Part Number: TMS320F280039
Hi experts,
I am testing the function of DB and Global load with frequency changing. The details are as follows.
All the CMPA CMPB TBPRD FED RED are using global load (OSH). The moment of global load is TB counter reaches 0.
If the FED value exceeds TBPRD value, Is the follow content depicted in the picture true?
1.Even if the TB counter has reached 0, the FED will continue to count and continue to produce the dead-band delay effect.
2.When frequency changing and global load happened, Since the FED counter has not reached 0 at this time, it will not respond to this load instruction.
3.Based on 2, This global load instruction will be cached by FED, and then the global load instruction will be executed when the FED count reaches 0.
4.Based on 3 & 4, In the first PWM cycle after frequency conversion, a pulse will be lost at the circled position in the figure
Leo
