which CAN example test case are you running? Or it this a code that you are writing on your own? I tried a couple of the DCAN test cases here but i do not see the error. Also, can you check the version of C2000Ware and CCS you are using?
joseph
this code written by my own
i'm using C2000Ware_5_01_00_00, and CCS version 12.8.1
thanks,
Can you try using the example CAN test cases? I do not see an issue with CAN mailbox configuration with the existing examples. Just wanted to first confirm that the examples do not show the CAM mailbox error.
Joseph
