F29H850TU: Unable to do anything with the hardware in CCS 20.0.2 version due to Ccs-server error
Part Number: F29H850TU
I was using F29x processor with CCS 20.0.2 and at one point it got stuck. I had to close it. When I reopened it, I started getting the following error dialog box related to ccs-server:
Now, I am unable to load any .out files to the processor. The load program option is in grey and cannot be selected, and the window always has the "Code Composer Studio - Initializing..." all the time. I tried restarting and the issue persisted. This help page does not have this particular error information and any other steps in the document that I tried did not help. 10.1. Installation — Code Composer Studio 20.1.0 Documentation
I have uninstalled the ccs software and I will have to reinstall the ccs now. If the issue still persists, I will update here accordingly, but is there any better way to deal with this?
  • If this cannot be resolved now, is there any workaround, or can we configure older ccs version, like ccs1270, to run F29x? That tool is good to use. Please reply quickly with anything because this is stopping me from debugging code on F29x and we have no other tool to do this.
    Even with reinstallation, the issue persists.
    I have also attached the log data that the above dialog box points to:
    !SESSION 2025-04-25 16:43:13.262 -----------------------------------------------
    eclipse.buildId=unknown
    java.version=17.0.2
    java.vendor=Eclipse Adoptium
    BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
    Framework arguments: -application com.ti.ccs.server.start -pluginCustomization C:\ti\ccs2011\ccs\eclipse\ccs.preferences.ini -ccs.socketPath \\.\pipe\071317f007b416841cb469df540db4df.sock -ccs.workspaceFolderPaths c:\Users\sananth\workspace_ccstheia -ccs.defaultImportDestinationPath c:\Users\sananth\workspace_ccstheia -ccs.buildSecurityPolicy level:desktop
    Command-line arguments: -os win32 -ws win32 -arch x86_64 -application com.ti.ccs.server.start -pluginCustomization C:\ti\ccs2011\ccs\eclipse\ccs.preferences.ini -data C:\Users\sananth\AppData\Local\Texas Instruments\CCS\.ccs-server\workspaces\071317f007b416841cb469df540db4df -ccs.socketPath \\.\pipe\071317f007b416841cb469df540db4df.sock -ccs.workspaceFolderPaths c:\Users\sananth\workspace_ccstheia -ccs.defaultImportDestinationPath c:\Users\sananth\workspace_ccstheia -ccs.buildSecurityPolicy level:desktop
    !ENTRY com.ti.ccs.core 1 0 2025-04-25 16:43:14.090
    !MESSAGE [ccs.trace] CCSServer> IDE session in progress: 0057a61f-41c1-4f6b-a7ca-0c734de9d37e (server v20.1.1.202503191515)
    !ENTRY com.ti.ccs.core 1 0 2025-04-25 16:43:21.270
    !MESSAGE [ccs.trace] CCSServer> shutting down...
    !ENTRY com.ti.ccs.core 1 0 2025-04-25 16:43:21.277
    !MESSAGE [ccs.trace] CCSServer> shutdown complete - ignoring pipes
    !ENTRY org.eclipse.osgi 4 0 2025-04-25 16:43:21.285
    !MESSAGE Application error
    !STACK 1
    java.lang.StackOverflowError
    at org.eclipse.core.internal.dtree.AbstractDataTreeNode.assembleWith(AbstractDataTreeNode.java:180)
    at org.eclipse.core.internal.dtree.AbstractDataTreeNode.assembleWith(AbstractDataTreeNode.java:128)
    at org.eclipse.core.internal.dtree.DeltaDataTree.getChildNodes(DeltaDataTree.java:520)
    at org.eclipse.core.internal.dtree.DeltaDataTree.getNamesOfChildren(DeltaDataTree.java:619)
    at org.eclipse.core.internal.dtree.DeltaDataTree.safeNaiveCopyCompleteSubtree(DeltaDataTree.java:870)
    at org.eclipse.core.internal.dtree.DeltaDataTree.safeCopyCompleteSubtree(DeltaDataTree.java:855)
    at org.eclipse.core.internal.watson.ElementTreeIterator.<init>(ElementTreeIterator.java:69)
    at org.eclipse.core.internal.resources.Resource.accept(Resource.java:94)
    at org.eclipse.core.internal.resources.Resource.accept(Resource.java:55)
    at org.eclipse.core.internal.resources.Resource.accept(Resource.java:117)
    at com.ti.ccs.project.ProjectCoreUtils.findFirstFileOfContentType(ProjectCoreUtils.java:2149)
    at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:273)
    at com.ti.ccs.server.model.ProjectDescriptor.isStale(ProjectDescriptor.java:334)
    at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:478)
    at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462)
    at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495)
    at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504)
    at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726)
    at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240)
    at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276)
    This post is being rerouted to the CCS team for further assistance.
    Ozino
  • This help page does not have this particular error information and any other steps in the document that I tried did not help. 10.1. Installation — Code Composer Studio 20.1.0 Documentation
    Can you try clearing the cache in the folders mentioned in the below FAQ?
    https://software-dl.ti.com/ccs/esd/documents/users_guide_ccs/ccs_faqs.html#i-want-to-restart-code-composer-studio-with-a-fresh-environment-how-do-i-do-this
    Also please note that CCS 20.1.1 is the current latest version. It has several key fixes and enhancements to improve stability so I would suggest updating to that version as soon as you can.
    ki
