TMDSCNCD28P55X: Test Vector Problem at Arc Fault Detection using Embedded AI models
Part Number: TMDSCNCD28P55X
Other Parts Discussed in Thread: TIDA-010955
Hi, I was looking through this device's design guide and application in arc fault detection using embedded AI models.
This device is composed with TIDA-010955 and control card C2000.
I was trying to build NN model from Model Composer and test it with 'test vector'. However, I couldn't find the 'expressions' tab just as written in document 'Arc Fault Detection using Embedded AI models' at 7.3.3. I'm pretty sure that I've checked on CCS while running the code and Model Composer too.
So I was not able to test the model with the trained model.
I wish I can get help with this and want to say thank you for in advance for your kindness.
